Question about ACE Dimplex (r) Compact Electric Fireplace (DFP36430) Heater
My Dimplex electric fireplace does not turn on. Just moved in and the last owner never used it. I can't find the model # but the remote has a DOC ID # 255K656-61-8367T. where should I start? Thanks for your help.
  • 232 Answers
SOURCE: I need a wiring diagram
you can get from www.dimplex.com
Posted on Sep 15, 2009
  • 2514 Answers
SOURCE: remote control working with fireplace.
try www.dimplex.com go to customer sevices they should be able put you on to a local dealer in your area
hope this is of some help
Posted on Dec 13, 2008
  • 92 Answers
SOURCE: 15 Amp circuit breaker keeps on tripping , as as
breaker tripping right of way means bad breaker or dead short. which means something has burned out or is wired incorrectly
Posted on May 14, 2009
  • 3 Answers
SOURCE: I have a Dimplex Electric
There is a safety bi-metal strip that is probably tripping out. Does it turn back on after a cooling down period ?
Posted on Dec 05, 2010
Testimonial: "Thanks for all the advice. It is working now and has been for the last 15 minutes. Hopefully it will work for a while."
SOURCE: I have a Dimplex Fireplace with remote control. I
There was a recall on some of the remotes. Check to see if yours is one of them. If you take the plug put of the remote box, and just plug it directly into the wall,it should work.
Dimplex optiflame remote not working
The DFI2310 uses a simple plug-in remote.
You can either order one from Dimplex, or use an aftermarket solution such as this one from Skytech: Skytech 1315G Electric Fireplace Remote.
Oct 08, 2012 | Dimplex DFI2310 23 Inch Deluxe Electric...
Does not turn on when you use the remote for fireplace
Kelsey, have you changed the batteries in the hand held remote? If not, I suspect that's the problem.
Please let me know. Thanks
May 05, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
Our dimplex electric fireplace model number 28106D3F shut off and won't turn back on
Turn the Master ON/OFF Switch to OFF. Unplug the fireplace from the wall receptacle and leave unplugged for 10 - 15 minutes. This will give it time t reset itself. In the future, if you finding you're have to do this more often. Unplug the fireplace, stop using it and call Dimplex USA Technical Service 888-346-7539 for further instructions.
Mar 09, 2011 | Heating & Cooling
Hi I have a Dimplex electric fireplace model# CS3311. I had the Remote Receiver plugged into the wall outlet and the Unit Plug was plugged into the side of the Remote Receiver, just like it says to do in...
Lisa, apparently there was an electrical overload in the receiver box. I assume this electric stove is new and still under warranty. In which case, armed with your Proof of Purchase, you need to contact Dimplex USA or the retailer you purchased it from.
Below is a link to Dimplex USA Customer Support.
http://www.dimplex.com/customer_support/contact_us
Feb 23, 2011 | Dimplex Compact Electric Flame Stove...
Need to replace noisy fan motor on Dimplex 6901470100 Not sure how to gett access to blower. Thanks
If you no longer have your Owners Manual go to the Dimplex home page and click on the Help tab. You should be able to download the Owners Manual for your model fireplace there in a pdf format. Also look for a Trouble Shooting tab.
Jan 31, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
I have a Dimplex Fireplace with remote control. I believe the model number to be BF335STP/DXP. We have had this fireplace for almost 2 years. When we have a power outage you have to follow some...
Nov 30, 2010 | ACE Dimplex (r) Compact Electric Fireplace...
Does dimplex model 6902340100 have a fuse, stopped working no fan, no light took back panel off could not find a visable fuse.
My friend just had the same problem. It turned out to be the Remote Control box,( the little box you plug the Fireplace into so you can use the Remote). He just plugged the Fireplace straight into the wall outlet, (without the Remote) and now it works fine.
Oct 19, 2010 | ACE Dimplex (r) Compact Electric Fireplace...
Dimplex Electric Heater Model Number DF 3003 fan motor not working. How do I access the fan motor to repair or replace it?
Dimplex has a Service Manual for your Heater. I recommend requesting the manual through their Literature Request website. I located the owner's manual and the troubleshooting guide via their website, but it appears you will need to request the Service Manual.
Hope this helps.
Mar 30, 2010 | ACE Dimplex (r) Compact Electric Fireplace...
Remote control working with fireplace.
Dec 13, 2008 | Dimplex DS5603 Heater
Help
Dimplex has a number for you to call: 1-800-668-6663 ext# 358 TELL THEM YOUR PROBLEM AND THEY WILL PUT YOU IN THE RIGHT DEPARTMENT. I had problems with the main switch and they sent me a new one.
Nov 05, 2008 | Dimplex Compact Electric Flame Stove...
Heating & Cooling Logo
537 people viewed this question
Top ACE Heating & Cooling Experts
Andrew Taylor
Andrew Taylor
Tim Whalen
Mack Baxter
Are you an ACE Heating and Cooling Expert? Answer questions, earn points and help others
