Question about Philips Xenium 9@98 Cellular Phone
I need LCD for phillips CT9A9K - Philips Xenium 9@98 Cellular Phone
My Phillips 52" LCD TV won't turn on...it is just
it possibly you have shorted power supply board or inverter board that cause of clicking sounds..
try to unplug the inverter board then try again if the indicator lit in blue you have shorted inverter board that need to be replace.
Nov 06, 2012 | Televison & Video
Remote code for 26" LCD Dynex tv
Remote code for who? Dish network? Comcast?
CableVision UR2-CBL-CV04 code: 096
Charter DIGITAL code: 0463
Comcast M1057 code: 0463, 10463
Cox COX code: 0463
Direct TV RC23 code: 10463
Dish Network VIP508 code: 720
Dish Network VIP622 code: 720
Motorola DRC800 code: 0463
One for All URC-6690 code: 0464
Phillips PDVR8 code: 115
Phillips PH5DSS code: 115
Phillips PHDVD5 code: 115
Phillips PMDVR8 code: 115
RCA RCU807 code: 135
Rogers DCT3250 code: 0463
Shaw DCT3416 code: 0463
Sony RM-VL600 code: 8043
TiVo HD code: 0091
TiVo SERIES 3 code: 0091
Jun 06, 2011 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
Haw to remove the base from sharp LCD TV 56 in
I find this guide about how to remove the Base of an LG LCD TV. Things You'll Need:
* Table or other flat surface
* Soft cloth or towel
* Phillips screwdriver
Instructions:
1 Unplug your LG LCD TV from its power supply and unhook any other cables from the TV.
2 Lay a towel or a soft cloth onto a table or another flat, supportive surface.
3 Lay the LG LCD TV face down on the towel, which will protect the screen from being damaged.
4 Use the Phillips screwdriver to remove the four bolts that hold the base in place. The bolts are located in the center of the TV near the bottom.
5 Slide the stand out from the bottom of the TV.
6 Press the protection cover, which is supplied with the TV, into the spot on the TV where you removed the base until you hear it click into place.
7 Re-insert the four bolts you removed into the holes on the back of the TV and tighten them with the Phillips screwdriver.
I hope this help; remember to rate this answer. Good luck.
Sep 30, 2010 | Sharp LC-32SB24U 32 in. LCD TV
I have a problem with my phillips universal remote control.i lost the codes to use with my hyundai lcd tv HLT3270
Need to figure out which Phillips remote you have. This link to Phillips web site has user manuals and code list for their remotes, just find your remote, and it should give you a link to the code list.
Philips Remote Control Finder
Sep 22, 2010 | Televison & Video
How do i disassemble to access motherboard and DC jack
Me too, need to get inside to clean and remove dust and see why my video is gone after about 10 minutes of operation or so, good chance it is an overheating problem, but I cant get the case open.
May 19, 2010 | E-Machines M5414 Notebook
How to replace screen on Pavilion dv7-1040us. is diferent from other hps I have replaced, cannot figure out how to remove it.
Here it is! Have fun!
  1. Remove the four 4 mm P1 Phillips-head screws that secure the hinges to the display panel enclosure.
  2. Remove the two 4 mm P1 Phillips-head screws that secure the metal tabs on the bottom center edge of the LCD panel to the display panel enclosure.
  3. Lift the LCD panel out of the display panel enclosure.
LCD Panel replacement Note: Before replacing the LCD panel, remove the left and right hinges from the old LCD panel and install them on the new LCD panel.
  1. Place the LCD panel into the display panel enclosure.
  2. Replace the two 4 mm P1 Phillips-head screws that secure the metal tabs on the bottom center edge of the LCD panel to the display panel enclosure.
  3. Replace the four 4 mm P1 Phillips-head screws that secure the hinges to the display panel enclosure.
To remove in order to replace LCD, you will have to remove WLAN, keyboardwith the instruction :
Wireless LAN Minicard removal Caution! Observe all precautions when removing and replacing components.
Before you begin: Remove the battery2_bing.gif.
  1. Loosen the two captive P1 Phillips-head screws that secure the memory/wireless LAN Minicard cover to the bottom of the notebook.
  2. Use your finger or a flat-bladed tool to lift the edge of the memory/wireless LAN Minicard cover and remove it.
  3. Carefully disconnect the wireless antenna cables from the wireless LAN Minicard with a small needlenose pliers or tweezers.
    Remove the two 3 mm P1 Phillips-head screws that secure the wireless LAN Minicard to the system board and allow it to release to the spring tension position.
  4. Grasp the wireless LAN Minicard by the edges and pull gently to remove it.
  5. Place the wireless LAN Minicard in a static dissipative bag.
Before you begin: Remove the battery.
  3. Remove the 8 mm P1 Phillips-head screw in the memory/wireless LAN Minicard compartment that secures the keyboard to the base enclosure.
  4. Remove the two 8 mm P1 Phillips-head screws that secure the keyboard to the base enclosure.
  5. Turn the notebook right side up and open the display panel fully.
  6. Use a flat-bladed tool or your finger to lift the top edge of the keyboard and slide the keyboard toward the rear of the notebook.
  7. Using minimal force, push the locking bar toward the rear of the notebook to unlock the keyboard ZIF connector on the system board.
  8. Remove the keyboard ribbon cable from the ZIF connector and remove the keyboard.
Keyboard replacement
  1. Place the keyboard right side up on the top cover and insert the keyboard ribbon cable into the keyboard ZIF connector on the system board.
  2. Push the locking bar toward the front of the notebook to lock the keyboard ZIF connector on the system board.
  3. Toe the tabs on the bottom edge of the keyboard into the top cover.
  4. Press the keyboard flat.
  5. Close the display panel and turn the notebook upside down.
  6. Replace the 8 mm P1 Phillips-head screw in the memory/wireless LAN Minicard compartment that secures the keyboard to the base enclosure.
  7. Replace the two 8 mm P1 Phillips-head screws that secure the keyboard to the base enclosure.
  8. Toe the memory/wireless LAN Minicard cover into the base enclosure.
  9. Tighten the two captive P1 Phillips-head screws.
Dec 09, 2009 | HP Pavilion dv7-1240us Notebook
I need screws for an Olevia LT37HVS tv stand
Most of these sets us either a M4 or M6, around 22mm. this is close to a 2" long 1/4-20 screw, but in metric.
Home depot or radio shack, or just about any place that sells TVs these days ought to have them.
At radio shack, a wall mount comes with the following screws to fit all TVs:
  • 4 x Phillips screw (M4 x 10 mm)
  • 4 x Phillips screw (M4 x 20 mm)
  • 4 x Phillips screw (M6 x 12 mm)
  • 4 x Phillips screw (M6 x 20 mm)
  • 4 x Phillips screw (M6 x 30 mm)
  • 5 x Phillips screw (M5 x 6 mm)
Only caveat is don't go with a screw substantially longer than what is needed.
Oct 23, 2009 | Olevia LT37HVS 37 in. LCD HDTV
No sound from Phillips 37 LCD
The audio output IC is probably faulty this cost only a few dollars if you replace it your self.Let me know if you need further assistance or more information.
Mar 30, 2008 | Televison & Video
Philips Xenium 9@98 Cellular Phone Logo
48 people viewed this question
Top Philips Cell Phones Experts
Vladimir Frolov
Tom Chichester
tosin_christ
Are you a Philips Cell Phone Expert? Answer questions, earn points and help others
