Question about Toto Neorest 600 1pc. Toilet MS99OCGR-01
I have a noisy deodorizer fan on Neorest 600. Any suggestions?
My neorest toto 600 shoots water everywhere when flushed
Reckon the toilet gets PO'ed f for being used and abused!
May 03, 2017 | Toto Home
Toto neorest leaking & low pressure wand
Sounds like the washer in the shutoff at the wall has failed and is partially blocking the fill pipe. Some rubber from it may have gotten into the toilet valve internally. With the wall valve closed, try to remove the connection pipe to the toilet. If you can do it without water continuing to flow out of the wall shut off...then remove the pipe from the wall shut off. Flush the toilet. Now, apply air pressure to the rubber hose the goes into the overflow pipe. That may clear the valve in the tank and solve both problems. If you cannot stop the water at the wall shut off, close the water valve feeding the house. Remove static water pressure by opening the cold water a the kitchen sink faucet. Now you can open the wall shutoff valve and replace the washer and clean it out....
Mar 08, 2014 | Toto Neorest 600 1pc. Toilet MS99OCGR-01
My neorest 500 smells we have had it for 4 years. I am wondering what can be done. we love the toilet.
Smells usually come from the tank and not the bowl.
Buy tank deodorizer from local store located near toilet brushes.
http://secure.willert.com/images/bf_wire.jpg
Deodorizer hangs inside tank. make sure it reaches the water.
You can also drain and clean the tank using CLR calcium lime and rust remover.
The CLR and gunk are fine for flushing away as long as the gunk doesn't clog the flush holes that let water flow into bowl.
http://www.fixya.com/support/r6633961-toilet_doesnt_flush_water_just_spins
Sewer line can also cause of odor.
If the toilet bowl is not full of water, or if nearby drain is not filled with water, or if toilet is not sealed tight against floor, or if toilet appears to have dampness visible around base, or if a vent pipe terminates behind a wall instead of on the roof: these things can cause sewer air to enter room.
Jul 28, 2011 | Toto - Toilet - One-piece - Neorest 500 -...
I need to know where to put the electrical oulet for the toto toliet 600
Put it within reach of the unit and make double sure it is GFCI protected!!!!!!
Nov 08, 2010 | Toto Neorest 600 1pc. Toilet MS99OCGR-01
After the flush and it fills up the water overflow keeps running
check the over flow valve shutoff and make sure it is at the right height
Sep 28, 2010 | Toto Neorest 600 1pc. Toilet MS99OCGR-01
The bowl is full of water and cannot be snaked by a plumber it will not flush. it is a neorest 600
When you say it does not flush; do you mean it flushes...the water just won't go down (won't empty the contents of the toilet bowl)?
Be more specific.
JZ...
Dec 09, 2009 | Toto MS990CGR-11 Augusta Decorative...
Not auotmatically flushing
Sensor is not working. It could need replaced, or just cleaned, also check if its getting power. If this helped give me a thumbs up please.
Oct 06, 2009 | Toto Toilet Onepiece Neorest 600 ...
Toto Neorest 600 1pc. Toilet  MS99OCGR-01 Logo
82 people viewed this question
Top Toto Home Experts
john h
Robert McCall
Robert McCall
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
