Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
I have clean the carb. new sparke plug check the spark and it still will not starteven new gas ? Jerry
    President:
  • Ryobi Master
  • 1,545 Answers
New gas can be a help...especially if the old gas is a month or more old. More important are all the different things that can lead to a no-start scenario with your machine. By process of elimination, you have to take it step by step and try to rule out all the different causes. Remember, this is an internal combusion engine, very similar to your car engine in that regard (it just doesn't have any valves and burn oil with the gas). A no start or stalling out and dying condition are the most common malady in these forums. For a start, check carbon buildup in the muffler and on the screen in the back of it. It's easy to take the muffler off. Torx head fasteners bolt it to the exhaust port of the engine. Check the exhaust port for bad buildup. Never clean it off the engine with metal...scrape it with a wooden device. Remove the spark plug. Shine flashlight down into engine. Is there a lot of carbon on top of the piston? Cleaning it up is a serious job if you remove the engine to do so.
Here is a Zama pdf file troubleshooting most possible mechanical and carburetor related problems. This is good reading and there is a lot to learn here. The charts are about 1/3 of the way into this file. Make sure all the screws and bolts to the carb and engine are tight and that the air filter is clean.
http://www.zamacarb.com/pdfs/QuickKit_CR2010.pdf
You will need Adobe Reader on your computer to view this. If you don't have it (it is safe), it's a free download from their website. You can always remove the program later.
Posted on Nov 12, 2010
Echo PB 251 won't run. replaced plug, gas, fuel filter, air filter. took carb a part, and cleaned with carb cleaner, used the compressed cleaner to clean out venturis/ports.
Wow! with all you have done it should run. Be sure the switch is on but if you are getting spark, it should be on. I would take it to the echo place for service.
May 14, 2015 | Echo Garden
2006 kawasaki 250 ninja has spark, gas to the carb bowls but won't start
If plugs are dry then blocked idle jets are the most likely problem...
Sep 22, 2012 | kawasaki Ninja 250 R Motorcycles
MY HUSQVARNA 36 AIR INJECTION chain saw does not get gas to the spark plug. Checked and cleaned the fuel filter and line and it seems to be clear....??? What else would prevent gas from getting to s
this new gas is a carb killer you will need a new diaphragm for the carb and there is a little screan next to the needle and seat that can be cleaned. about a 5.00 repair if done right.. use marine gas
Feb 03, 2012 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
I have a new batiere in my 1991 vino 50cc tow stroke, And the starter wont work and it wont kick start even with starter fliod. Anything that I can check or replace?
Check fuses. Get a new spark plug then check for spark by hooking up the plug wire then hold the metal side of the plug against the cylinder. Have a friend kick the engine over while you look for spark. Remove the carb, then remove the float bowl from the bottom of the carb. Use spray carb cleaner to clean the carb. How old is the gas? Flush the tank and fill with fresh fuel if old gas is present. Please rate my answer. Thanks.
Apr 06, 2011 | Yamaha G5 Motorcycles
Will not start
If you have a spark plug wrench take out the spark plug look at it if it is all wet engine is flooded with gas,dry it and clean it if it is dry its not getting gas, try putting in a new spark plug. is there gas in tank , is switch on, is gas turned off, is the tank full, is the gas old and stinky? has the tiller sat for months carb may be plugged check ,engine oil level, try a little shot of engine starting fluid or gas sprayed into carb needle valve in carb may be pluged, float in carb may be stuck. tap on carburetor good luck
Jan 31, 2011 | Troy-Bilt Garden
I have a 1979 yamaha enduro 125cc i cant get it to start... i ran when i first got it and then it just died and i havn't been able to get it started... i changed the spark plugs cleaned the gas tank...
Did you squirt some gas in the cylinder to see if it would fire? Check the spark by laying the spark plug on the head, or holding it there with rubber handles, attached to the plug wire, see if you get a spark, if that checks out, you have spark, open up the air filter and peek in the carb, twist the throttle to see if gas comes shooting out. If not, squirt a little gas in the carb, try it, fire? check the fuel filter, pump, carbs could be gummed up. Did you get the jets clean? Run a wire through them to see if they are clear? Blow through them to check. Check it out.
Jun 23, 2010 | Motorcycles
Put new carb on 86 cr 80 ran fine 4 10 minutes then quit changed spark plug and gas still nothing. has spark dont know how hot also changed manifold appeared to be dry rotting still nothing. even attemped...
for any motorcycle to run you need three things. spark, fuel and compression. i see you've tried to get fuel and spark. if you have spark thats one down. dont pour fuel into cylinder. instead spray tiny bit of brakeclean or carb clean into spark plug hole. i have a feeling if you drained your gas after the carb clean the carb most likely sucked bad gas back up and might need cleaned again. ive seen it happen alot on ols bikes.
Jul 11, 2009 | 1993 Honda CBR 600 F(2)P
Suzuki TC 100 won't start but park for 10 years bought new spark
Go to the dealer and ask for the stock plugs for your bike. Check for spark on each of the new plugs then install the plugs.
Remove the carbs , dissemble it and clean the varnish out. Remove the petcock, ( gas valve ),water trap and clean it out. Next let one cup of gas flow into a container. Any water or rust in the bottom of the container? If any rust was in the water trap or the container then purchase an inline fuel filter to eliminate the rust getting into the carb.
If cleaning the carbs yourself does not do the trick then take it to the dealer and have them clean it and install carb kits. This should eliminate the carbs as a problem. Get a new air filter and install it.
Now you have spark, gas and air. If it still will not start it is likely that you need new crank seals. On a bike that old you may well need new crank bearings as well.
Please rate this solution. Thanks!
Mar 22, 2009 | 1972 Suzuki T 350
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
109 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
