Question about Coleman Heating & Cooling
I want to know what a lever in a fire place is
  • 3,287 Answers
The lever at the top of the fireplace operates the "damper". The damper is a door that opens the fireplace to the outside via the chimney.
The damper must remain open whenever a fire is burning in the fireplace to allow smoke to escape out the chimney instead of filling the fireplace and eventually, the room. The damper should be opened prior to starting a fire, otherwise the handle will be too hot to handle. Once the fire has gone completely out, the damper should be closed to prevent heat from being drawn out of the room / home. You can easily check is your damper is open or closed by simply looking up the chimney. If dark, it is closed. If light(er) it is open. Do not operate the damper while looking up - as dirt, soot, rust, etc. can fall when doing so.
The damper also prevents pests from enter the room / home. It is not uncommon for birds, bats squirrels, etc. from creating a home / getting caught in side the chimney.
I hope this helps - good luck!
Posted on Nov 12, 2010
There is a lever on the side of fire place. does it need to be up or doen when you use fire place
If you are referring to the damper in a standard fireplace, it should be pushed up to open it.
Jan 23, 2017 | Work Safety
I have a hitachi nv45...aand dropped it of the roof.It broke the pushing lever (part #888-883)I replaced it and now the gun isnt firing properly.The guns rapid fire doesnt work.You have to push the trigger...
Sometimes after a good knock on the side the cylinder will bind and not work correctly. Remove the head and make sure that the cylinder moves easily up and down. If cylinder is ok, then most likely the adjustment on the pushing lever set too low. New pushing lever does not come with the adjustment screw and lock nut. Adjust the screw up or down for best firing position. If the adjustment screw is in place and adjusted, make sure that the plunger is not sticking within the valve(plunger makes contact with the adjustment screw on the pushing lever). With pushing lever removed, the plunger should move easily in and out. Good luck
Oct 13, 2014 | Air Tools & Compressors
98 Ranger Headlights Not Working
Check the bulbs, if OK replace switch.
May 17, 2017 | 1998 Ford Ranger SuperCab
Central pneumatic roofing nailer,where is the nailing ajustments?i should be able to hold the trigger and touch the nose to fire repeatedly but it wont let me.dont see a ajustment?
Not all nailers have the ability to bump-fire. It depends on the type of trigger and the firing valve that the trigger contacts. Remove gun from air supply and remove the nails (for safety). Take a close look at the trigger itself looking for a bump fire setting. It will have a rotary dial to select single or repeat fire. If no setting, look at how the safety foot contacts the trigger's inner trip lever (the trip lever inside the trigger is what actually contacts the firing valve pin). With trigger pressed in, push the safety foot in and notice if the safety contacts the inner trigger lever. On bump fire trigger, the safety foot mech. will push up on the inner lever each time that you press in safety (and you will see that the inner lever will depress the firing pin). On single fire trigger, with trigger pressed, when you push on safety foot, the mech. will not contact inner trigger lever because the lever is too short to allow safety to make contact with it. On single fire triggers, the inner lever can make contact with safety only when trigger is in the resting position. With trigger released, depress safety and notice that safety contacts inner trigger liver and will remain in contact untill you press the trigger at which time the inner lever will depress the firing pin then fall away from safety. If you are a tinker-er, you can make adjustment to inner lever so that it will make constant contact (the rotary dial on triggers that are made to give you a choice of bump or single actually make the inner lever longer or shorter ). If you make any adjustments, make various and numerous tests with-out nails to make sure that it will not fire accidently.
Mar 21, 2011 | Air Tools & Compressors
Paslode framer when you depress trigger there no resistance and it does not fire
Paslode framer has a lever inside of trigger that may be bent or missing. Easy to check. Remove air line and nails. Remove trigger by pulling pin. Check under trigger for missing parts. Test gun by connecting to air and place nose of gun against wood or hard rubber and then depress firing pin. If gun fires then problem is with lever under trigger or safety mechanism which is in two parts. Check safety for bent or broken piece, usually upper part will be missing lip that actually pushes on the lever. If however gun does not fire when firing pin is depressed, time for replacing orings in gun. Parts are available at www.toolpartsdirect.com . Good luck with your repair and post again if you have other questions.
Jun 30, 2010 | NRS Paslode 501000 Powermaster Plus...
Gas tube
I don't know what you did, but when you beat on something that is supposed to glide with ease, something is wrong. Send me that thing, I'll fix it. I have been sitting around here bored to death lately. Where do you live? I was wondering what would happen if yo took the old gas tube, put crimp in it, to slow it down, and try it, see what happens. The locking lever? You mean the bolt? Is jumping out of it's track? Yikes!
Feb 13, 2010 | SKS Optics
New shifters for deore xt x7 delrailer
Shimano make an "EZ fire" which is an integrated shifter/brake lever combination and cheaper than buying seperate shifters and levers.
e.g.
http://www.tredz.co.uk/.Shimano-Acera-8-Speed-EZ-Fire-ShiftersBrake-Lever_24339.htm
Feb 07, 2010 | Shimano Deore Xt Thumb Shifters 7...
The lever doesn't stay down anymore, what should I do?
It sounds like the latch is broken. Unless you are very comfortable opening appliances and know very well what you are doing, it is best to have the toaster replaced. Check if it's still under warranty, or buy a new one.
Any workarounds to block the lever in its down position are very dangerous and a potential fire hazard. You may be able to wiggle the lever into place so it catches whatever is left of the latch, but make sure it will pop up easily when the toast is ready.
I hope this helps.
Nov 16, 2009 | DeLonghi RT200 Retro 2-Slice Toaster
Mamiya RB67 ProS wont trigger or advance
Start by making sure the dark slide is removed, the camera will not fire with it in place. The next step is to check the rotating back to make sure it is locked in either the vertical or horizontal position. Without film in the magazine, the multi-exp lever on the back must be set to show the red dot under the advance lever. You can check the camera without the back by removing the rotating back using the latch on the bottom of the camera
Nov 25, 2007 | Mamiya RB67 Pro SD Medium Format Camera
Heating & Cooling Logo
157 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
