Question about Lexmark X2350 All-In-One InkJet Printer
I need to scan a printed page into a txt file using Notepad. Gone through the Lexmark Imaging option and attempted to scan, Come up with a message about installing OCR software. I can't find original lexmark CD; what do I do? Do I need this OCR software? Why?
    Genius:
  • 1,087 Answers
The Lexmark OCR scan software allows you to scan documents to your computer. It enables you to scan to PDF or scan a document and convert to text to edit. The Lexmark OCR scan software is only available in the install disk that came with your printer. Please contact Lexmark technical support for assistance. Thanks.
Posted on Nov 12, 2010
How do I reset ms610 imaging unit?
When you get the error message "Replace imaging unit, 0 estimated pgs remain [84.3x]" This means the imaging unit has reached end of life and needs to be replaced. The device will not print, and this message will not be cleared, unless you replace it with part number 50F0Z00
(or 500z)
Vertical streaking. If the imaging unit is near end of life, or the device has had problems with non standard toner, vertical streaks may occur on the page. Replacing the imaging unit will resolve the problem.
Vertical streaks on page
Vertical band at top of page. This typically appears on printed images, but can also appear on text. The most likely cause is toner contamination on the charge roll, however if the band is still visible after printing 30-40 continuous pages this means the imaging unit needs to be replaced.
Vertical Banding on images
Seal failure on the imaging unit. Occasionally seal leaks have been seen from the Imaging Unit.
Toner will be seen on the main frame near the Imaging Unit sides.
If toner build up is excessive, it may even fall into the Tray below. Cleanup with a toner vacuum may be needed.
Replace the Imaging Unit to fix the problem.
Spots, scratches, marks on the page. If they are random, this indicates a problem with toner scatter.If they are repeating patterns, measure the distance between matching marks or spots. If the distance is one of 97mm, 47mm or 38mm, this indicates marks or dents on the imaging unit and it will need to be replaced.
You receive the message Replace defective imaging unit The imaging unit is defective and needs to be replaced. If you just installed it, it will be covered under warranty - contact Lexmark Australia on 1300 362 192
You receive the message Reinstall missing or unresponsive imaging unit and the below instructions don't resolve the problem. Try one or more of the following:
  • Check if the imaging unit is missing. If missing, install the imaging unit.For information on installing the imaging unit, see the "Replacing supplies" section of your device's User's Guide
  • If the imaging unit is installed, then remove the unresponsive imaging unit, and then reinstall it.
  • Note: If the message appears after reinstalling the supply, then the imaging unit is defective. Replace the imaging unit.
You receive the message Replace unsupported imaging unit The imaging unit you attempted to install was either non-genuine, or was from a different region. Buy a genuine Lexmark imaging unit from an authorised Lexmark supplier in your country/region.
You receive a 31.6x error One of the following errors is shown on the display:
31.60 Imaging unit smart chip error
31.61 Imaging unit I2C packet timeout
31.62 Imaging unit I2C packet has been sent but code timed-out on receiving the data (callback)
31.63 Imaging unit security error in the send challenge sequence
31.64 Imaging unit ROM signature error
31.65 Imaging unit stuck busy (status register and/or CRI Arbiter register report busy)
31.66 Toner failed to replenish into the imaging unit
In this case you need to ensure that the imaging unit is properly installed. If yes, check if the imaging unit is supported. Replace with a supported imaging unit if necessary.
If the problem remains, you will need to organise a Lexmark service call (Australia 1300 362 192)
You receive error message 32.11 Imaging unit smart chip compatibility error This could be caused by an unsupported imaging unit (non-genuine or incorrect region). Replace with correct imaging unit to clear this error. If your imaging unit is supported, you will need to organise a Lexmark service call (Australia 1300 362 192).
You receive error message 84 Imaging unit low If expected, replace the imaging unit. If unexpected, call Lexmark Support (Australia 1300 362 192)
Jan 23, 2017 | Office Equipment & Supplies
Lexmark 1270 All In One Printer, Scanner, Fax
I suspect it is because the print buffer in the printer is not being flushed properly and the document is sort of getting hung in limbo between the computer and printer.
the only way to clear cue is either re-start, disconnect the printer from the computer, or turn the printer off. Sometimes you may need to unplug it as well.
Mar 03, 2008 | Lexmark Color JetPrinter Z42 InkJet
Scan a document into Word
Hello
Notepad uses the file extension ".txt"
You can open this file in Word and then choose "Save As" and change it to the Word format (.doc or .docx).
I would assume the scanning feature is using OCR (optical character recognition) and, after the scan, the default is to save it in a .txt format so it will open in almost any computer.
You can set your computer to use Word to open .TXT files automatically. You would still have to choose the "Save As" and change the format to Word before you can make meaningful editing changes (elaborate fonts, stationary, etc.) as .TXT files have only the most basic formatting available.
Nov 09, 2013 | Office Equipment & Supplies
How to create index.html while designing web page?
If you are using dreamweaver then dreamweaver will do all of that for you - if not then use notepad and when you save it as a txt file close down notepad and ensure that you have file extensions showing ( my computer --> tools --> folder options --> view
hide extensions for known file types ( untick the checkbox ) and apply as per below
website link
then change the file extension from .txt to either .htm or .html
Apr 28, 2009 | Macromedia Dreamweaver MX 2004
Lexmark x2470 how do i scan
The easiest way to scan to computer is to use the Lexmark Imaging studio Application. This should have been installed at the same time as the driver software. In the Imaging studio you have several options. Select SCAN and follow the prompts. For example to scan a photo select SCAN. On the next page select -send scanned image to: Lexmark Photo Editor. Below that it will say "what is Being scanned" select the appropriate button and click the "scan now" button.You can also use the - send scanned image to: - drop down box to send the image directly to another application such as WORD, PAINT, clipboard, file or fax. If you have any problems that are more specific contact me or another tech on the chat line for help.
