Question about HP Designjet 110plus nr InkJet Printer
The printer fails to start when the power-on button is pressed - this happened once before and was "solved" by replacing the 3amp fuse in the plug. Unless I have a whole packet of duff fuses this time it didn't.
  • 2 more comments
  • brianmurray_ Nov 13, 2010
    I need to speak to someone familiar with the HP Designjet 110 as I think this is a problem peculiar to this series of printers. The power button is not a simple on/off switch but involves some form of fuzzy logic as it can turn itself off and on for various reasons in normal operation.
  • brianmurray_ Nov 16, 2010
    I cannot communicate with the printer (to install firmware) because it will not power-up ie there is no green light or other signs of life. The power cable is fine.
    The warranty has expired. Lets see what's involved in replacing the formatter. I'm fairly capable but f I feel I cant cope then I will take it to a repairer.
  • brianmurray_ Nov 17, 2010
    Please let me have details of how to replace the formatter and where to get one..
  • 340 Answers
It could be one of 2 things, the formatter board or firmware. You can get the firmware from the link below. Once you have tried this please reply and let me know if it worked or not and we will take the next step in the troubleshooting process.
http://h10088.www1.hp.com/cda/gap/display/main/gap_home.jsp?cp=1_4011_100&zn=gap
Posted on Nov 13, 2010
  • Lori Langley Nov 16, 2010
    It is most likely the formatter board then. If the printer is still under warranty i would contact HP to have it repaired. If its not, you can do this yourself, however if you are not too farmiliar with the inner workings and such of your printer it can be somewhat difficult. Let me know what you would like to do and we will follow up. I can send you the instructions on how to replace the formatter board where to find one if you decide that is what you would like to do. Please let me know asap so we can get this going for you.
  • 2,567 Answers
If that fuse is failing so often, then this means that there is a failure somewhere in the power circuitry. The most common points of failures in power circuitry are silicon diodes, power transistors & voltage regulators. Please check these using the continuity test (or short circuit test) of a digital multimeter.
Posted on Nov 12, 2010
Tip
Ink System Failure Fix for Some HP Printers
<span><span>Hewlett Packard Ink System Failure Error Fix (tested C6180) </span></span> <ol> <li><span><span>Press and hold the "*" key. </span></span></li> <li><span><span>Press the "#" key and release both keys. Display should say "Enter Special Key Combo" </span></span></li> <li><span><span>Press and release in sequence the "1", "2" and "3" buttons. screen says "support" R0631M </span></span></li> <li><span><span>Press and release the right arrow button until the display says "System Configuration Menu". </span></span></li> <li><span><span>Press and release the "OK" button.</span></span></li> <li><span><span>Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status", </span></span></li> <li><span><span>Press and release the "OK" button. </span></span></li> <li><span><span>Display should say "Hardware failure status: Clear. Press OK to clear". </span></span></li> <li><span><span>Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue". </span></span></li> <li><span><span>Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. </span></span></li> <li><span><span>Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.</span></span></li> <li><span><span>Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer </span></span></li> <li><span><span>Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. </span></span></li></ol><span><span>I hope this helps</span></span> <span><span><br /></span></span> <span><span>Regards GM</span></span>
on Jul 15, 2011 | Office Equipment & Supplies
Tip
Reset all models of Brother Printers
<p>Applicable for all models of Brother Printers. Sorry, I still not yet tried this method because very difficult to get Brother Printer, this is possible cause of the printer is not popular printer. For everyone that having Brother Printer, I hope this post can assist your.<br /> <ol> <li>Disconnect the power cord from your Brother Printer. <li>Press Set button, while holding the Set button re-connect the power to your printer <li>The Error code will be display "Machine Error 46&prime; <li>If the Error code appear, press the "arrow up button" ( ^ ) there will be numbers that are going to be display. <li>Choose 8 then press Set Button <li>Press Arrow Up button again then choose Zero (0) and press Set Button Again, now you will enter Service Mode. <li>Press "Mono Key/Button" 25 times or until "Purge Counter Appear" <li>Now press arrow up (^) again then choose "2&prime; press Set Button <li>Press Arrow Up (^) again then choose "7&prime; press Set Button <li>Press Arrow Up (^) again then choose "8&prime; press Set Button <li>Press Arrow Up (^) again then choose "3&prime; press Set Button <li>The purge counter will be reset to Zero. <li>Now Press Stop/Exit Button <li>You will return to Machine Error 46 <li>Press Arrow Up (^) then choose 9 press Set Button <li>Press Arrow Up (^) again then once more choose 9 press Set Button <li>Your Printer will reset then wait until it power up again. </li></ol>
on Mar 08, 2011 | Office Equipment & Supplies
I am getting the message "Ink System has failed. Unable to print. Refer to printer documentation. Error:0xc18a0001." I have tried to shut it down and back on and it's still not working -...
