I live in Wisconsin (so it gets cold) and I just built a 1,000 sqft detached garage with 9' walls and I looking for the most efficient way to heat it. I will generally only be using it on weekends, but, wouldn't mind keeping it moderatly warm throughout the week as well. Looking for recommendations . . . . Thanks, Rob
  • rob_hummel Nov 12, 2010
    Sorry,
    I should have included that it is fully insulated and sheeted with 1/2" osb inside.
    Sorry, to be so blunt, but I am very aware of the different types of fuels available . . .Oil, NG, LP
  • 3,287 Answers
Hi Rob - There are a bunch of variables that come into play. If you're going to use liquid fuels such as K1 kerosene or "home heating oil" (red dyed diesel fuel without the "road use tax"), you have to consider the tank location. Since home heating oil is really dyed diesel fuel, is reacts to cold just like diesel fuel does. It begins to gel - paraffin separates and the fuel gets cloudy around the 20 degree F mark and can clog the supply lines and filter. It gets worse as it gets colder. You can get around this somewhat by installing larger diameter and insulated fuel supply lines and moving the filter bowl assembly inside where it won't be subjected to that much cold. Your dealer may put additives in the fuel to prevent separation or you can add it yourself. K1 can be added to home heating oil tank to reduce clouding and straight K1 can be burned by an oil burner (you can not burn home heating oil in a K1 heater though). K1 on the other hand, flows just fine at these temps and lower. You'll need to supply storage tanks for these fuels.
The amount of heat or BTU's per gallon of these two fuels is significant. Home heating oil checks in with 50% more heat with around 140,000 BTUs per gallon while K1 has just over 90,000 BTUs per gallon. Cost is another factor. Typically, K1 sells for more than home heating oil, but has the benefits above. Prices for home heating oil and K1 are volatile and change daily and from dealer to dealer. Many dealers will lock prices and / or offer purchasing plans.
Next is natural gas (or just plain "gas") and propane (or LP). Gas is usually delivered via underground supply pipes and propane is delivered by truck to your on-site tank in areas that don't have the underground gas pipe infrastructure in place. The LP dealer will usually supply and install an above ground tank. You'll likely have just LP or both LP and gas available in your area. Heating appliances must be set up to burn one fuel or the other - not both. It is often a relatively inexpensive operation to convert from one fuel to the other, meaning separate appliances for either are not required. Gas prices are usually fixed for different times of the year, while LP prices may change daily and based on the volume used. Lower usage customers often pay more than their next door neighbors that use more from propane the same company. Like home heating oil and K1 dealers, many companies offer price locks and purchasing plans.
Gas and LP heating appliances burn "clean" meaning that there is little smoke, soot or tuning needed. Oil and K1 however, require regular tuning and cleaning to achieve maximum efficiency. Oil and K1 will burn but not rapidly combust - as gasoline would. LP and gas however, will explode if allowed to collect in an enclosed area and ignited by spark from a ringing telephone, etc. Prices of the heating appliance itself come into play as well.
You can heat the space by your choice of fuel and method of heat delivery. Forced hot air is probably going to be your best choice, but you could choose a forced hot water system if you add antifreeze to it. You'll also need a source of water to make up any lost due to pressure relief valve discharges, etc. If you chose the forced hot air system, you could probably get away without the expense of duct work - where a forced hot water design will require baseboard radiant heaters or a fan forced hot water coil.
That should be enough to get you thinking.. good luck!
Lastly, electric heat. Electric heat is 100% efficient, but is probably the most costly to operate. It's listed because it is available - not because I recommend it.
The best thing you can do is insulate. Insulation pays you back quicker with each rise in fuel costs. Put money into proper insulation as you can. Low E glass in your windows, weather strip doors, etc.
Posted on Nov 12, 2010
  • Steve Nov 12, 2010
    No problem. Your question, like too many others here - didn't provide the detail needed to get the info you're looking for. It's hard to know specifically what kind of "recommendations" you're looking for - if you don't say. Do you want a recommendation for a brand name of a reliable furnace? Or burner? Programmable thermostat? Fuel dealer? Or what??
    Sorry to be so blunt.. but no one can read your mind! Please, tell us what you've got and what you want!
Heat for a 3 seasons room
single pane glass is not thermally efficient as the glass transfers heat or cold
double glazing with a air space between is more efficient and will require less power to keep the temp setting
before you do anything , talk with a thermal engineer or you could be wasting money by doing what you suggest incorrectly
Apr 18, 2017 | Heating & Cooling
I am getting ready to buy baseboard heat for a 800-900 squarefoor open area, old GArage, And I am looking at 3 8' 2500W sections of base board. is this enough. And How much better is the units you have...
First, those of us on FixYa don't sell any products or appliances. Just information.
But to answer your question about electric baseboard heating ... It's the most inefficient and costly heating source you could use. With that said, a lot depends on the cubic footage of the area, as well as how well that area is insulated. This applies for electric, gas or oil heating. You rae not just heating square footage, you're wanting to heat cubic footage (i.e. Width x Length x Height = Cubic Footage). Assuming you have an 8 ft ceiling, the Cubic Footage would be (assuming a 9 ft ceiling) 7200 Cubic Feet. Based on that and if it was my home, I'd be installing a 20,000 - 25,000 Btu Vent-free (Flue-Less) Gas Heater, with built-in thermostat control. It could either be as a Free Standing, Vent-free Gas Fireplace System or simply a Wall Mounted Heater. One is decorative, as well as efficient and the other is simple and efficient. Plus, gas heat is a warm, moist heat that you feel very quickly and it's more comfortable than electric or oil heat. As a matter of fact, Vent-free Gas Heating Appliances are 99.9% efficient. And will work without electricity. Which is great during a Winter power outage. If you currently don't have Natural Gas at your home, then LPG (Liquid Propane Gas) is readily available.
So, by now, you figured out that my preference is gas. I have three Vent-free gas heating appliances in my 3000 square foot home (2-Vent-free Remote Controlled Gas Log Sets in existing wood burning fireplaces & a Vent-free heater in my 2-car garage). Our primary heat source is an electric heat pump. Which doesn't work well, when the temperature reach 32 degrees F or lower. We use the gas heaters only as a supplement heat source or as primary source, if the power goes out.
I hope you'll take a little time to research this, because in the long run, it can save you $$$. Below, is a link to Empire Comfort Systems. They have excellent supplemental and primary heating products in all looks, shapes and sizes. This will give you an idea of what's out there.
http://www.empirecomfort.com/corporate/
I hope all of this helped you. Please let me know. Thanks.
Jun 13, 2011 | Fahrenheat F25426 Electric Baseboard...
Leaving a fridge in a cold garage
a fridge will not work right in an un heated garage
Dec 17, 2009 | Refrigerators
Is an oil burner efficient for a detached 2 car garage w 1 BR apt
the best oil burner to use would be of the condensing combination type as this would be abt 96%efficient and only heat water as you needed it probably saving you abt 30% on your oil bill
Nov 12, 2008 | Water RHEEM 40 Gallon FVR PROP PWR Heater...
Ge wall unit cools and then stops
Weather below 50 deg F can harm airconditioners if you run them. If the unit is turned off, then the weather can get as cold as it wants to and not damage the unit. Also 99.999% of the time repair costs on wall units surpass the cost of replacing the unit. This is even accounting for the fact that you will have to pay $25 to $50 to get rid of the old a/c. 5 yrs isn't that bad for a wall shaker anymore. Suggest looking for a new unit.
Jun 27, 2008 | GE AJCQ08ACB Air Conditioner
Heating & Cooling Logo
101 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
