Question about Magellan MAESTRO 3100 98083401 GPS Device
Battery I get the message Battery critically low and the GPS is put to sleep. I bought an AC charger and charged it for more than a day and I can't get it to apparently take a charge. The unit is six months old and has rarely been used.
  • RChance2 Aug 23, 2008
    Bought this unit 1' year ago. Says battery critically low. How to charge it? Bought an adapter but doesn't seem to work.
  • cmolson Sep 21, 2008
    I have the same problem. Used the Magellan for 8 months and battery is critcally low. I had to purchase another battery since the "warranty" states battery is not included.
    Now I can't figure out how to charge the new battery for 18 hours straight prior to use.
Hello everyone, i will like to suggest a few important troubleshoot points related to Battery Problems with this Magellan Gps units,
1- broken dc jack- this will be inside the Gps Charging Pin Terminal - most common one
2-Gps must be program to " Never Turn off", this is a battery saver selection,(customer user end)
3- No output from Car Power Supply
4- Defective Battery not holding a charge will stay at no more than 3,8 vdc(3 bars of battery diagram)
5-wires,terminals,conntacts, are taped and they dont fail, unless someone touches it.
Posted on Sep 29, 2008
Did you push the reset button on the side with the unit running?
that seems to keep mine on and I'm hopeful that it is recharging.
Posted on Aug 15, 2008
  • 3 Answers
BertM, I had the same problem and also do not use it frequently enough. The unit finally gave way about 7-8 months. I am hoping that Magellan will honor their warranty and find it's bad battery. I am awaiting an RMA. Visit following site for help:
http://www.magellangps.com/support/askmaggie.asp
Posted on Jun 30, 2008
Battery will not charge just says battery critically low and turns off
make sure your charger cable is seated all the way and the light(usually blue) on the charger is on,let it charge for an hr. before trying to turn it on. If it still doesn't charge try another charger of the same type with it as your charger may not be working. If your sure your outlet is ok{powers other devices} then you can see if the fuse in your charger has blown,replace as needed.Any automotive store has replacement fuses of this type.
Nov 01, 2013 | Magellan GPS
Magellan 4040 charging issue
Click HERE for the user manual and go through it carefully you will find the solution.
Goodluck..
Feb 24, 2008 | Magellan Maestro 4040 GPS Receiver
Gpsmap 180 firmware corrupt
It sounds like it has lost its memory battery. Usually you
would get a "memory battery low" message as it is on its
way out but you don't mention that so perhaps it has
completely failed.
The battery is rechargeable - if you leave it switched off
and loaded with a fresh set of alkalines for a few days it
may recover. If not contact Garmin as they have replaced
many memory batteries free of charge even out of warranty.
Oct 30, 2007 | Garmin GPSMAP 430 GPS Receiver
Nuvi 1390 will not power on.
Try pressing and HOLDING the power button for up to 15 seconds (or until it powers up - whichever happens first). This is a hard reset - and should get you going unless the battery is discharged.
Oddly, batteries can discharge when the GPS remains on the car charger. Disconnect it and connect to the your computer's USB port (or AC adapter if it came with one) over night. The computer must be ON - "sleeping" is ok too - just not "OFF". This will charge the internal battery.
If it will not accept a charge, you may need to replace the battery or return the GPS to Garmin for service.
Nov 19, 2011 | Garmin Nuvi 1390 Car GPS Receiver
Bought a new ac charger for the laptop and tried to charge it up ,critical low battery error keeps coming up and computer switches off
replace battery, as long you adapter plug in indicator work charging also work so only battery not accept charging.
Apr 04, 2010 | Lenovo ThinkPad R61 Notebook
Acer aspire 2920z is automatically shutdown only message appear warning critical battery low and then shutdown
Sounds like your battery is faulty and not charging. Try replacing the battery or just use the mains lead with the battery removed. If this keeps happening replace the system board
Feb 23, 2010 | Acer Aspire 5610-4648 Notebook
Garmin 350 cannot charge and nav at the same time
Your battery is faulty. Did it come with an AC Charger? Ac chargers do a better job than the car Dc which really only manages to maintain a reasonable level of input. i suspect your internal batter is critical and either needs a thorough charge or replacement
Jul 25, 2009 | Garmin Nuvi 350 Car GPS Receiver
Nuvi 200 GPS
We did not have a charger to plug in the GPS to charge, so my husband plugged it into a battery charger. I guess the battery charger was low, so it drained the unit rather than charging it. It was so low it would not come on again. I have an electric charger that adapts the car charger into AC current, so I tried that and the unit came on. Problem solved and the GPS is working again. Thanks for responding.
Jun 20, 2008 | Garmin nuvi 200W GPS
Charging unit with AC adapter
I have a 100v A/C power / charger unit for my garmin C340 GPS that I use to charge my Garmin's battery every day. I can use thj adapter to run the GPS, or just turn it off and let it charge the GPS. But it connects dirctly to the Garmin GPS unit, not to the cradle like the Cigarrette lighter unit does. .
Mar 18, 2008 | Garmin StreetPilot c340 GPS Receiver
Magellan MAESTRO 3100 98083401 GPS Device Logo
205 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
