Question about Cameras
Handbook for old Halina 3000 camera - Cameras
Flash overexposing
  • Page 22 talks about adjusting the flash level see the instruction manual - link below
  • Looking at the handbook - see other link below - Page 41, details how to adjust the flash level, for more or less output
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Apr 07, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
I want to find th A550 Handbook -can anyone help
If you're talking about the Sony DSLR A550 then the address to download a copy of the full 178 page manual to your computer is: http://esupport.sony.com/US/perl/model-documents.pl?mdl=DSLRA550
Jan 22, 2010 | Cameras
My halina mw wont stop winding on
The Halina 35MW wasn't well built and they often had various motor wind problems. This will usually due to one of two things:-
1. A small cam which operates a microswitch on the winder mechanism has broken or worn off.
2. There is a short in the supply to the motor.
Unfortunately, the camera was only ever built as a cheap item and was never designed to be taken apart and repaired. Both faults may in theory be repairable, but from experience you'll almost certainly break something else whilst trying. As the 35MW had poor build quality, poor film registration, and a really poor lens just throw the thing away.
There are loads of far better 35mm film cameras around and there are so many lurking in folks drawers and cupboards that there's never any need to pay for one. Try your local FreeCycle or Freegle group. The free cameras aren't limited to 35mm compacts either; I've had boxed and near unused 35mm AF SLR's by all of the major manufacturers including many accessories as almost nobody wants 35mm gear any more and resale values are so low that some can't be bothered with the hassle of eBay listings, PayPal registration and all the fees charged.
Jan 08, 2010 | Photography
How can I get the pictures on the camera's internal memory copied to a SD card without the camera plug?
just go to one picture options ...and see if it has a feature to move to ...or copy to ...in this case you cand move them to the card ...
anyway ...if there is a card slot ...on his model it has to have something like this ...
after that to do not have this problem ...go to the memory in the menu ...and change the option to save pictures in the card directly ...
if your camera do not support a car d..and only has internal memory ..tan you need a driver and a cable to download them into computer and after that get them to the card .
Nov 16, 2009 | Sony Cybershot DSC-T200 Digital Camera
I have a Halina Digital Photo Frame DPF070B with no instructions. The screen will display only one picture, I have to manually advance to the next photo vs. a slide show functioning automatically. I made...
Go into the folder where the pictures on your memory stick are stored. There should be thumbnails of all of them and you can select anyone with the red border. Select anyone so it shows up in the picture frame. Now press Enter. Five buttons should show up. Press the middle one to start the slide show. Press Esc to stop the slide show. You can also access the tools settings from here to adjust the interval time. Hope this helps.
Aug 15, 2009 | Cameras
No software
I don't know this model, but generally you download in one of two ways. Either you connect a cable from the camera's port to a USB on the computer, or you take out the flash chip from the camera and plug it into the computer's slot (only recent computers have this slot). Either way, the flash chip should now show up as an extra drive (e.g. E) on "My Computer" You can open the directory on that drive, and whatever photo-handling software you have on the computer (Picasa, Photoshop, Microsoft Image) can be used to save the images to your computer.
Jun 05, 2009 | Cameras
Olympus C-3000 download Help
I also have a c-3000 zoom and tried to use it with my vista laptop for the first time (worked fine for years on xp with the software). I got an error message saying something along the lines of "Your camera is too old to work with Vista" (not the exact wording). I bought an external card reader, and you should probably do the same.
Mar 27, 2008 | Olympus C-3000 Zoom Digital Camera
Flash mode locked to Off
Try this, I had the same problem. Here is what I did, I powered off the camera then with the menu button pressed I turned the camera on. This must set the camera back to default settings. I was then able to turn my flash to auto or any other selection.
Dec 28, 2007 | Olympus FE-120 Digital Camera
Cameras Logo
90 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
