Question about Rockford Fosgate Punch 800a4 Car Audio Amplifier
Bridging 800a4 what is the rms rating if i bridge 800a4 to run a 12-inch sub in a lincoln navigator
  • 109 Answers
That all depends upon whether or not the sub you are running has dual voice coils or just a single voice coil. The 800a4 is a four channel amp; thus the only way you can bridge it will be 3 channel or 2 channel. If you are running a dual voice coil sub then you can wire the amp two channel and get 400 watts x 2 @ 4 ohms. Make sure that you sub can handle this kind of power though.
Here are the specs:
4 x 100 @ 4 ohms (13.8V - <0.05% THD)
4 x 200 @ 2 ohms (13.8V - <0.10% THD)
2 x 400 @ 4 ohms bridged (13.8V - <0.10% THD)
Fuse: External 60A
Manufactured in 1999 - 2001
Posted on Jun 19, 2008
I have Sony xm-2165gtx amp 165 watt rms x 2 at 4 ohm 200 watt x 2 at 2 ohm 400 watt x 1 bridge output at 4 ohm stereo or bridge mono output 4 ohm stable in bridge mode this mean can't go lower then 4 ohm...
You can't bridge that amp onto a load lower than 4 ohms. So you can't bridge that amp onto two 4 ohm subs. To get the most power out of your subs is easy. Run one channel to one sub and the other channel to the other sub. 165 watts RMS is plenty for most subs.
Dec 05, 2013 | Car Audio & Video
Hifonics colossus-ltd dual monoblock amp does not have much output, running a cerwin vega stroker dual 2 ohm sub wired 4 ohm load bridged
Bridge at 4ohms your only getting 600watts rms. You will need to bridge at 1ohm (parallel) and adjust the gain accordingly. This will give it 1600 watts rms. If you would of had a dual 4ohm sub, then you could of bridged it at 2ohms mono, but you can't you have to go either 1 ohm or 4ohm. I believe it's not getting enough power.
May 20, 2012 | Hifonics Colossus-ltd Dual Monoblock 3200w...
Want to run 2 subs of 1 amp ep 4,000 in bridge mode.
You can do that but your subs will have to be monsters or you will blow them out as bridged mode will drive 2400 watts RMS into 4 ohms. Many speakers are rated in peak or program power... these are FAKE specifications. with this amp in bridged mode each of two identical speakers would have to be rated at 2400 watts program or about 3600 watts peak each to survive... When rating speakers and amps ALWAYS compare RMS values... and for safety use an amp of 80% of the RMS rating of the connected speaker or speaker system.
Aug 28, 2011 | Behringer EUROPOWER EP4000 4,000-Watt...
I Have a Sony Xplod 800 watt amp and 2 12 inch Sony Xplod subs
You should definately bridge them. Firstly, lay the 2 speakers face down next to each other. Note the connections +- +-. The first + will go to the amplifier. The next terminal(-) will be connected to the next speaker(+). Take the last(-) and connect to amplifier. Please note that your amplifier has a bridge section which is normally the first + and the last- on the two channels. Connect your woofers on the bridge.
May 28, 2010 | Sony XM-ZR1252 Car Audio Amplifier
What size amp do i need to run 4 1000 watt pyle 10's bridged
well first of all you cant bridge subs... you can bridge an amp... and for 2 they are probablly not 1000 watts, make sure you understand RMS and what the sub can ACTUALLY HANDLE properly... i would get a 1000 to 1500 watt RMS that is RMS RMS RMS RMS amp not one that says 2000 watts MAX POWER cuz thats cheap ****... get a kicker JL hifonic alpine or something in that category that actually tells you the TRUE power output of the amp... then run those 4 subs in a parallel circuit so its like really only having 2 subs. make sure then these subs do not run less then 2 ohms at the terminals while in a parallel, then bridge these subs acting as 2 subs not 4 to your TRUE 1000 watt amp and you should have a good powerful system
Mar 19, 2010 | Pyle 10'' Subwoofer Tube w/Amplifier Car...
Can i run just 2 subs on this 1200 watt kenwood 5-4-3 and if so what way will i get the most power, i mean do i bridge it or pute the speaker wires in other ports
you can run 2 subs given that you dont go over 2 ohms of resistance and that the subs are rated at 1000 watt max each around 4 or 500 watt rms. if your not sure about ohms dont bridge it and get single voice coil subs. this amp is capable of about 700watts constant power 1200 max spike if the voltage stays at 12 or higher.
Feb 05, 2010 | Kenwood KAC-X650D Car Audio Amplifier
What kind amp should be use for ts-w307d2 subwoofer speaker?
Nice sub, i have 2 308d4s in my car. Okay this sub is a dual coil 2 ohm. so to get best bang for your buck you'll want a 2 channel amp and bridge it. Your sub is 400 watts RMS, So you'll want an amp that has the same rating. I'd recommend the pioneer GM-5400t. Then wire your voice coils in parallel, and bridge your amp, you'll get 380 watts RMS, which is perfect for this sub. If you have questions on wiring or anything you can just ask. thanks, i hope this helps
Oct 20, 2009 | Pioneer TS-W307D2 12" 1200 Watt Champion...
Rockford Punch HE2 wiring question.
if your sub will handle it, bridging it will give you more power. The best thing to do is to find out how much power the amp puts out ( RMS ) and if it is in your power handling range bridge it. It sounds better and gives you a harder punch because of more power.
Feb 05, 2009 | Rockford Fosgate HE2 RFP4212 Car Subwoofer
Subwoofers
This will depend on the amplifiers capabilities.
I will give 2 different scenarios.
#1 Stereo configuration
If the amplifier supports an RMS power output close to the RMS input power of the subwoofers then run the amplifier in stereo mode. For example 150 watts RMS X 4 channels driven at 20-20khz. (If you can provide a model # for the subs and the amp your looking at I can help you further with this decision.
Wiring for this is easy and simply involves matching the connectors for 2 of the channels (Front or Rear) to each of the subwoofers.
#2 Mono Bridged mode.
If the amplifier is lower power but mono bridgable you can bridge two Pairs of channels and power each of the subwoofers this way.
Generally speaking a 2 channel bridgable amplifier will be able to at least combine the wattage of each channel into a single monural channel and in many cases its actually higher.
So you would bridge the front 2 channels into a single bridged mode for one subwoofer. and then you could bridge the read 2 channels into another bridged mono channel for your other sub woofer.
For example if you had bridgable amplifier thats 50 watts RMS X 4 you coudl very likely (Generalization based on quality of amplifier) send 150 watts RMS to each subwoofer.
Again I would need to know what amp you're refering to to provide specific wiring instructions. Many Bridging amplifiers either have a single switch that will send them to bridged mode or you would use the positive + terminal from one channel and the negative - terminal from the other channel or a combination of both.
Sep 17, 2008 | Kenwood 12" 4-Ohm Single-Voice-Coil...
Amp getting really hot
well it is getting hot due to the amp drawing and pushing alot of current. try getting lower gage wiring for power to the amp and lower gage speaker wire.
Apr 20, 2008 | Power Acoustik PS2-1200 Car Audio...
Car Audio & Video Logo
758 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
