Question about RELIANCE ELECTRIC WATER HEATER
Where do I find the hot water control on a reliance 501 electric water heater?
    Genius:
  • 1,015 Answers
You will find thermostat and limit switchs behind removable cover plates on front of heater. Remove four screws to remove covers. You will need to slightly part insulation inside to se thermostat. They are adjustable using ablade scredriver,Usually from 90-140 degrees. Temperature setting is set by turning screw which moves arrow pointer to desired setting. Be careful of touching any of the power wires. Hope this helps. Thanks
Posted on Nov 12, 2010
Reliance 501 Hot Water Heating element for 30 gal tank, where to purchase
You do not need special parts.
Wattage is printed on end of each element.
Buy generic elements at hardware store.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
Apr 21, 2012 | RELIANCE ELECTRIC WATER HEATER
Reliance 501 water heater and I cant find a way to turn it DOWN ..the water is scalding
Replace both thermostats and test both elements.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.htmlhttp://waterheatertimer.org/How-to-test-water-heater-element.html
Power is off while doing these repairs.
If water is hot, then you know that electric line and circuit breaker are working correctly.
We have a 501 in our office and we have no hot water. I have checked the breakers and I don't know what to do from there. Any suggestions?
If your electric hot water heater is not working...check out this tip about electric hot water heater problems
Electric Water Heater not Working
heatman101
Jan 12, 2011 | RELIANCE ELECTRIC WATER HEATER
I have reliance 501 electric hot water heater, and currently have no hot water. Can't locate owners manual. What could be causing the problem.
There is an address near the end of this link to request manuals of reliance water heaters not listed. http://www.reliancewaterheaters.com/lit/om.html
it is quite possible that your heater works on the same principle as one of the other models and just differs in capacity or power rating.
Apr 10, 2010 | RELIANCE ELECTRIC WATER HEATER
Need to empty reliance 501 hot water heater how?
1) Shut the breaker off to it at the panel. 2) Hook a hose up to it (the bottom has a drain). 3) Close the valve to the water heater (on the cold water supply). 4) Open drain on the bottom of water heater. 5) Open the relief valve to allow air into the tank (it won't drain otherwise - think if you put your finger on one end of a straw - the liquid stays in until you let go). Why are you draining it by the way?
Jan 26, 2010 | RELIANCE ELECTRIC WATER HEATER
I have a reliance 501 electric hot water heater and i cant find the reset button. Where is it located?
it is located on the thermostat. Take the cover off the side and you will see a little red button in the side of the themostat.
Jan 10, 2010 | RELIANCE ELECTRIC WATER HEATER
RELIANCE ELECTRIC WATER HEATER Logo
263 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
rickb63
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
