Question about Husqvarna Garden
125b leaf blower started first time has not started since
    Brigadier General:
  • 4,088 Answers
Remove the spark plug and test for spark which should be blue and snappy. If weak or nothing, try a fresh plug gapped at 0.020". If still nothing and the warranty is still in effect, take the blower back for repair or replacement. Hope this helps!
Posted on Nov 12, 2010
Husqvarna 125b won't prime and run unless upside down. If turned right side up it dies. If I prime it when it's right side up it blows bubbles in the tank.
Try a new gas cap. There needs to be air behind the liquid in a vacuum (think plumbing) or it does not flow. Make sure you've replaced all the cracked lines. Allowing air into the vacuum will also stop the flow. It's one of these.
Sep 13, 2014 | Husqvarna 125B 28CC Gas Leaf Blower...
What screw is L & H on husqvarna leaf blower 125b ?
unit is running lean. The lo is closest to the crankcase. Give the lo a half turn out.
Aug 31, 2014 | Husqvarna 28cc Hand Held Blower HVH 125B
Husqvarna 125b leaf blower
Have you checked the Flame Arrester in the Muffler. They clog easy and engine can't push out exhaust.
Nov 23, 2013 | Husqvarna 28cc Hand Held Blower HVH 125B
Starts fine, run fine,for about 2 to 5 min.,then cuts off,sounds like it's not getting the gas.
I have a Husqvarna 125B same problem. Turned out to be a bad gas cap. Doesn't vent properly and starves the engine. I took the gas cap off of my Huqvarna weed eater and put on blower and blower worked fine,
Nov 11, 2012 | Husqvarna 28cc Hand Held Blower HVH 125B
Required fuel oil mix
Two-stroke oil with a 50:1 (Gas:Oil) mix ratio is required for the Husqvarna 125B leaf blower. Using the wrong oil or improper mixture ratio can drastically affect the performance of the leaf blower.
Nov 02, 2012 | Husqvarna Hand Held Blower 125 B Grass...
How do I get the spring back in my Huaqvarna 125b blower?
you have to wind the spring back in, one coil at a time , its not too easy i would say the best thing is to order a new spring, this will come in a keeper so makes fitting easy.
May 26, 2012 | Husqvarna 28cc Hand Held Blower HVH 125B
Have a husqvarna 125b have spark and fuel wont start done every thing i know new plug rebuilt carb gaped coil im tired of pull on it any answers please help it
the rule of thumb is spark, fuel, compression. I found I gad a plugged air filter. It would not start until I removed it and tried to start.
May 07, 2012 | Husqvarna 28cc Hand Held Blower HVH 125B
Husqvarna model 125b Hand held blower (Gas) No
If you have tried a new spark plug and you still have no spark, then your Ignition Coil, (Module) has gone bad. They aren't cheap if you buy it new. Try to find a used one if you can for around $10.
Good Luck!
Jim
Aug 02, 2011 | Husqvarna Hand Held Blower 125 B Grass...
I am attempting to remove the vac door cover on a Husqvarna 125B leaf blower. I can see it is hinged and appears to have a catch on the other side of the cover. Problem is that I have tried wedging out...
Hey dumont411........ did you ever get the screen cover off your Husqvarna 125B. I'm having the same problem.
Please email me directly at mrc.engr@verizon.net and not this stupid site.
Thanks !!
Mike Cecchini
Bethesda, Maryland
Oct 23, 2010 | Husqvarna 28cc Hand Held Blower HVH 125B
Garden Logo
102 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
