Question about Hotpoint Freezers
Have a hotpoint frost free freezer fz150 red indicator stays on,checked for ice build up behind the draws,its clean the pump woks for 15 seconds and then stops,it then comes on about 15 mins later for another 10 seconds....any help would be appreciated
SOURCE: Ice build up in my frost free upright freezer
I looked at the BACK at the bottom underneath of my Sears Kenmore frost free upright freezer and what was causing the ice buildup was very simple. At the factory, the assembler looped the little hose too high and when the water went into the hose it could not get out due to being too high in one spot! An ice dam will form, blocking ALL water coming through
and freezing up any more water coming down giving you a HUGE wad of ice that is scary!!! I just removed the screw holding the loop that holds the hose and put a bit of warm water down the little hole on the INSIDE (Behind the grate) to melt the remaining ice in the tube.You need to take out 4 screws and remove the grate to see this. I could not believe that this was the problem! I haven't had any ice build up since.Now don't tear your freezer apart before you try this trying to fix the compressor, thermostat etc. It may be the only thing wrong with it!
Posted on Jul 21, 2008
  • 1462 Answers
SOURCE: LG frost free fridge freezer GR-359sq
defrost drain is blocked - probably with ice. take the back panel off inside the freezer and melt the ice off with a hairdryer then follow up with hot water till it flows away freely. this takes some patience. if fault reoccurs then get back to me
Posted on Aug 28, 2008
myrlex
  • 674 Answers
SOURCE: Future FZ150 red warning light keeps coming on,
bring to the nearest service center..
Posted on Apr 04, 2010
  • 523 Answers
SOURCE: The red warning light (exclamation Mark) is on?
check the condensor fan if it has one
Posted on May 05, 2010
SOURCE: BEKO AB910 Frost Free Fridge/Freezer Ice build up
I have the same model + problem. You should not need to defrost this model manually if it's working correctly, but the ice build up you describe is probably due to a blocked pipe in the auto-defrost system at the back. You need to defrost properly to prevent recurrence.
Behind the upper freezer drawer there's an aluminium tray behind a plastic grille. Every few days this tray warms up to melt any accumulated ice behind this plastic grille (full height of the freezer). A pipe should take the meltwater down to a plastic tray below (pipe + plastic tray are visible if you take the lower panel off the back). Your problem is too much ice blocking that pipe: the heater can't cope and it doesn't melt, so the ice 'cascades' down the back behind the bottom drawer.
When you manually defrost, you must ensure that this pipe is clear, otherwise the auto-defrost won't work, and you may have to defrost manually again within days.
I have found that the best way to defrost the pipe is to remove the lower back panel, disconnect the corrugated flexible plastic pipe from the stub that comes from the bottom of the freezer, + pump steam into the stub (gently) using a hand-held steamer (with tube + nozzle). You don't have to empty the freezer or move your food as the door stays closed, and no steam gets into the freezer until the pipe is unblocked. Be sure to unplug the freezer before taking the back off! [There is a fan in this area that could start up without warning]
Check how much of the pipe is blocked by gentle probing with a pencil: the aluminium tray is about 105mm above the bottom of the stub. This measurement is important…
When the pipe is clear, there may still be too much ice in the aluminium tray above (not sure how much is 'too much') if you only created a narrow 'chimney' though the block of ice (likely to get blocked again). You need to widen that chimney by melting more of the ice in the aluminium tray. I use a simple steam nozzle made from an old-fashioned Bic pen with a couple of 1mm holes drilled just below the coloured bung at the end. This directs steam onto the walls of the 'chimney' rather than upwards.
There's no point steaming the walls of the plastic 'stub' pipe, so only use the home-made nozzle when your probe reaches 105mm (i.e. when you have melted all the ice in the plastic stub tube but before your 'chimney' has broken through the block of ice in the aluminium tray). If you judge this right, you'll melt almost all of the ice under a still-frozen top surface: no steam will get into the freezer and your food will stay frozen. With a probe it will be clear when you've broken through the top surface of the ice. When you have done so, it's time to look inside the freezer to see how well you have cleared the aluminium tray.
