Question about GE Audio Players & Recorders
I need template for GE Spacemaker Model no. 7-4230A
SOURCE: I'm trying to find a User Manual for a GE Spacemaker 7 5295
Right after I posted my request, I managed to find a suitable Users Manual on the web. Thanks for your help.
Posted on Apr 15, 2009
kish-81
  • 3 Answers
SOURCE: GE Slim Spacemaker 7-5295 CD
Make your own template with some thin cardboard. (cereal box) Turn the unit upside-down with the 3 spacers in place & mark their location with a pencil. Then mark the front edge & sides of the radio onto the cardboard. Instant template!
Posted on May 05, 2009
  • 18 Answers
SOURCE: GE SPACEMAKER XL1800 MODEL: JVM1860BF001
MAGNETRON, 99% of the time with your complaint
Posted on Nov 21, 2009
Testimonial: "thanks. I just hate to replace whole unit but it looks like it is going to cost 125 for magentron and 100 for service call plus. "
MicrowaveSvc
  • 9098 Answers
SOURCE: F3 error GE Spacemaker XL 1800: Model JVM1851CD.
F3 on a GE / Hotpoint microwave means you have a shorted membrane keypad (aka membrane switch).
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and of course one should never leave a microwave unattended while cooking.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs nationwide.
Either way, we can let you know what your options and costs would be and send you other helpful info.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me
directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Posted on May 06, 2010
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Spacemaker Microwave, Model #JVM1540SN1SS, buttons don't work
The membrane keypad has failed.
The keypad itself is not available as a separate part, so the control panel frame with keypad would have to be replaced.
This is actually a pretty simple DIY job.
You can part number WB56X10826 from the Pros here for $114.62 plus shipping (that compares to $166.50 from GE!).
You can also find helpful exploded view diagrams at that link.
Then disconnect your keypad strip as shown in the photo below, then remove the screws that hold your circuit board in the old frame.
Then carefully (since the display is made of glass) move your circuit board to the new frame, and reassembly is the reverse of disassembly.
Posted on May 30, 2010
I have a GE OTR microwave JVM1460 spacesaver xl1400. I am trying to take it down. I unscrewed the two top bolts from inside the cabinet. I thought it should just swing down on the mounting strip, b
remove-ge-spacemaker-800x800.jpgRemove a GE Spacemaker
The GE Spacemaker series of microwave ovens are designed to be installed above an oven range, freeing up counter space in your kitchen. Some of these Spacemaker models are connected to an outside venting system to carry kitchen vapor and odors outside. Other Spacemaker models utilize a ductless system to do this. Removing a GE Spacemaker microwave oven isn't a difficult task, but, because of the size of some of the oven models, it is a two-man operation. Have a question? Get an answer from an appliance repair specialist now!
Other People Are Reading
Things You'll Need
  • Assistant
  • Sharp knife
  • Phillips screwdriver
Instructions
    • 1 Open the cabinet above where the Spacemaker microwave oven is installed. If you see a vent in the cabinet leading to the Spacemaker oven below, your Spacemaker is vented. This vent needs to be disconnected before continuing with removal. Disconnect the vent either by loosening the duct clamps or by cutting the duct tape away with a sharp knife. Pull the vent out of the top of the oven.
    • 2 Have an assistant support the oven from below. Loosen the mounting screws connected to the Spacemaker through the cabinet bottom. Loosen the screws by turning counterclockwise with the Phillips screwdriver.
    • 3 Unplug the Spacemaker from the socket in the cabinet.
    • 4 Continue loosening the screws while your assistant holds the oven in place. Once the screws are removed, have your assistant slowly lower the Spacemaker down by lowering the front face at a 45-degree angle.
    • 5 Feed the power cable for the Spacemaker through the hole in the bottom in the supporting cabinet.
    • 6 Help your assistant slowly pull the Spacemaker forward and out of the mounting brackets on the rear wall. Once the Spacemaker is cleared of the mounting cabinet and rear wall, set it down.
    • 7 Remove the mounting bracket from the rear wall by loosening the screws.
Read more : http://www.ehow.com/how_7344250_remove-ge-spacemaker.html
Nov 26, 2014 | GE Microwave Ovens
How do I install a GE Spacemaker Microwave oven?
It depends on where you want to install it. Thet usually go below the cabinetts which are over the oven.
IOt should have come with a template so that you can drill holes into the bottom of the cabinett so the holes you drill will match up with the holes in the microwave. Once done then there should be screws and fiber washers.
Good luck,
Marty
Jun 12, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
How many cubic feet is a GE spacemaker model l# JVM240WL001
you must ask some vendor Online via chat with GE, they offer many Sales, and good opportunity. Get in tourch with them.
God bless you
Aug 03, 2012 | GE Profile Spacemaker 1.8 Cu. Ft....
I need Template and installation instructions for GE Spacesaver Microwave Model JVM1630CJ02, built Jan 2005. Thank you.
You can download GE owner's manuals and installation instructions here.
If the installation instructions do not have the template, you can also find helpful exploded view diagrams and order needed parts by entering your full model number here.
Apr 29, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
We don't have the installation template. Where can we get it?
You can find helpful exploded view diagrams and order parts (including installation materials) by entering your full model number from the tag on the oven
here.
Jan 16, 2011 | GE Spacemaker JVM1540 Microwave Oven
I need to reinstall my ge spacemaker compact disk player under a new cabinet but do not have the layout of were to drill the holes
Hello. I can assist you. Just look at the top side of your player and you will see the holes. Using a piece of paper, lay out the holes on the paper as they are on the unit itself, starting out with the length of the unit, and the depth of the unit that you want under the cabinet. Once you have every measurement including the hole locations you have your layout template. Now, just make a small hole where every screw goes, and tape the template up to the cabinet base paying attention to keeping it uniformly away from the back wall and the front of the cabinet. Use a marker to mark the screw holes and you will be good to go.
Nov 10, 2009 | GE Slim Spacemaker 7-5295 CD Shelf System
Will the template for JVM1790 be the same as earlier GE models?
Make your own template of the holes in the top of your cabinet and lay it over the new unit and see if they align. As long as your replacing GE with GE it probably will work.
Oct 04, 2017 | GE JVM1790 1000 Watts Convection /...
Sep 04, 2007 | GE Slim Spacemaker 7-5295 CD Shelf System
56 people viewed this question
Top GE Audio Players & Recorders Experts
Greg Cann
Greg Cann
Carlos L. Burgos
Carlos L. Burgos
SHARCNET-USA
SHARCNET-USA
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