1. Get the unit into the "Support Menu" by following the steps below according with the product,
A. - Press and hold the "left arrow" key.
B. - Press the "Setup" key and release both keys.
C. - Press and release the "OK" button
2. Press and release the right arrow button until the display says "System Configuration Menu". (on C8100 use Touch Screen)
3. Press and release the "OK" button.
4. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
5. Press and release the "OK" button.
6. Display should say "Hardware failure status: Clear. Press OK to clear".
7. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
8. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
10. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
11. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
12. If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
14. If the error is still there, or reoccurs replace the unit.
VOTE ME IF YOU LIKE THIS SOLUTION
Aug 12, 2011 | HP PhotoSmart C5150 All-In-One InkJet...
Tip
How to Reset Ink Level Canon MX300 Cartridges
1. Switch off the Canon MX300 and disconnect the power cable.<br /> 2. While press and hold the power button, Connect the power cable to electric socket.<br /> 3. While pressing the power button, press the "Cancel/Stop" button (red button).<br /> 4. Now release the power button and the printer turns into a kind of factory mode. Wait for 10 seconds until it says "idle".<br /> 5. Press "&gt;" (next button) once "Shipping Mode 3&prime; then Press the "OK" button. Press "OK" again for "without cleaning".<br /> 6. A test page will print.<br /> 7. Open the cover, like you are about to change the cartridges.<br /> 8. Disconnect the power cable again without switch off the printer.<br /> 9. Take out the both cartridges.<br /> 10. Close the cover.<br /> 11. Connect the power cable and turn on the printer.<br /> 12. Now just put the cartridges back and the ink level in the canon Pixma MX300 have full again.
on Feb 17, 2011 | Canon MX300 Office All-In-One Printer
Tip
HP Photosmart C6180 Ink System Failure
<br /> Hi,<br /> <br /> <br /> Please perform the following steps and let me know the message that will be displayed on the printer.<br /> Press and hold the "*" key. <br /> Press the "#" key and release both keys. <br /> Display should say "Enter Special Key Combo" <br /> Press and release in sequence the "1", "2" and "3" buttons.<br /> Press and release the right arrow button until the display says "System Configuration Menu".<br /> Press and release the "OK" button.<br /> Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",<br /> Press and release the "OK" button.<br /> Display should say "Hardware failure status: Clear. Press OK to clear".<br /> Press and release the "OK" Button. Message changes to "Hardware failure status Press Cancel to continue".<br /> Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.<br /> Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.<br /> Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer<br /> Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.<br /> <br /> If I could be of further assistance, let me know. <br /> Thanks,<br /> <br /> LETMEFIXIT
on Feb 04, 2011 | HP Photosmart C6180 All-In-One InkJet...
I have i canon mp210 i got the black and colour ink cartridge refilled, but when i put them back in the black and colour light still stay on. i have held down the stop/start button for more then 5 seconds...
Things to try, unplug printer for a min of 10 mins.
clean the chip on front of cartridge with nail varnish remover very lightly though.
Reinstall the cartridge holding down the button for a min of 5 seconds.
If that dont work maybe one of the cartridges have failed it does happen from time to time.
I have my own remanufacturing business so know the market & technology fairly well.
Nov 06, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
How to stop test print on Xerox Phaser 6125N?
On the printer press the "Menu" button, then press the down arrow twice and select "Admin Menu" by pressing the "OK" button. Then press down once and select " System Setup". Press the up arrow once and select "Start Up Page". It will probably say "On" and have a * next to it. To turn it off, press down and select "Off" by pressing "OK" again. Make sure that the * shows next to "Off" on the display.
I had the same problem, hopefully this will fix it for you :)
Oct 20, 2008 | Office Equipment & Supplies
PixmaiP6700D:error#300. "The printer does not respond. Make sure that the printer is plugged in, powered on, and properly connected to your computer." I've checked all of the connections and...
Error Code300--
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Sep 05, 2008 | Canon PIXMA iP8500 InkJet Photo Printer
HP Designjet 110plus nr InkJet Printer Logo
81 people viewed this question
Seeker5211
Seeker5211
