Question about Dell OptiPlex GX270 PC Desktop
The system lights up and goes right back off.
  • 1,179 Answers
Ahh, yes don't worry, I am here, you can find the solution in my tip entitled My Computer is not turning on!!! Is it dead!!! No POST!!! I would put this problem down to a shot circuit, dust that has gathered moisture.
Thanks
damnor01
Posted on Nov 12, 2010
When braking, dash panel acts up. Speedometer goes to 0 and then back to normal. Clock and Radio lights dims and comes back, or goes out completely, comes back on after a minute.
Make sure the battery has a full charge and all connections good. Then check your charging system. Right now I'm thinking, check your charging system.
Do you have a voltmeter on your dash, what does it do when you step on the brake? It may drop a little, but, it should recover.
Nov 29, 2015 | 1996 Saturn SL
Dodge grand caravan when I turn my right turn signal on its normal then it will flash on the left side 3 times then it goes back to the right normal then the left side will flash 3 times again then it goes...
make sure each of the light bulbs on all signal lights, park lights, running lights, brake lights.
if they do --
pull the flasher relays and replace them.
Dec 17, 2014 | Dodge Grand Caravan Cars & Trucks
My light problem is i have low beam on right side no low on left side i turn highs on and right side goes out and high on left turns on then when back to lows beams and i pull turn signal to flash high...
If you have separate bulbs for the low and high beams(4 light system), if you pull the turn signal and hold it, all 4 lights will stay on until you release the turn signal. You need to replace the bright bulb on the right side and the low bulb on the left side. If your headlights only have one bulb on each side, then you will have to replace both of them to get everything to work.
Jan 04, 2011 | 2000 Ford Mustang
Temp guage fluctuates down to bottom when 'theft system' light comes on (flashes every second or two) and then goes back up when light goes out. 'Check guages' light flashes on right after theft system...
the instrument cluster is probly failin-can happen with age or if u spiked it by puttin a new battery in car-these things are really sensitive to voltage swings--may also be a wiring issue too--get car scanned at a discount place and buy a haynes manual
Dec 14, 2010 | 1991 Chevrolet Cavalier
Red light flashing
With the older FAT PS3, if you turn off the system from the main switch in the back then back ON. The red light should stop flashing. But if you do this and Power On again. Watch the color of the light. If it goes from red to yellow then flashing red light. Then this is the YLOD = Yellow Light Of Death. This can only be fixed by shipping it back to Sony ($150.00) or void the warranty and take the system apart to reflow the motherboard. There are guides on Youtube if you have the right tools. I have done the reflow many of times.
Oct 30, 2010 | Sony Playstation 3 (PS3) Console
Somehow my wiring system in the front passenger floorbaord is getting wet and now the brake lights arent working. Which wire do i look for to correct this problem?
The wire is white and starts at the switch on the break peddle and goes in the body harness on the driver side of the van and goes all the way to the back where it splits for the top break light and both break lights in the back.
If you are not getting any voltage in the back I would check right at the break peddle switch and go from there. Good luck
Oct 13, 2009 | 1999 Pontiac Montana
PS3 stops right before the menu comes up.
This would be due to a hardware failure would suggest you bring it into one of sony's autherised repair centers to get it fixed.
Sep 29, 2009 | Sony Playstation 3 (PS3) Console
Anti- thief system keeps car from starting.
try locking and unlocking using key cylinder in driver's door
Jan 13, 2009 | 1995-1997 Chevy 1500 Truck Ignition...
Dell OptiPlex GX270 PC Desktop Logo
29 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
