Question about Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
When the tv is on i get vertical colored stripes along the whole screen
  • 4,889 Answers
Do the stripes reduce in intensity after the set is on for a while? Please provide this info so that I can help you with your problem.
Posted on Nov 12, 2010
Vertical rainbow stripes on my GB color
I would say that the screen is causing the lines in a gameboy colour the lines are not the same like it would be in an orginal gameboy the one with the four batteries. Lines in gameboy color are the screen issues then the whole screen would have to be replaced on the GBC then.
May 18, 2013 | Nintendo Game Boy Color Console
I have multi colored vertical lines across the entire screen. The menu screen is perfectly legible when selected on the remote and will go on and off like it is suppose to.
If this tv vertical colors lines problems happen by itself,tv problems not causes by u or an object by hitting forces to the tv LCD screen panel itself.The tv board that call the T-CON board it is dead,this board sit in the bottom in the middle of the LCD screen panel.Must be replaced the T-CON board to solve tv vertical colored vertical lines.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish T-CON board for the replacement.If causing by u or an object by hitting forces it to the LCD screen panel itself.The tv not worth a whole tv anymore,because by replacing the tv LCD screen panel will cost the same as a new tv.
Jul 28, 2011 | JVC LT37XM48 LCD TV
Half of my screen will turn in to vertical colored stripes
T-con board. Check lvds cable for tight connection.
Sep 15, 2009 | LG 42LC2D 42 in. LCD HDTV
Green line running vertically along the edge of picture
If its a LCD projection TV (such as Sony Wega, Hitachi, Epson, Philips, and some Panasonic, some Mitsubishi), and the green image is in the whole screen or just one part as a blob or a line. Is most probably that one of your LCD Color Filters is damaged (burned out or starting to get busted), I don’t know if you can just replace the color filter, I believe you need to change the whole light engine system or the optical block. There are some places around, I found some on ebay but you should definitely try on discountdashmerchantdotcom their price range $260.00 - $330.00
Jun 25, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
TV Screen Stripes
NOt very clear.....
Multiple stripes all over the screen? Vertical or horizontal?
If it's only like an inch vertical lines put a mark on the cabinet where exaclty the line is, turn off the TV then open the back, you'll see lots of ribbon wires (gold color) from the plasma panel it self going to buffer boards, using the mark find the closest ribbon wire where the line is showing then remove and clean the contacts, make sure to reseat it properly when putting it back otherwise you'll just add more lines or black bar on the screen if pins are not seating properly.
But do not be afraid if the lines get worst just turn the power off right away and reaset the ribbon wire till you get it correctly.
CAUTION;
DO NOT try to do this while the TV is on oherwise you'll burn COF (Chip on film) on the panel and you'll end up replacing the whole PDP.
Mar 08, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Green vertical stripes down right hand side of screen, no picture
Unfortunately this means that your TV may be damaged. I would suggest talking to a professional or consider replacing your TV depending on the cost of fixing it.
What it means is that the power to that line of LCDs in your screen is 'stuck' and it is generally not user-serviceable.
Jan 23, 2009 | LG 19LG30 19 in. LCD HDTV
Hitachi 60v500 tv has split screen with white vertical stripe down side
Good Day, poandflo;
After removing the power from TV remove the back of the TV (bottom only): Repair: Re-insert PDM connector on both Main Digital module and Drive PWB.
Good Luck, big IRISH. ps. remove cables one at a time and plug back in ensuring that they are seat properly.
Aug 08, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Big vertical tinted stripe on screen
Need more information:
Can you isolate which color is causing the banding?
Is there something ON the lense itself?
Is the projection mirror broken or bent?
S
Dec 12, 2007 | Sony Grand WEGA KDP-57XBR2 57" Rear...
Dark Vertical Stripe on Right Edge of Screen
I experienced the same approx. 1/2" vertical stripe on a Viewsonic vx1945 and ATI Radeon x1050 video adapter on Vista Business SP1, but the stripe appeared along the left edge of the screen, instead of right edge. I then temporarily decreased the monitor resolution, and the stripe went away. I then increased the monitor resolution back to its original setting, and the stripe did not re-appear. So, that was the 'fix' in my situation, hope this helps.
Dec 11, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Black Out
Hi Detrix, Check with www.lcdrepair.net if you want a repair. Something is wrong with your LCD controller and or GUI interface circuit or the circuit supplying power to it. If your technically endowed, you may want to open the monitor case and clean the dust and lint from around the circuits using a Small paint brush to sweep away any built up dust. These circuits take the Signal from the computer and controls the 2.5 million pixels on the LCD screen. Dsut can cause major problems with handling all that data. Give it a shot, what do you have to loose, its not dangerous if the monitor is unplugged.
Oct 09, 2007 | Samsung SyncMaster 193P 19" LCD Monitor
Sony BRAVIA KDL-40V2500 40 in. LCD HDTV Logo
131 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
