Question about kawasaki Garden
Sparkplug wire has been cut, what should i do
  • 718 Answers
Buy a new coil and replace it, and you will be on your merry way.
Posted on Nov 13, 2010
Goes to magneto down by pull string, remove pull string housing and dare it b
Jul 06, 2014 | Garden
Rpm gauge keeps jumping and it will cut off after jumping. It also acts like it wants to cut off while im driving and the transmission changes gears
This is a misfire with you car. The problem will be in 2 places if the disributor cap is bad youll see what they call ,spark flash, In the rotor this cap has to be in a set position and it has a tendeny to ge displaced and that will have to be replaced., The sparkplugs as it connects to the cap may spark flash over and at idle you can see it. Now at the sparkplug wires they go it to the valve cover and the valve cover leaks oil into the sparkplug boot. This can cause a misfire.What you need to remedy the situation is a tune up with a new distributor and cap and rotor with new sparkplug,
Apr 25, 2011 | 1992 Honda Accord
Just replaced filter and condenser when engine gets warm rotovator still cuts out
When the engine cuts out pull the spark plug and put the wire back on and ground the plug to the engine block and pull the cord to look for spark between the sparkplug gap. If no spark it could be that when the coil warms up it will caus no spark.
Mar 16, 2011 | Garden
Can someone tell me how can I replace the spark plugs on Dodge Caravan 2005, from above?
Open the hood to access the engine compartment. Locate the sparkplugs sitting to the side of the motor. Six wires run to the motor, three on each side.
Twist the rubber boot and pull away from the sparkplugs. This will expose the sparkplug.
Unbolt the sparkplug with a socket wrench. Use a 5/8-inch deep-well socket attached to the socket wrench.
Pull the sparkplug away from the motor. Discard the sparkplug.
Screw the sparkplug into the motor by hand. Make sure it is hand-tight.
Tighten the sparkplug with the socket wrench, using the deep-well sparkplug socket.
Click the wire to the sparkplug wire to the end of the sparkplug. Gently pull the wire to ensure it clicks into place.
Repeat the procedure for the remaining five sparkplugs. Change each sparkplug one at a time.
Aug 24, 2010 | Dodge Grand Caravan Cars & Trucks
How do I get the spark plugs out of my 1998 ford escort to replace with new ones? Also where does the pcp Valve go?
With you hood open and you are standing in front of the car sparkplug wires need to be removed,i suggest you remove them one at a time, under each wire the sparkplug is threaded into the cylinder head,using a 5/8 sparkplug socket remove the sparkplug and replace it with new properly gapped sparkplug.Note:if you remove all sparkplug wires at once the factory wires are generally numbered 1 2 3 4 the sparkplug closesed to the passenger fender is #1 and the one clossesed to the driver's fender is #4.Standing in front of vehicle the PCV Valve is located between #3 and #4 on the backside(intake side) of the engine fitted down into a rubber hose
Jul 17, 2010 | 1998 Ford Escort
What cause sparkplugs not to fire
A
  1. Faulty coil/coil pack
  2. Faulty or corroded wiring
  3. Faulty spark plugs
  4. Faulty ECU
  5. No fuel in combustion chamber
  6. Faulty security system2_bing.gif, cutting ignition during operation.
Apr 30, 2010 | 1997 Dodge Intrepid
1989 Dodge Omni Stalls out
A sparkplug wire may have been loosesed or disconnected or damaged.
If you can't find it then wait until late evening when it's dark.
Open hood and start the car. You will see the sparks from the damaged/loose sparkplug cable. Don't touch it while ignition is ON. It will shock you!
If you "disconnected" any sparkplug wires when you replaced the oil pump, then they were not put back in the proper firing order.
Hope this helps!
Sep 04, 2009 | 1989 Dodge Omni
When i turn it on only four pistons work need help
Check your sparkplug and wires, make sure that there are no cuts or kinks in the wires, also be sure the plug wires dont cross over eachother. Check the sparkplugs for any builed up of composits or damage.
May 15, 2009 | 1994 Mitsubishi 3000GT
91 civic cuts out
Did you replace the sparkplug wires
Jan 19, 2009 | 1991 Honda Civic
Garden Logo
22 people viewed this question
Top kawasaki Garden Experts
Joseph Mueller
Joseph Mueller
Phil Walker
Phil Walker
dannydoesita
Are you a kawasaki Garden Expert? Answer questions, earn points and help others
