Question about Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener
Garage sensor problem
My garage doesn close all the way down without holding the botton switch until it close the garage..the other sensor color is orange and the other is green i try to reposition the orange light color still it not change the color to green.pls give me some advice..thanks
  • bubbles10586 Dec 02, 2008
    I have the same problem and have tried repositioning the orange sensor, but still no luck.
  • 18 Answers
The colour on the sensors doesn't change.
One is orange constantly and the other is green when detecting a signal from the orange sensor.
If the green is flickering, they are not adjusted correctly.Move the green sensor until you get a good solid green. Holding the wall pad button down, just bypasses the sensors.
Try adjusting only the sensors so that they are solid.
In addition, check the little yellow light on the back of the machine and count the flashes.
The number of flashes will tell you what the error is in your manual.
Posted on Feb 13, 2009
Door goes down and when it stops at botton, it turns and goes back up ??? Need adjusting ..How can I adjust???
Adjust the position of the door by using the black and purple buttons. Black moves the door UP (open) and purple moves the door DOWN (close)
Setting the up position: 1. Press and hold the black button until the LED starts flashing slowly, then release. 2. Push and hold the black button until the door reaches the desired UP (open) position 3. Push the door control or programmed remote control. This sets the Up (open) position and begins closing the door. 4. Immediately when the door begins to close press and release the black or purple button. This will stop the door Setting the Down position: 5. Push and hold the purple button until the door reaches the desired DOWN (Closed) position. 6. Once the door is closed, If there appears to be too much pressure on the door, you may toggle the door back and forth using the black and purple buttons to reach the desired closed position. 7. Push the door control or programmed remote control. This sets the Down (closed) limit and the door should open.
Aug 11, 2011 | Chamberlain 3/4-HP Whisper Drive Plus...
Can open my garage door with the remote just fine, but it will not close the door. When I try to close it from the button inside the garage I have to hold it down until the door is all the way closed,...
Check your door sensors. Make sure they are pointed at one another and the small light on each one is lit and not flickering ever so slightly. Tweak them a little. If you cannot get both lights to come on you have bad sensors.
Jun 27, 2011 | Sears Craftsman LiftMaster Chamberlain...
The garage Remote control was working normally at first then for now reason now it just opens the garage door but doesn't close it. I checked the side sensors they look OK & clear, and I...
It could be the garage door motor that is acting up. Try closing it with the button in the garage. If that's not the case, you may need a different garage door opener.
Jun 06, 2011 | liftmaster Garage Door 1/2 Hp
The garage door will open with a single press of the button but will not close the same way. It will start to close - then reverse - unless I hold the botton down for the entire closing motion.
Check the door sensors. They must be pointed at one another and the small light on each one must be lit and not flickering. Tweak them if necessary. If you cannot get both lights to come on you have either bad sensors or the wiring to them.
Nov 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door won't close unless I hold down the wall button until it is fully closed. Checked the L.E.D light at motor and it flashes 2 times in about 8 seconds. Sensor with amber light is on, other does...
WHEN HOLDING IT DOWN MAKES THE DOOR CLOSE PROPERLY THE PROBLEM IS IN THE SAFETY EYES.
CHECK FOR A LOOSE OR BROKEN WIRE.
ARE THE EYES WIRED CORRECTLY?
ARE THEY AIMED AT EACH HOLDING DOWN THE WALL BUTTON OVERRIDES THE SAFETY EYES.
Oct 09, 2010 | liftmaster Chamberlain Garage Door Opener...
My two door garage was only not closing by remote was only closing by inside the garage with holding the botton till closed.i touched the side botton of the system now only make noise without opening or...
Sounds like your drive gear may be going bad. Remove the cover from the motor unit. It will be obvious if the gear is bad. Also check to make sure the sensors in the doorway are pointed at one another.
Oct 05, 2010 | Sears Craftsman LiftMaster Chamberlain...
I can open my garage door with the remote just fine, but it will not close the door. When I try to close it from the button inside the garage I have to hold it down until the door is all the way closed,...
Make sure your door sensors are pointed at one another and that the small light on each one is lit and not flickering. Tweak them a bit. If you cannot get both lights to come on you have either a bad sensor or the wiring to them.
Sep 07, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Opener /
door will not go down unless you hold down the inside botton.
Sep 14, 2008 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener Logo
1,366 people viewed this question
Top Chamberlain Car Audio & Video Experts
Iron
Iron
Are you a Chamberlain Car Audio and Video Expert? Answer questions, earn points and help others
