Question about Minka Aire F602-BNCH Gyro? Fan
How to clean the blades inside the cage of a minka gyro ceiling fan
2 Suggested Answers
RyanFanMan
  • 342 Answers
SOURCE: cannot figure out how to
there is a band around the cage that you have to remove that takes some paitence but that should fix it
Posted on Jan 01, 2011
Minka f502 is noisy - how do you tighten the screws that attach the fan blade to the motor hub?
With a screw driver? And perhaps you also clean all blades. Sorry if you already did that.
Mar 16, 2015 | Minka Aire Ceiling Fans Gyro Traditional...
How do you tighten the fan blade to the motor hub. My fan is noisy.
Probably need to take the screen cover off then the bottom of the small motor to see if you can get to the screws. Or call Minka Aire @ 1-800-307-3267
Minka aire gyro fan quit oprating
Contact Minka Aire @ 1-800-307-3267. You might have to ship it back to Minka for repair or replacement depending how old it is. fanman9952@aol.com
Feb 28, 2014 | Minka Dryers
Noise from one of the fans on gyro fan
Please see my Solution to the post about the "HOT" motor, with blades that don't turn.
The Minka Aire Gyro fan heads do NOT have any exposed screws that can be tightened. Checking the rear (wood color) pointy trim piece -- first loosen, turn fan blades a bit, then it. tighten back up.
If your fan was just fine before, and now it's cranky, the problem could be the motor head's "tweaked" out of balance: EITHER from the rear trim piece (see above), or from the twin support arms. OR, the fan head has somehow gotten off-kilter and is whirling out of balance.
FIRST, gently rock each fan blade - they are PVC plastic, not wood, and should not Warp. Do they all look the same? Do they feel snug or loose in the fan head? IF that's all good...
1) With the fan OFF, swing that motor head thru it's up and down range a few times, make sure it's moving like the good one.
2) do the above-mentioned pointy trim piece thing, and the "swing thru" thing; rec-check BY HAND to see if it's corrected.
3) If not, check for fan head wobble by slowly turning the blade (fan head) and see if it's running parallel to the motor head. IF NOT, use a thin plastic (spatula) and gently wedge the kiltered side back to parallel - recheck afte each "nudge". It should spin nice and flat with no wobble, and not feel loose, either!
BY HAND: Spin the blades fast - does it bang? NO? great!
Yes? Double check that the grill hasn't gotten banged, and pushing into the blade's path. Re-try the "adjustment" of the fan head - if it still does not remove the problem, then the internal motor shaft supports may be loose, or broken.
Hope this Helps!
Jun 08, 2009 | Minka Aire F602-BNCH Gyro? Fan
Minka aire f602
There are tiny dip switches on the remote as well as on the receiver. Make sure they are set to the same sequence. The receiver is the black box that all the wires connect to in the ceiling.
Nov 02, 2008 | Minka Aire F602-BNCH Gyro? Fan
Traditional Gyro by Minka Aire - Just installed and does not work
I would triple check that the wiring is correct, then I would check the dip switches on the receiver and the wall switch to make sure they are set the same.
Apr 28, 2008 | Minka Aire F602-BNCH Gyro? Fan
Parts
Talk to customer service or sales. They can probably sell you those parts.
HEADQUARTERS
1151 W. Bradford Ct.
Corona, CA 92882
EAST COAST DISTRIBUTION CENTER
9348 D. Ducks Lane
Charlotte, NC 28273
--> TEL: +1 (951) 735-9220
FAX: +1 (951) 735-9758
EMAIL:
SALES DEPARTMENT:
sales@minkagroup.net
CUSTOMER CARE DEPARTMENT:
minkalaverycustomercare@minkagroup.net
Nov 10, 2007 | Minka Aire F602-BNCH Gyro? Fan
Minka Aire F602-BNCH Gyro? Fan Logo
107 people viewed this question
Top Minka Dryers Experts
Joseph Coppeto
Joseph Coppeto
Are you a Minka Dryer Expert? Answer questions, earn points and help others
