Question about KitchenAid Dishwashers
My dishwasher is stuck on rinse only cycle - KitchenAid Dishwashers
  • 3 Answers
Try going to the breaker box and resetting the breaker.
Posted on Nov 12, 2010
'low rinse' stuck on with full rinse aid, can't start wash cycle
Actually, if you look closely at that Low Rinse button or emblem, you will see a little lock symbol ABOVE the words "Low Rinse", and I'll bet THAT light is the one that is on. Basically, you have the control lock (or child-lock) turned on. To turn it off, you have to press and hold the SANITIZE button for 3 to 5 seconds until that light goes off. Now your dishwasher will work!
Mar 11, 2015 | Samsung DMT400RHS Builtin Dishwasher
DD603 top draw cycle getting stuck on 73min??????
Normally if you started the rinse cycle with water already in the base of the dishwasher it will immediately go into circulating the water through the wash arms. Do you hear the wash arms running when the washer is stuck at 11mins? Also when the washer is stuck at 73 mins are the wash arms running all the time or do you hear the pump operate at some stage?
If you have the dishwasher manual available make sure the water pressure setting is at HI or LO depending on your rated mains water pressure.
Apr 30, 2013 | Fisher and Paykel 24 in. DD603H W Built-in...
My sr24h hobart undercounter dishwasher is stuck in a mode where all it does is drain water out. Will not do anything else...???
Hello There; If your unit stuck on the wash cycle and not advance to rinse cycle because the rinse water is not up to 180 degree . You've to check out the booster element and the rinse temp. I hope this will help.
Sep 19, 2010 | Hobart SR24-H Built-in Dishwasher
Dishwasher doesnt drain on wash cycle,ok on rinse cycle
Change the circuit board, timer/progrsmer.
Take it out and clean contacts,
Look for burnt circuit line and solder a fine bead carefully on the circuit board, difficult. Use the pot and pan program.
Vitally
May 03, 2009 | Maytag MDB7100AWB Dishwasher
MY G892SCUPLUS MIELO DISHWASHER LIGHTS AND CYCLES ARE STUCK.
The rinse aid light means you are out of rinse aid. The salt light means you have to add salt to your built in water softener. If the drain/intake light is on, that is when you have a problem. It will flash when there is a problem. You have to count the flashes and that will tell you what the error is.
Sgt 48
Jun 01, 2008 | Miele 24 in. G892SCU Plus Built-in...
Dishwasher is stuck on the rinse cycle
make sure the float or metal probes in the unit are clean.they sense water and if anything is on them it will cause a malfunction in the unit.
Aug 27, 2007 | Hotpoint 23 in. BF41 Built-in Dishwasher
The "Rinse Only Button" will not function even after going through the "Cancel" cycle.
br, sounds like you have a stuck keypad. This would be the only reason it is switching to a different cycle. Catriver..post back.
Oct 01, 2006 | KitchenAid 24 in. KUDS25 Built-in...
My Kenmore diswasher gets stuck between the quick rinse and drying cycle
I am having the same issue as described above. I think it is either the timer, thermostat (temp assure), or thermostat (temp boost) that needs replacing. The dial gets stucks in both the wash temp boost cycle and rinse temp boost cycle. However, I don't have a picture of the temp assure or boost part. Does anyone know how to fix this? Thanks. -Bill
Aug 31, 2006 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwashers Logo
174 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