It's perfectly feasible to get all this done in 30 minutes.
Don't forget to replace the corrugated plastic pipe + valve at the bottom. It stops humid air from going into the freezer and icing up in exactly the area we've just been defrosting.
Take a lot of care with steam jets as they can burn you badly. You should check a first aid website so you know what to do BEFORE it happens.
Some of these tips may be helpful: (1) run the freezer at -18 degrees (the 'warmest' setting) so it's not working so hard. (2) Leave a big gap (>100mm) between the back of the freezer and the wall. (3) Clean the matrix of delicate tubes to the left of the fan whilst you have the back off [a small bottle brush is ideal; remove the fan for better access]. (4) Put something between the middle of the freezer and the wall to prevent the warm air that's being blown out behind the fridge from being sucked into the air intake behind the freezer (there is a baffle built in underneath, but nothing behind. (5) Mount the fan on spacers (with longer screws) so that it's closer to the heat exchanger… this means that a larger area of grille can act as an air intake. (6) Raise the unit off the floor a little to free up the air intake path beneath the freezer.
Posted on May 10, 2010
My Hotpoint freezer FZ150 red light keeps flashing. I turn freezer off then on again and its ok for a bit, then it flashes red again,
the flashing maybe door is not sealing check gaskets on door for folds or tears or door not aligned right
Feb 26, 2017 | Hotpoint Freezers
My frost free FZA30 has a build up of ice on the bottom shelf. Is there a cure?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 21, 2011 | Hotpoint Freezers
Kenmore Freezer 106.727581: The freezer ices up and the temp goes up to 34 degrees. If I manually defrost it, it goes to 5 below zero in about 6 hours. How can I determine which of the below need to be...
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited. Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system: The defrost timer The defrost thermostat (also called the bi-metal switch) The defrost heater. To determine if the defrost heater is burned out, watch this part testing video
Aug 21, 2011 | Kenmore Freezers
Icing up
I've just had a similar problem. I fixed it by removing the large panel on the back of the inside of the freezer. I found a large build up of ice at the bottom of the freezer which seems to have developed because the drain hole at the bottom of the freezer was blocked. I defrosted the ice, cleared the drain and now the freezer is working fine.
Jul 23, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Apr 10, 2010 | Freezers
Thick ice build up behind freezer fan
check door rubber,if is oblate heat it with fan,if it is ragged change it.
Jun 29, 2009 | Freezers
Apr 23, 2009 | Freezers
Ice build-up on the inside top of of freezer door
yea def , not normal, nor an acceptable amount of ice forming there( good pic). heres what i have been told to try and with good results
first make sure the door gasket is sealing all the way,(small gaps in ht emagnets at extreme corners) is common but with a little amount of "mortite"or "permagum can sometimes be insterted behind the corner of gasket to assist filling the void.
second a small amound of a white/clear silicone be applied to the outer perimtere of gasket, to minmize air movemnt from between gasket and door panel.
lastley in oyour second pic i see "frost free" written on a plastic air deflector. you can remove that with 3-4 screws on backside of it, and then reinstall with a small spacer so as the baffle now with sit with a 3/8in. gap between it and the top of the freezer liner.( a brass ferrel from the compression fitting of a plumbing fitting is just the right size)..... the theory behind this is to prevent the air from gatting "trapped" in the void created when the door closes-- air can now pass back and forth freely.
I hope this gives you some satisfaction if not I would advise another tech be sent who is willing to call for factore tech support( ths is where i got my info from)
Jan 14, 2009 | Frigidaire 13.7 cu. ft. Upright Freezer...
Is the frost build-up in my freezer normal? Why do I have ice in forming the the bottom of my frost free freezer?
The drain has most likely frozen over. It is at the bottom behind the back panel inside the freezer. You will need to remove all of the ice and run hot water down the drain until it is clear.
Nov 16, 2007 | Freezers
Freezers Logo
74 people viewed this question
Top Hotpoint Freezers Experts
christian nielsen
Victor Nwachukwu
Victor Nwachukwu
Ken Wieczorek
Ken Wieczorek
Are you a Hotpoint Freezer Expert? Answer questions, earn points and help others