Dec 16, 2008 | Lexmark X2470 All-In-One InkJet Printer
When i log on a message........device monitor application has encountered a problem and needs to close.........this is causing problems for me as some things (like messenger doesnt work)
Try these steps:
  1. Download the printer driver from the Lexmark website.
  2. Unzip the files but do NOT install the printer using the downloaded driver. Cancel the installation that starts.
  3. Go to the C drive and open the LXK.... folder.
  4. Go to driver and then to win Xp_2k.
  5. Open the View menu and select Details. Details of the file are displayed in columns in the right-side pane. Look for the SETUP INFORMATION file in the Type column.
  6. Open the notepad file in the Name column to its left.
  7. Click Edit, Find and look for the entry that begins:
    LanguageMonitor=
  8. Add a semicolon (;) at the beginning of the entry. NOTE: The semicolon disables the entry.
  9. There are two instances of the word LanguageMonitor in the file. You will need to place a semicolon (;) before itin both places. (Use Edit, Find Next to locate the second instance of the word.)
  10. Click File and select Save. Close the notepad file.
  11. Now look for the CONFIGURATION SETTINGS file in the Type column. Repeat steps 6 through 10 above with this file also.
  12. Go to the Control Panel and select Printers and Faxes.
  13. Open Add Printer. When the Browse option appears, follow the steps for installing the printer using the INF file from the C drive.
  14. DO NOT try to print a test page as a communication error may result. First you need to change the spooler settings. Do the following:
    1. Go to the Control Panel and double-click on the Printers folder.
    2. Right-click on the printer icon and select Properties.
    3. Click the Advanced tab and select Print Processor.
    4. Change the Print Processor to Winprint and the Default Data Type to Raw.
    5. Click Apply and OK.
    6. Attempt to print a document.
Good luck..
Dec 16, 2008 | Lexmark X5150 All-In-One InkJet Printer
I have a Lexmark x2470 and it works great. But ever since I got it I have never figured out how to scan to computer. Can you help?
The easiest way to scan to computer is to use the Lexmark Imaging studio Application. This should have been installed at the same time as the driver software. In the Imaging studio you have several options. Select SCAN and follow the prompts. For example to scan a photo select SCAN. On the next page select -send scanned image to: Lexmark Photo Editor. Below that it will say "what is Beig scanned" select the appropriate button and click the "scan now" button.You can also use the - send scanned image to: - drop down box to send the image directly to another application such as WORD, PAINT, clipboard, file or fax. If you have any problems that are more specific contact me or another tech on the chat line for help.
Dec 01, 2008 | Lexmark X2470 All-In-One InkJet Printer
Won't scan
1. From CONTROL PANEL choose ADD REMOVE PROGRAMS
2. Uninstal ALL Lexmark stuff.
3. Reboot
4. Download latest software from lexmark.com for your scanner.
5. Install ONLY the latest driver (not from your CD)
6. Reboot.
7. Good luck!
Aug 04, 2008 | Lexmark X3550 All-In-One Printer
I am trying to use a Z705 color jetprinter, but cannot get it to print from the pc. I can print from notepad (not using the print file from the tool bar but from the notepad file. I have tried everything....
May be you are not installed well the software driver of the printer. First check the test page of the printer.
For test page see the option of the printer icon.right click icon goto the properties and click test page. Then it will not print well after that put the driver cd into the cd drive and install the software.try it and if the prob comes again please inform to fixya.com
May 12, 2008 | Computers & Internet
Lexmark 5400 series
Problem: Lexmark cannot retrieve applications list
I have the Lexmark X3550 with the WiFi option board installed (makes it same as the model X4550) and get the “cannot retrieve applications list” message on one of the five computers connected to my router (Linlsys WRT54G V8) and using wireless printing and scanning. Just like everyone else with a similar Lexmark WiFi printer/scanner, I can print wireless, but cannot get the wireless scanner to work on one of my PCs.
The fix, in my case, was to change the Lexmark network name as follows.
1. Launch Lexmark Imaging Studio.
2. Right-Click on “View or change network settings”.
3. Enter a new network name in the first box shown. (This box contained the correct network name for my PC, but another name was needed to make the scanner work. I simply added “-lex” at the end of the current network name.)
4. Right-Click OK. You should return to the Imaging Studio screen.
5. Close the Lexmark Imaging Studio window. (The tray icon should remain at the screen lower right.)
6. On the printer, press the Scan Mode button.
7. On the printer’s display screen, select the Computer Name that you entered for the new network name. Just use the arrow buttons until the exact name is shown.
8. Press the Check button. The display screen should show “Downloading Applications List”. Within about 10 seconds the message should change to “ *Scan to Computer ”. Wireless scanning should now work.
9.. Press the Start Color or Start Black button. “Requesting Scan” will be shown. After a few seconds scanning will start. The process is a bit slow.
10. After a while you may see an empty small Lexmark window onscreen. Later, the Lexmark Imaging Studio will appear onscreen, then change to show many options and features. An image of the scanned item will appear in a Lexmark window. Save and/or edit the image. Another scan can be done by pressing the printer’s Check button again. Be sure the correct computer name is shown on the printer’s display.
That’s it. A new computer name was the solution. Your PC and printer may require a restart (power off) after changing the “computer name”.
Regards, Fbyrd
Mar 12, 2008 | HP PSC 2210 All-In-One InkJet Printer
Lexmark X2350 All-In-One InkJet Printer Logo
362 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
