I recently tried the DIY service and repair manuals from a website and it actually helped me repair transmission problem in my jcb 3cx site-master. It wont
move forward or reverse, engine is good both solenoids for forward and reverse work.
I don't have much technical knowledge but I just followed it step-wise, and works perfect! got it from www.reliable-store.comAll the best
Play / Pause is on the left (in your picture).
Stop is next to it,
Then Fast Reverse (hit more than once for even faster reverse)
Then Fast Forward (hit more than once for even faster forward)
I tried the DIY service and repair manuals from a website and it actually helped me repair transmission problem in my jcb 3cx site-master. it wont move forward or reverse, engine is good both solenoids for forward and reverse work.
Put the vehicle in Park, disconnect the shifter from the shift lever on the trans, adjust the linkage or cable so the connection is clearly a slip in/on connection and tighten things back up. Hopefully this will solve your non-reverse. As for all the gunk and metal shavings, friend, you better have another tranny standing by in your garage when this one stops working completely.
Yes! The FastLane brand works. I thought my bounce back was a loss because the remote doesn't work until my older daughter played with her remote control car in the same room. The Tonka Bounce Back responded very well to the FastLane remote. And fortunately, FastLane is pretty inexpensive. Good Luck!
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
This is basically the same problem with a Hoover power drive only the forward still drives albeit slowly and a slight "push" to keep it going. There has to be a common core type of drive failure !!
