Question about Motorola Talkabout T5420 (14 Channels) 2-Way Radio
Is the T5420 compatible with the T5000? - Motorola Talkabout T5420 (14 Channels) 2-Way Radio
  • Motorola Master
  • 1,654 Answers
Yes. Both should utilize the same 14 or so FRS and GMRS frequencies. The only exception would be if one of them were a model produced for another country. While this is rare, it is worthy of asking.
Best regards.
Posted on Nov 12, 2010
How do I get the Motorola T5000 and Boafeng UV-8D radios to communicate with each other?
check you settings in the radio,follow your instruction manual for the radio
Jun 11, 2015 | Motorola TalkAbout T5000 2-Way Radio
Frequency range motorola t5000
http://shop.giantintl.com/Manuals.asp?offset=30
Sep 28, 2013 | Motorola TalkAbout T5000 2-Way Radio
I hunt in a remote area. Will the t5000
If your farm radios are FM UHF radios, it is possible they could communicate if programmed to match one another. You would need to limit your wattage on the farm radios to 1/2 watt on the FRS (family radio service) channels, which are in the T5000.
Your T5000 will NOT match CB (citizen band radios).
Best regards.
Feb 28, 2010 | Motorola T5000 Two Pack 2-Way Radios with...
Rx not working
You need to check the programming of your Frequency, interference Code eliminator and Qt filter, if any. All must match one another for the radios to communicate. You have posted under the T5000 heading, here is a link to the nearest numbered user guide. http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T5XxX_User_Manual_E.pdf
Best regards.
Nov 30, 2009 | Motorola T5000 Two Pack 2-Way Radios with...
T5420 unable to transmit or receive. Please help!
Here is a link to the user manual: http://www.giantintl.com/ContentManage/manuals/Moto/T5320_T5410_T5420_User_Manual_E.pdf
This unit does not have a reset button. While troubleshooting you might check the batteries. Be certain they are in correctly and the contacts are free of corrosion. You can use a pencil eraser to clean the contacts.
Walk through all the programming instructions in the manual, double checking both the frequency and interference eliminator codes. A quick setting back to zero on the code would alleviate any problem with that section of the radio.
As far as your "paging" this operates on the same frequency and code as the rest of the radio. If the radios are not working correctly in this relm, the paging will not work either.
Apr 24, 2009 | Motorola TalkAbout T5000 2-Way Radio
Can't make the T5420 operate without the beeps!
I have not looked up the T5420 user guide, however, on most Motorola TalkAbouts you hold in the minus (-) button while turning the radio on. Post back if this doesn't work, and we'll find the manual for you.
Nov 17, 2008 | Motorola Talkabout T5420 (14 Channels)...
Here is a link to the T5000-T5500 user manual. 'http://www.motorola.com/mdirect/manuals/T50-T55_UserGuide.pdf'
From what you have stated, I can discern the radios will power up. You might try setting your interference eliminators to zero (off) to see if you are able to transmit at all.
You do not mention if you are using AA batteries or rechargeables. Either way a fresh set of charged batteries would be best for a test. It is clear you were getting power. However, it does take more energy to transmit than to receive. If your batteries are low or bad, pressing the PTT could us all the energy the radio has, and yet not transmit to the other units.
You might also check you VOX settings if any and be certain they are turned off.
It is not likely 4 radios would fail all at the same time. So it is probably a programming problem. Hope the user manual helps you find the solution.
Aug 23, 2008 | Motorola Talkabout T5420 (14 Channels)...
Motorola t5000 charger polarity
The Polarity of Motorola's equipment is always Center Positive.
Pat
Aug 13, 2008 | Motorola T5000 Two Pack 2-Way Radios with...
Motorola T5000 Rx problem
Hi SirDrag,
Your concern could be the internal speaker of the T5000. This could be verified by attaching an external speaker or a headset compatible with the unit through its accessory jack. Should this be the case, it of course would require replacement. Though Motorola speaker for this model is proprietary in design, those made for Alinco, Icom, Kenwood and/or Yaesu should also work. The only concern would be getting one that will fit the physical mounting limitations of the front cover.
In some instances, it could be the volume control developing blind spots along its carbon pad. A spray from an electronic contact cleaner should do the job (albeit temporary).
It is also possible that the Interference Eliminator Code setting is different with that of the TX radio.
Worst case possibility is a defective electronic component (such as the op amp) which would then require the professional services of a qualified communications technician.
Hope that this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 14, 2008 | Motorola T5000 Two Pack 2-Way Radios with...
Motorola Talkabout T5420 (14 Channels) 2-Way Radio Logo
76 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
bill tarkulich
Level 1 Expert
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
