Question about Estate Washing Machines
I have just bought a used, 6 year old, Estate washing machine. I have it all hooked up in my apartment and have already had to troubleshoot many problems, namely it flooding my laundry room. Now, I can't get the water that is in it to drain at all. It has been sitting in the machine for almost 24 hours now. I have tried all different settings and cycles, and they all stop after agitating and it just sits there. I am close to calling someone to come look at it, but I thought I would try this first to hopefully save some money.
  • Estate Master
  • 8,220 Answers
Ok I suspect you have a broken lid switch. I have just bought a - themobilian_122.jpgSwing up the controls and first check the water level switch for: pinch tubing. tubing not connected, blow out the sediment in the tubing from when you moved the machine. Make sure that tubing is tight on the switchNext check the lid switch connectionthemobilian_124.jpgLook for it to be plugged into the lid switch on the case of the washer. In my hand there is 3 wires to that switch 2 hot wires and one green ground wire. Jump them 2 hot wires and see if it will spin or pump out. How to swap out that lid switch:
I have more vdeos of common repairs on this nice machine HERE
Posted on Nov 12, 2010
I have a Estate Machine. Washer seems to agitate ok but will not spin dry with a full load with out a little help. checked coupling and it is fine.
Some models a few years old had bad bushings in the
super structure post
They scored up the spin tube
Look into a new washer at this point
Jul 04, 2017 | Estate Washing Machines
How do you clean the estate heavy duty 8 cycle 2 speed washing machine
You stop using the disgusting liquid detergent that is causing the stench, first off, switch to Powdered Detergent, then leave the lid up when you aren't using the machine. 6 months from now it will be fine, otherwise, you can disassemble the washtubs and scrape the liquid detergent residue of everything with a putty knife... Option 1 is better, trust me.
May 02, 2016 | Estate Washing Machines
I am trying to replace the agitator dogs on a Whirlpool Estate washing machine. I haveremoved the agitator assembly and am trying to take it apart. How do you get the agitator assembly apart when it...
NOT SURE HOW URS WORKS BUT SOME DO NOT REMOVE FROM THE TOP OR MIDDLE BUT INSTEAD HAVE A COUPLER ASSEMBLY AT THE BOTTOM THAT REPLACES THE CAM DOGS FUNCTION SEE PICS
May 08, 2014 | Estate TAWS850PQ
Bush WM-1260TVEME wash on a cotton wash when i heard noises that sounded like a firework been lit i turned round and orange sparks were coming out of top of display panel.i havent used it since this as...
first unplug the machine if you haven't already-if your machine is less than a year old you should be under warranty-call the company that you bought it from-cheers Denny
Oct 22, 2013 | Washing Machines
Delicate cycle fills with water but will not agitate
Timer needs cleaning on the delicate relays (points) in the delicate position. Maybe timer failure. Transmission stuck, jammed or failing in that wash mode
Sep 21, 2012 | Estate Washing Machines
15yr old Whirlpool Estate does not stop filling
umm well it is 15 years old so maybe its just ready to go. get a new washer machine.
Feb 10, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
GE commercial washer wont spin or drain
If your washing machine is 20+ appliance years old, it's probably due for replacement.
Jul 15, 2017 | GE WNRD2050DWC 3.5 Cu. Ft. Commercial...
Washing machine won't spin until open and reclosed the lid
sounds like transmission not resetting for spin properly replace transmission
Nov 20, 2008 | Estate ETW4100SQ Top Load Washer
HELP PLEASE
you need to check the pump you may have something stuck inside look there first
Mar 28, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Wash Machine Drainage problem
i am a recently retired appliance engineer of 20 years, slowing down the flow of water from any electrical washing appliances can be dangerous and will cause extensive damage to the appliance in question, at the very least it will stop half way through the cycle every time the only way to remedy this is to rectify the drain, or at least sort out another waste water outlet sorry
Sep 21, 2007 | Estate TAWB600JQ Top Load Washer
Washing Machines Logo
61 people viewed this question
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
