High efficiacy 90 furnane does not blow high heat; yet the fan motor blows but not hot heat.
    Scholar:
  • 104 Answers
If the furnace blows heat, just not hot enough, you need to have a furnace company come out and adjust the manifold gas pressure. (This is not something a homeowner can to, it takes special tools)
Posted on Jun 18, 2008
Why is my heat or air is not blowing and car is running hot
How hot is the engine running in degrees f? Does the radiator fan run?
With hvac turned on, check voltage and ground at the blower motor. If good voltage and ground, suspect the blower motor is faulty.
Jan 02, 2016 | 1992 Saturn SL
A/C stops working after the car warms up.
when last did you have your car fully serviced? small problames like yours can be solved in less than 2hours trust me you need someone to take a look at your car.
Sep 01, 2012 | 2000 Plymouth Breeze
Heater doesnt work
To troubleshoot this types of problem,click the link below :---
Car heater blowing warm, but not hot air?http://schematicsdiagram.blogspot.com/2011/12/car-heater-blowing-warm-but-not-hot-air.html
Engine Overheats and heater blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Heat blows cold on drivers side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
No heat on car? http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Heater blows intermittently and temp gauge goes erratic?
http://technoanswers.blogspot.com/2012/01/heater-blows-intermittently-and-temp.html
Heater blows cold?
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heater/AC blower motor not working?
http://technoanswers.blogspot.in/2012/02/heaterac-blower-motor-not-working-on.html
A/C, heater, defroster fan, not working? http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html Heater problem?
http://technoanswers.blogspot.in/2012/02/heater-problem-on-isuzu-trooper.html
This will help.Thanks.
Mar 27, 2012 | 1994 Volvo 960
My heater is not working except on one side in my 2007 impala driver side it blows warm passenger cold
To troubleshoot this types of problem,click the link below :----http://howtobyme.blogspot.in/2012/02/heater-blows-only-from-defrost.html
--------Go through the procedure to confirm the issue.
Heater blows intermittently and temp gauge goes erratic? http://technoanswers.blogspot.com/2012/01/heater-blows-intermittently-and-temp.html------------Heater blows cold? http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
---------Car heater blowing warm, but not hot air? http://schematicsdiagram.blogspot.com/2011/12/car-heater-blowing-warm-but-not-hot-air.html-------- Heater/AC blower motor not working?
A/C, heater, defroster fan, not working? http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html Heater problem? http://technoanswers.blogspot.in/2012/02/heater-problem-on-isuzu-trooper.html---------
Feb 27, 2012 | 2007 Chevrolet Impala LS Sedan New Cars
Heat or a/c blows only one speed /high only
90% of the time it is a faulty blower motor resistor. The sound when you turn off your HVAC is probably a squeaking from the blower motor fan or the pressure dissipating internally from the AC system. These are normal sounds.
Jan 05, 2012 | Cars & Trucks
Fan moves slowly ,compressor still hot even with a portable fan blowing on condensor ,but temps are back to normal. What would cause the fan to blow slowly and there is no obsructions
Ralph78yanks,
Your condenser fan (fan motor by compressor) is a variable speed and controlled by a computer board and compressor speed. If the fan motor slows down and the compressor is running in high, the unit can over heat and cause temperature issues in refrigerator sections. GE has a program which can see actual fan RPMs of motor. As I research this incomplete model number (7 possible different models) I see they all use the same fan motor Part# WR60X10209, this is a DC motor. Make sure you fan has not melted also. The heat from the compressor can melt the should or blade when this motor fails. I hope this information helps you..
Jul 11, 2011 | GE Profile PSW26P Stainless Steel Side by...
Heater problem, 2 left front vents on dash board are blowing ice cold air + right 2 vents are blowing hot air. is this a possible dial setting/button problem or actual haeater problem. heat was set @...
Most likly this van has seperate controls for driver and passenger heat and ac controls.If its blowing hot air your heat is working.These controls operate differant dampers that are electonicly controlled.If the dials arent working they would cause this problem.
Feb 12, 2011 | 2004 Ford Freestar
My fan fuse blows when it gets hot
About the only thing that would cause the fan fuse to blow is either the fan has a problem and is dragging or a short in the wiring. I would bet the fan motor is probably bad. The hoses and thermostat have nothing to do with the fan motor fuse blowing.
Jul 29, 2009 | 1993 Acura Legend
2001 Town and Country has only high speed fan both front and back fans. Connector to fan has 12v only on one of the 6 leads. Grounding the lead with the 12v on it turns fan on high speed. Where is...
if the blower only blows on high then it is you blower motor resistor that is located behind the glove box it has two screws that hold it in place
Jun 19, 2009 | 2001 Chrysler Town & Country
Heating & Cooling Logo
101 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
