Question about Bissell 9200 Upright Vacuum
Problem: water will not dispense Local repair shop gave verbal diagosis>need both solenoid valves. Found this part on www.nelsonappliance.com $14.95 each. (Shop quoted $98 for repair & parts) Can i access & replace parts? Is there a "how to" video available?
3 Suggested Answers
SOURCE: NO WATER OR SHAMPOO
I had a problem with no water or shampoo coming out of the main unit but did come out of the hand tool. Someone had the answer posted here and if I could find it, would refer you there as it was much more technical. My wording is more like, little red thingie under the water tank. Saved me buying parts or taking it in for service. Anyway, here goes:
Remove the water tank. On the base unit, there are two little red things, one on each side. Squeeze the clips together to remove the red things. There is a hole where each of these red things were. Clean these holes out from loose hair, dirt, etc. Then using a toothbrush or other small brush, clean the little red things. These are the actual sprayers. They can get clogged.
The poster that I got this from also explained how to remove the little red clips from the hoses and how to clean them, but they noted that it was pretty easy for the spring to shoot up inside the hose and to be real careful. I do not have the details on that. It was simple to remove and easy to clean, but you had to make sure and hold the spring. Mine worked without doing that but my husband took it apart anyway just to make sure it was all clean. You can search this site for the full description in more technical terms on the hoses and clips and cleaning them. It was on the fixya site.
Posted on Jul 13, 2009
  • 794 Answers
SOURCE: I recently had my vaccum
Hi gbenintendi,
This issue might be caused by different factors. And I'll give you some basic checking and troubleshooting that you may try to do to address the issue of having a low or almost no suction on the lower part of your machine.
1. First thing, check the dirt cup to make sure it is empty.
2. Your vacuum has 3 filters. Check out for debris on the inner and outer circular filters in the filter cup and the post-motor filter on the front of the machine. Also don't forget to check the upper-tank louvers. They may be removed and rinsed. Dirty filters will restrict air flow. To clean the filters:
  • It can be hand washed in cold water with mild detergent. Make sure to
3. Consider also on checking for good suction at the end of the upholstery hose with handle. If there's good suction, ensure this end of the hose is firmly pressed into the lower hose outlet on the back of the vacuum. Also check to ensure the brush is rotating. If it is not, remove the plate on the bottom of the vacuum by the two tabs and check the belt and clean the roller of debris and dirt. If the lower hose is clogged, remove the hose with handle and clean this hose.
4. If there is NOT good suction at the end of the hose with handle, remove the hose by twisting it off the back of the machine and check for suction on the vacuum. If the suction power is good, check the hose for cracks or splits and using a broomstick handle, push any dirt or debris through the hose.
Your problem may be something as simple as a broken drive belt or a filled dirt container. If you continue to experience low suction with your vacuum, please take your machine to a local BISSELL Authorized Service Center.
Hope it helps.
Thank you for using Fixya.
Posted on Mar 30, 2011
How can I operate the Bissell PROheat 2X carpet/upholstery cleaner without instructions?
Your solenoid that activates the hand unit is most likely burned up. Bissell 2X machines generally last 4 to 6 uses and a solenoid burns up. This is the only machine that we do not offer repair service for in my store. It is a terribly poor quality design.
BTW, the brushes aren't supposed to turn when the machine is in the upright position.
Sep 18, 2014 | Bissell 9500 ProHeat 2X CleanShot Upright...
Hoover F7425-900 SteamVac V2
http://www.hoover.com/pdfs/manuals/F7452900.pdf Heres a link to the manual if you dont have one, Ive emailed them and they gave me the same solutions that are on page 17. ? Make sure tank is securely locked in position ? Clean water tank or detergent container empty ? Refill container according to instructions for surface being cleaned ? Recovery tank lid not on correctly ? Make sure lid is firmly in place ? Valve cap clogged ? Remove and clean valve cap (see following instructions) 1. Remove clean water tank. 2. Turn valve cap (A) counterclockwise and remove. Soak valve cap in warm water for at least 15 minutes. Wipe cap dry. 3. Align slots (B) on cap with tabs (C) in opening. Turn cap clockwise to tighten.
Sep 17, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
How do I replace the hoses on a Hoover Spin Scrub?
I'm guessing you have an F7000 series machine. You have a bad solenoid. When they go bad they don't close so all the water poors out. Take it to your local vac repair shop for the repair.
Sep 11, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Will spray water, but not solution
Hi there! The clean water tank has two spring loaded valves that releases the contents. Fill the clean water tank with water on both sides. Hold the cleaner up and push the valves in on both water and solution side. Both valves should push in and contents should drip out. If not, the clean water tank will need replacing. To order a replacement tank follow the link. Search Results The type of solution you are using can also prevent the solution from dispensing, be sure you are only using the recommended cleaning solution for this cleaner. If the clean water tank valves seem to be working fine, there may be an issue with the pump assembly that delivers the solution. We would recommend taking the cleaner in to an authorized repair center for service. To locate the nearest service center to you follow this link > Service Center Locator Hope this helps!
May 31, 2014 | Hoover F7452-900 All-Terrain SteamVac
I have a Hoover SteamVac that dispenses detergent when pulling backwards instead of rinse water.
This may be due to an electrical issue with the solenoids not shuuting off when suposed to. I would take it to a shop for repair.
Apr 15, 2010 | Hoover F7452-900 SteamVac Upright Vacuum
Bissell ProHeat Rug and Floor cleaner. Won't
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
sf
Oct 20, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have a Hoover STeam Vac Dual V. Replaced the water tank-no problem. but water still pours out through the bottom. when idle, when off, when running. dont need to press the lever. Help!
Te dual V models have an electric pump and 2 solenoids that control the soap and water to dispense. The problem you describe, sounds like the water solenoid is stuck open. and would need to be serviced by a repair shop.
Oct 07, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Detergent bottle keeps falling off, wont stay put and clean water isn't emptying at all
The tank assembly needs to be replaced. Keep your tank handle. The other problem is your water not dispensing. There are electric solenoids and a pump that control dispensing soap and water. Take it to a repair shop for complete diagnosis before you replace the tank. The new tank is better, both soap and water tanks are in one assembly
Oct 04, 2009 | Hoover Vacuums
Schematic parts diagram for bissell proheat 9200 carpet cleaner
Hi, just go to amazon here: Amazon com bissell proheat carpet cleaner parts and you can find every needed parts. I hope this was helpful. Cheers
Jul 24, 2008 | Bissell 9200 Upright Vacuum
Hoover steamvac deluxe
http://geeksquad.fixya.com/ThreadView.aspx?prdid=41020&thid=565323
Hoover SteamVac deluxe
Posted by stripes9 on May 02, 2008
The solution will not dispense from the machine but will still dispense from the hose.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover F5866-900 SteamVac Deluxe Wet/Dry. You probably have 2 problems, #1. The trigger assm may be loose or broken and is not releasing the solution from the water solution tank or #2. The valve under the water solution tank could be shot or broken. If so, then the water solution tank is one assm and you would need to purchase a new or a good used one to replace. Please, feel free to check with your local vac dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 02, 2008 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Bissell 9200 Upright Vacuum Logo
651 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
