WASHING MACHINE WILL NOT AGITATE ALREADY REPLACED AGITATOR COUPLER CHECKED BELT TENSION
  • 3,051 Answers
Hello there:
There are several reasons why a machine will not agitate I understand that you have checked a couple of them
I will provide you with the rest of the things that need to be checked so please carefully check each one of these ok?
f your washer doesn't agitate, check these: Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it. Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
I will post the rest in a seperate comment
Posted on Nov 12, 2010
  • Michael Thomas
    Michael Thomas Nov 12, 2010
    Transmission
    The transmission could have either of these problems:
    Older
    washers produced by Whirlpool® have a transmission with an
    electro-mechanical shifter. If the shifter becomes even partially
    defective, the unit may not agitate properly or at all.
    The transmission may have a worn or broken gear, or some other internal problem.
    If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
    Agitator
    The
    inside of the agitator--where the transmission shaft attaches--can
    become worn, and strip out the spline that allows the agitator to
    properly grip the shaft. Then the transmission shaft rotates back and
    forth as it should, but the agitator doesn't move properly. If this
    happens, you may need to replace the agitator and/or the transmission
    spline.
Agitate
It doesn't agitate If your washer doesn't agitate, check these: Lid switch Motor coupler Belts Clutch Drive motor Drive pulleys Transmission Agitator Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it. Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Feb 06, 2010 | Washing Machines
Will not wash after catches water,all i hear is a buzzing sound
Jan 22, 2010 | Kenmore Washing Machines
Hotpoint 9533 the wash machine dosen't wash
It doesn't agitate If your washer doesn't agitate, check these: Lid switch Motor coupler Belts Clutch Drive motor Drive pulleys Transmission Agitator Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it. Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. Drive pulleys
Jan 17, 2010 | Washing Machines
Kenmore Model 110-24632300 filled up with water and now will not agitate or drain.
Jan 03, 2010 | Kenmore 22642 Top Load Washer
Washing machine fills with water and will not go to next cycle
Jan 03, 2010 | Whirlpool Washing Machines
My wilkins servis washing machine will not wash cycle
It doesn't agitate If your washer doesn't agitate, check these: Lid switch Motor coupler Belts Clutch Drive motor Drive pulleys Transmission Agitator Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it. Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Jan 03, 2010 | Washing Machines
Washer will fill and spin but will not agitate ge top load washer wwsr3130w0ww
Jan 02, 2010 | GE WBSR3140DW Top Load Washer
GE Profile , when door closes comes on , but does not appear that agitator is moving.
Jan 01, 2010 | GE Profile WPRE6100G Top Load Washer
The agitator in my kenmore elite washer won't agitate. The water won't spin out. The basket turns, and we've had the clutch replaced. Any suggestions?
Jan 01, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Agitator not moving
Following are the main reasons for the agitator not to move.
Lid switch
Motor coupler
Belts
Agitator
The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
Thanks for contacting Fixya.
Oct 12, 2009 | Kenmore 22422 Top Load Washer
Washing Machines Logo
169 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
