Question about Ruud UBHC Air Conditioner
I have a Ruud Achiever 90 plus furnace. There is a random ticking noise coming from the furnace. It comes and goes at random, even when the thermostat is set to SYSTEM OFF. I removed the panel and found that the noise is coming from a relay on the main curcuit board that trips on and off. The relay is a component marked on the board as "K5". It is a Potter & Brumfield T9AV1D12-22. Does anyone have any idea what might cause this relay to intermittently trip like this?
  • Todd Reeve Nov 13, 2010
    I've started down that path....a few early mornings ago when I was awoken by that infernal ticking, I pulled the t-stat (a Honeywell FocusPRO TH6220) off of the wall and the ticking kept going so I think it's safe to say that it's not that. All of the connections at the t-stat and inside the furnace are secure, so I think your feeling that it's the main board is correct.
    It's only a year and a half old....still has the parts warranty but no the labour. Time to call in the service tech I guess.
    Thanks for you input.
  • Todd Reeve Nov 14, 2010
    Hmm, I'll have to check those things out. Thanks for the tips. I'll let you know how I made out.
  • 43,501 Answers
To eliminate the t-stat and wiring I would unhook the t-stat wires (of course mark them first) and see if it still does it...
If so, then the problem is interal in the furnace...
then, wiggle wires in the furnace to see if you can isolate the problem to a wire or connection....
My first gut feeling though is that your main circuit board is going bad....I think you will have to replace it...
heatman101
Posted on Nov 12, 2010
  • D. Floyd Kolb
    D. Floyd Kolb Nov 13, 2010
    I have seen nails in the t-stat wire that wait a long time to start to cause trouble....
    also have seen wire that the insulation started to break down and cause problems similar to that....
    One other thought....check grounding at the main electrical panel.....poor grounding also does funny things to those boards....
Ruud achiever 90 plus furnace-water leaks from the drain pipe
This furnace should condense, as long as it goes into the drain. If it is leaking inside the furnace, there may be a seal that needs replacing in either the pvc drain pipe or concentric drain trap needs resealed.
Feb 21, 2015 | Ruud Heating & Cooling
My Ruud Achiever 90 Plus not blowing cooled air
Look on the condensor, (outdoor unit) at the very bottom of the rear panel and you should find a red reset button. push it. If that does not solve the problem, and the outdoor unit is running (make sure both the fan AND the compressor are running) then you are looking at a low refridgerant issue and possibly dirty coils.
In that case, clean the coils and have refridgerant added.
Sep 23, 2009 | Ruud UBHC Air Conditioner
Ruud Achiever 90 plus not blowing air
the motor is bad or start capicitor
Aug 29, 2009 | Heating & Cooling
A different smell coming from the heat ducts. I can't figure where the smell is coming from. I have Ruud achiever plus 90 furnace.
There can be several causes for odors in a unit. If you have just started turning the air on, you may have an issue with too much moisture in the coil and supply plenum causing mold to accumulate and grow. Also ducting can come apart or be chewed open by critters allowing air to be drawn in from the attic or crawl space depending on your configuration. These are the typical smells.
Apr 08, 2009 | Ruud UBHC Air Conditioner
Ruud achiever 90 plus won`t start at times
sounds like you have a heat pump heat pumps dont work below 30* temps you should have some type of backup heat
Feb 05, 2009 | Ruud UBHC Air Conditioner
Check the data information on the unit there should be a troubleshooting guide that tells you what the two lights blinking once means. hope this helps.good luck. normally found with schematic
RUUD Furnace not coming on
the fuse that your refering to is on the control board indie of the furnace. shjould be a 3 amp. good luck.
Jan 30, 2009 | Ruud UBHC Air Conditioner
Ruud achiever 90 plus blower not working
does the furnace ignite?? your system may not have been lighting and has gone into ignition lockout count the codes of the led lights then remove panel led diagnostic codes are listed there.
if led codes indicate no problem verify capacitor is good and that mtr is getting 115 volts.
Sep 15, 2008 | Ruud UBHC Air Conditioner
Ruud UBHC Air Conditioner Logo
52 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
