Question about Remington Electric Pole Saw
Chain came off and it is too long and can't get it back together.
I take it to mean the exact same chain that was on there before now appears to be too long. Obviously, this is a clue. These things don't stretch.
All chain saws will have the chain get loose with use. You should be checking this and make an adjustment before it gets so loose that it comes off which is very dangerous and can cause injury.
When it appears too long, I can think of two things that may be happening.
1. It really is too long and you need to find the adjustment screw near the base of the blade and screw it in (with a long screw driver or the tool that came with the unit when you bought it) which pushes the chain saw blade further out and tightens the chain. Usually, to get the blade back on, I have to tighten the screw and loosen the chain and then make it tight again after everything is together, so experiment with the process of tightening and loosening the screw. (Note, the loosening and tightening assumes that the nuts on the big bolts that hold on the blade have been loosened to allow the blade to slide. Make sure this loosening was done first.) 2. The chain may have slipped of the sprocket gear that drives the chain. If you have not taken the blade off you can't see this gear well and might not notice. Disassemble the blade and put it back together seeing that the chain is properly seated. Don't screw the bolts tight before you adjust the tension in the blade as in my remarks above. Tighten the bolts well, as the final step.
Posted on Nov 16, 2010
Easy way to remove timing chain on 20008 chevy impala ss with the 5.3 engine
the book shows it as a single chain from the crank to the cam shaft at the base of the V of the block
the easiest way to remove the chain on these is to undo the cam bolts and slide the can sprocket and the crank sprocket together
if you put on the crank sprocket it is difficult to get the cam gear back on the end of the shaft
so pull together
line up the marks and install together
Nov 14, 2017 | Cars & Trucks
Chain will spin when I put clutch and bar back together start it up chain spins then stops and clutch gets red hot?
or a to thick chain or the chain was not cleaned after use before a long time The chain may be stiff with tree resin, you have the chain anyway can rotate by hand when the machine is not on the safety brake
Jan 30, 2016 | Garden
Time chain tensior how to take tha time chain off
Im presuming you already have the timing chain cover off. To remove timing chain you must remove bolts holding the gear on as well and tensioner. These must all come off together. Also must be kept together while putting them back on
Sep 28, 2014 | 2006 Chevrolet Malibu
Chain came off r70 riding mower how do i put it back on
ok there is three sprockets one on the transmission a guide in the middle and onle on your back axle. take a wrench and loosen up the middle sprocket. slide it all the way back untill the chain is snug or tight. tighten up your bolt and it should notice it drives faster and thats how you keep it from falling off. hope it works for you
May 15, 2010 | Garden
How do i put my chain back together after i took links off
You wiil need to take the removed links to a bike shop and buy a joiner link which will clip together, They will match the link to your chain.
May 02, 2010 | 2002 Yamaha TT-R 125 L
Changed the chain and sprocket but can't link the chain back up, do i need a special tool(CBF600 2006)
you are gonna need to loosen off on the back wheel and slide it foward until you get the chain linked back together. Then tighten back up.
Jul 07, 2009 | 2006 Honda CBF 600
I have a pacific usa mountain bike and the chain broke an i bought a chain and I cant figer out how to put it back together
well usually all chains have a link that comes off. if you get that to come apart, then you put the chain on the teeth were the teeth come through between the links. then you link back together the two chain links. it might be a little hard though
Mar 08, 2009 | Mountain Bicycle Chain Press Fit 42 In ...
Trying to put timing chain back after replacing head gasket on a Nissan N22 motor. Need to find adjustment to loosen timing chain so that i can attach timing gear with chain onto OH cam. can you help on...
no adjustment neccesary. There is a timing chain tensioner, which you will simply push back in to its body. once you do that, there should be a small hple somewhere on the body of the tensioner. That' sthere so you can piut a paper clip into it to keep the tensioner from coming out. Once you lock that in place you can remove the tensioner and than the timing chain.Once you get it all back together, just pull back on the pin and the tensioner will come out and put tension on the chain. good luck.
Jul 24, 2008 | Nissan King Cab Cars & Trucks
Remington Electric Pole Saw Logo
158 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
