Question about Vacuums
I am installing 2 separate lights on the overhead section of my granddaughters wall unit. On the side of the wall unit I am going to install a wall switch to turn on/off the overhead lights. My questions are 1a . For the wall switch, I believe I cut the BLACK wire and attach the 2 ends to the lite switch, & NOT cut the WHITE wire,which will continue onto the 1 st lite.. 1b. Do I cut the bare copper GROUND wire & attach the 2 ends to the lite switch OR not cut it and run it straight to the 1st lite? 2. How do I wire the 2 separate lights? I'm using Romex type NB-2, 14/2 w/ground. rated 600 Volts indoor wire. Also Wiremold NMW2-S lite switch, and a heavy duty 3 prong plug recommended by an electrical supply company for this type of wire. The wiring will be covered with Wiremold NMW1Channel conduit (plastic). Your specific help in wiring will be greatly appreciated. She's my Grand daughter, I do NOT want to screw this up. Thanks Gary Winslow
  • 2 more comments
  • Gary Winslow Nov 15, 2010
    Thank all of you for your very helpful recommendations. I will sleep much better knowing how to wire the switch & lights.
    Thanks again, Gary
    To: joecoolvette; Thank you for your excellent description on wiring the lite switch
  • Gary Winslow Nov 16, 2010
    joecoolvette: As I was attaching the wires as you recommended, when I realized I still didn't know if I should connect the GROUND wire to the lite switchand then onto the 1st lite or bypass it like the WHITE wire, and go directly to the 1st lite. I'm also assuming I connect the GROUND wire to the 1st lite(GREEN screw) then a jumper to the 2nd lite (GREEN screw) . Thanks, Gary.
    Thanks again. You have a way of explaining wiring that even I can understand.. Again 100% Have a Blessed day. Gary Winslow
  • Vacuums Master
  • 5,660 Answers
1) The Black (HOT) wire always goes to the switch. From the other screw of the switch it goes to the first light.
Then a jumper wire (Black so you can keep track), goes from the first lights Black wire, or gold screw, to the Black wire, or gold screw of the second light.
The white Common wire in the Romex cable goes past the light switch, to the first light. A jumper wire (White in color so you can keep track), comes from the first light to the second light.
Only the Black (HOT) wires are switched.
Have additional questions regarding this, please post in a Comment.
Regards,
joecoolvette
Posted on Nov 12, 2010
  • 2 more comments
  • joecoolvette
    joecoolvette Nov 13, 2010
    The wide blade on the heavy duty three prong plug, (If it has one), is for the Hot wire. The Black wire.
    The round pin on the heavy duty three prong plug is for the Ground wire. The bare copper wire is the Ground wire. If you see a Green screw on the light fixtures, this is where the bare copper Ground attaches to. When attaching solid wires together, such as in the Romex NM-B cable. (Non-Metallic Sheathed) So we have Black wire coming to light switch. From light switch to gold screw on first light fixture. Then from gold screw on first light fixture to gold screw on second light fixture. White wire goes past light switch connects to silver screw on first light. Then from silver screw on first light to silver screw on second light. Black is always the 'HOT' wire. White is always the Common wire. Bare copper is always the Ground. A switch always goes in the Black/Hot wire. NEVER in the White/Common wire.
  • joecoolvette
    "When attaching solid wires together, such as in the Romex NM-B cable. (Non-Metallic Sheathed), strip approximately 3/.4 inch insulation off of the wire. Lay the two stripped ends together of two wires, and use your Electrician's pliers to twist the two together. Then the wire nut goes on. Make SURE the wire nut is on tight, then apply a couple wraps of black plastic electrical tape. Apply the tape around the middle of the wire nut, wrap around the bottom, catching the wire also."
  • joecoolvette
    joecoolvette Nov 16, 2010
    My apologizes for getting back to you so late. YES, connect the bare wire ground to the light switches Green ground screw. The source Romex wire feeding up to the light switch, will be twisted together with the bare copper wire leading to the first light. One bare copper wire will be twisted onto the other bare copper wire, so that there is a 1 inch, or so, lead left. This part is looped around the Green ground screw. Correct, the 1st light will have a bare copper jumper to the second light. I Appreciate the kind words, and you rating! I am most humble. joecoolvette
  • joecoolvette
    You = Your (Sheesh!)
I installed the Hoover Wind Tunnel Central Vac in my new home. After connecting the wall outlets and successfully turning on the system from the hose control, I discovered there is lots of air flow t
I would recommend checking your wall outlets where the hose plugs in for any type of clog in the tubing. If the vacuum itself has great suction but when you go to the wall outlets that is probably something in the hose that is stuck. If cleared it will most likely have excellent suction throughout the entire system in the house.
Jul 21, 2012 | Vacuums
My home has a central vacuum system hook-up but no vacuum installed. My friend upgraded his central system and gave me his Eureka Mega Boss central vacuum system and the accessories, including the pow
The power head requires 120 Volts. Some hoses have a receptacle in the handle for the power head plug, and the hose has a cord at the wall inlet end that plugs into a receptacle. Some hoses have a plug at the wall inlet end that plugs into a 120Volt receptacle built into the inlet. The hose plugs into this receptacle when you push the hose into the inlet. The power for this built-in receptacle is wired with line voltage when the system is installed.
