Question about Texas Instruments TI-84 Plus Calculator
The table on my ti 84 has the X's counting be .5. how do i set it to count by 1
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Press 2ND [TBLSET] and change the delta-Tbl to 1. "delta" is an up-pointing triangle.
Posted on Nov 12, 2010
  • kakima Nov 13, 2010
    Let me also add that if you're viewing a table, you can press the key to change the delta-Tbl value.
I'm using a Ti-84 plus and when I try simple division it gives incorrect answers. For example, when I enter 5/2 it answers 3. When I entered 50/100 it answers 1.
You apparently have your calculator set to display no digits to the right of the decimal point. 5/2 is 2.5, which rounds to 3, and 50/100 is 0.5, which rounds to 1.
To change the display setting, press MODE, highlight the desired settings on the first two lines, then press ENTER followed by 2ND QUIT. Try setting "NORMAL" and "FLOAT" and see what results you get now.
Oct 06, 2013 | Texas Instruments TI-84 Plus Calculator
Tip
Show Routing Table button will open a chart displaying how data is routed...
Show Routing Table button will open a chart displaying how data is routed through your LAN. Use the example below on how to configure a static routing:
STATIC ROUTING:
192.168.2.2 192.168.1.2
ROUTER C ----------------- ROUTER B ----------------- ROUTER A--------------PUBLIC IP ADDRESS
192.168.3.1 192.168.2.1 192.168.1.1
ROUTER A: Gateway Mode ROUTER C: Router Mode
1STENTRY 1ST ENTRY
DESIP: 192.168.2.0 DES IP: 192.168.2.0
SM: 24 SM: 24
DG: 192.168.1.2 DG: 192.168.2.2
HOP COUNT: 2 HOP COUNT: 3
INTERFACE: LAN INTERFACE: WAN
2NDENTRY 2ND ENTRY
DESIP: 192.168.3.0 DES IP: 192.168.1.0
SM: 24 SM: 24
HOP COUNT: 3 HOP COUNT: 2
ROUTER B: Router Mode
1STENTRY
DESIP: 192.168.1.0 WAN IP: 192.168.1.2
SM: 24 SM: 24
DG: 192.168.1.2 DG: 192.168.1.1
HOP COUNT: 2 DNS: DNS of 1st router
INTERFACE: WAN
2NDENTRY
DESIP: 192.168.3.0
SM: 24
DG: 192.168.2.2
HOP COUNT: 2
INTERFACE: LAN
1stRouter must be set on Gateway Mode
2ndRouter must be on Router Mode
Use Static Routing
Select Entry
Destination IP = IP Subnet of the 1st Router
Subnet Mask = Subnet Mask of the 1st Router
Default Gateway = Interface IP
Hop Count = 1 + n
Interface= Connection to the 1st Router
Hope this help everyone.
on Apr 22, 2010 | Computers & Internet
Callpilot will not answer calls
Check AA/LINES
i.e. Line 1 is 001 in programming
line 5 to 8 on older systems is 025 to 028
If you recorded Grtg # 1 then go to Table 1 and make Morn etc play #1
Then check AA/lines and make sure AA = Y and Table = 1 and Ring count set to 0 (or 2 if caller id at site).
Reboot system perhaps.
Nov 24, 2012 | NorStar CallPilot 100
My TI-84 won't let me input x values on the table feature and has a bunch of numbers in the x-column
Press 2ND [TBLSET], then use the arrow keys to highlight "Ask" on the "Indpnt" row, press ENTER then 2ND [QUIT].
Aug 24, 2012 | Texas Instruments TI-84 Plus Calculator
My TI 84 won't convert my imaginary numbers to fractions. I typed in 1/(1+i) and it won't convert the answer to fraction form. It keeps saying Error Data Type
The TI-84 works with real fractions. It will not convert complex numbers to fractions.
You can convert the real and imaginary components to fractions separately. For your example, 1/(1+i) is .5-.5i. Converting .5 and -.5 to fractions, you get 1/2 + (1/2)i.
Sep 15, 2011 | Texas Instruments TI-84 Plus Calculator
How many grams of aluminum acetate contain 2.24 x 1022 atoms of hydrogen?
1 Look up the formula for the aluminum acetate.
2 Count the number of Hydrogen atoms per molecule: Call that nH.
3 Dividing 2.24*10^22 by nH you get the number of molecules of acetate.
4. Divide that number by Avogadro's Number to obtain the number of moles required.
5. Multiply the number of moles by the molecular mass of the aluminum acetate (look it up or use the periodic table to calculate it), you will get the mass of aluminum acetate that contains 2.24*10^22 hydrogen atoms.
Sep 14, 2011 | Texas Instruments TI-84 Plus Calculator
The value of (3/1000+4/10+5/100+2/1) in decimal is
2.408
Press 3 / 1 0 0 0 + 4 / 1 0 + 5 / 1 0 0 + 2 / 1 ENTER on your TI-84
Aug 08, 2011 | Texas Instruments TI-84 Plus Calculator
Where is the apps key on a TI-84 Silver edition?
Fourth row (third if you don't count the function keys), second column from the left. It's just to the right of the MATH key, or diagonally down and right from the green ALPHA key.
Oct 07, 2010 | Texas Instruments TI-84 Plus Silver...
My lexmark printer gives me an error '' 84 Replace photoconductor'', I replaced ink cartridge then turned it off, restarted and still the same errow please help. Thank You
With most all lexmark printers, the photocondutor is set by page count. If it was printing fine with no black streaks then you can just reset the count and it will start working again. If it had black streaks then you will need to purchase a photocondutor kit which comes with the instructions on how to reset the count...but normally it is a combination of a couple of things.
1. Turn the printer off.
2. Push and hold down the Select and Return button if it has them....and turn the power on while holding them down......wait until it says Reset PC Count...then push select....it should say resetting PC count. I generally do that twice....just to be sure....then Turn the printer off....and back on the light should be off and the printer should work just fine.
Jul 07, 2009 | Lexmark E350dt Laser Printer
Texas Instruments TI-84 Plus Calculator Logo
133 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