Apr 15, 2012 | Eureka 1810 Central System Vacuum
I am in ecuador and have had a local "plumber" install a lpg tankless water heater for me. After more difficulty than there should have been it's up on the wall with the water and gas lines attached but it...
The system is ignited by turning on a hot water faucet causing water to flow through the unit activating the igniter.You could disconnect the gas line at the unit turn the valve on and off real quick and smell for gas.If there is air in the line you may have to let it run or purge the line just long enough to make sure gas and not air is comming out.You might want to have utility company do this if you have any worries .I would make sure it is set up for lpg and not natural gas. And then and this is quite often the problem the gas line feeding the unit should be at least 3/4 inch pipe and fairly close to the main supply and in no instance the last fixture in system unless the pipe sizing is adequate for the amount of gas the unit needs to run.If sizing is the problem sometimes rather than running new pipes your utility company might be able to adjust the pressure comming out of the tank to make up for it. Hope this helps good luck
Jun 22, 2010 | Vacuums
The CV750 stopped working. It will come on sometimes but most of time it will not work. I installed new bag and cleaned filter. Green light on side of unit is on. Switch on side of unit will not make it...
The motor may have a sticking brush or a dead commutator segment. Turn off power to the unit to check for sticking brushes. Reapply power, does it now run? If not, shut it off, physically turn the motor a few degrees, and reapply power. If it still doesn't run, look for loose wiring around the motor. If it does run, replace the motor armature or the entire motor if the armature is not available as a separate part.
Oct 18, 2009 | Broan-NuTone CV750 Central Vacuum
Replace power switch - Electrolux Epic series 6500
well, i post an answer in the wrong field, and i can't find it, so i will type one more time.
slide two vinyl side pieces off, and remove top halves. remove two screws from the switch, and remove it from top halve. between switch and outside button is a plastic rocker, which is broken. you will find two broken pieces, one spring for the rocker piece, and one small plastic rod, which goes inside of the spring for support. i do not know if part is available, but you can for quick fix like me, turn the switch on by the hand, assemble unit, and plug in, and plug out from the wall. whay? i dont have electrolux store close by.
john
Feb 21, 2009 | Electrolux Epic 6500 Vacuum
No suction in the walls for our Beam Heavy Duty Vacuum.
Do you have any open valves? Sometimes when vacpans are installed they are left open. Check those and then the other inlets to make sure they are not open.
Also, if this unit is not newly installed, then you need to check for blockages. If the motor in the garage is winding up and running faster/harder than usual, then there is likely a blockage between the main unit and the inlet nearest the unit.
Dec 08, 2008 | Vacuums
Install self propelled belt
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=647063
Generic problem for all Vacuums
Posted by wmtp on Jun 04, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Usually the self propelled vacuum have 2 belts and you should replace them both 2 the same time 1st the self propelled belt and then the brushroll belt. Normally you would hook the belt on the pulley side of the brushroll or self propelled unit and then stretch the belt onto the motor pulley side of the motor using a belt puller or a screwdriver with a bend on the end for pulling and or stretching either belt onto the motor pulley. If you have a problem please feel free to contact your local vacuum cleaner dealer.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 04, 2008 | Vacuums
Changing the filter in Rainbow e series
Some of the e-series has a corrugated filter in the top section. To get to it, remove the clear plastic panels that are the sides. Most have 3 screws on each side to move, then the top half will come loose. There also is filter on the back, there is a door to remove to get to it.
Jun 03, 2008 | Rainbow 75th Anniversary Canister Vacuum
How do I change the fan on my model 2HD kirby
How do I change the
posted by Rogor on Apr 18, 2008
How do I change the fan on my model 2HD Kirby
1st you need to remove the head with the revolving brushing by dialing off the belt and undo the Kirby lock @ the top o the bell housing. Remove the head and that will expose the fan and the fan housing. The fan housing is held on by a couple of screws and once you removed the screws then you need to separate the fan housing from the motor section, it is held on by a Kirby fan housing sealer that is clear – so try to separate the fan housing with a knife or screwdriver, once the fan housing is off the Kirby fan is screwed on I believe either clockwise or counter clockwise and un-screw the fan and follow the reverse situation on installing the fan but you need to use the clear Kirby Fan Housing Sealer to re-seal the fan housing and let it dry and wipe of the excess clear sealer before putting it back together again. Always remember on the Kirby vacuums – use genuine Kirby parts on the repairs, it does make a difference. Then go back and place the Kirby head back on the vacuum – lock it on place and then re-dial the belt onto the Kirby fan shaft, plug your vacuum in the wall outlet and test run the vacuum.
http://kirby.com Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
www.A-1Vacuum.com 1-800-657-1874
Apr 18, 2008 | Vacuums
Vacuums Logo
41 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
