I receive an error code F01 on my Kenmore Duet Sport
  • Anonymous Aug 12, 2008
    I just bought a Duet today and tried to start my first load of wash and received an error code F 01
    I have Canceled the wash turn off power at the switch and tried again and then un-plugged it waited and tried again and still I get the F 01 error
  • 246 Answers
If memory serves me correctly this is a main control board error. To find out for sure, Remove the lower front panel of the washer. (the 1/4 screws are across the bottom) Just inside that panel is a tech manual. Skip to the error code section. For an F01, the steps should be unplugging it for 2 1/2 minutes (to reset the Triacc (part of the main circuit board). I would also pop the top cover (the screws are in the back) and check for any loose connections on your main circuit board ( front top, right hand corner) WARNING - Circuit boards are delicate and an static shock could ruin them. Ground yourself before touching the connections. If all steps fail, you can contact a local servicer. I only suggest this because I have found there are other things (not printed in the tech manual) that will give a false f01 error code. Make sure they give you a warranty for thier work. If you would like to replace the board yourself, they can be obtained from the local appliance parts supply stores or online form the manufacture.
Posted on Jun 18, 2008
Sears Electric Dryer is flashing F01 What is wrong?
The F01 indicates a failed electronic machine control board. This error code can sometimes be caused by a glitch or power surge through the electrical lines. You may be able to clear this code by unplugging the washer for 5 minutes. If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
You can order a new control board from the Sears PartsDirect website.
http://www.searspartsdirect.com/partsdir...
Here's how to do it: http://media.fotki.com/1_p,wkwdftgtbkdgf...
Error code on dryer F01 - Kenmore Elite HE3 Dryer - iFixit
https://www.ifixit.com/.../Error+code+on+dryer+F01 Traduire cette page The F01 indicates a failed electronic machine control board. This error code can ... The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Dryer Sears / Kenmore HE3 - F01 Error Code Main Circuit ...
2q==? 7:35 https://www.youtube.com/watch?v=eWqrn5klxm0 20 avr. 2015 - Ajout? par Jim Dandy Sears Kenmore Dryer Model HE3 - F01 Error Code. Main Circuit Board Repair - Electronic Control Board ...
Error code F1 on Kenmore HE2 electric dryer appeared ...
www.shopyourway.com > ... > Questions Traduire cette page Sears Kenmore HE2 electric dryer; model #11087571601. F1 error message appeared ... Power it back up and see if you still get the F01 error code. If not, then I ...
What does the error code F-01 mean on my Kenmore front ...
www.shopyourway.com > ... > Questions Traduire cette page By unplugging and plugging in the electrical cord, I got the dryer to work again. ... What does the error code F-01 mean on my Kenmore front loaded HE2 dryer? ... My kenmore washing machine 110.46462500 is flashing an error code F.01 ...
Feb 04, 2016 | Sears Kenmore Elite Electric Dryer 69278
I have a whirlpool duet washer WfW94hexr2 and it wont start. It gives me the error code F01 and E02. Help
First check all connections between the mcu and the ccu, remove the top cover by removing the two screws in the rear of the top cover pull and remove. If after checking and still the same, you might want to also Check the motor for the correct ohms. You might need to have a service tech to come out.
May 15, 2014 | Whirlpool Duet Sport HT WFW8400TE Washer
Whirlpool Duet Sport F21, F01, SD
Drain pump may be clogged or need to be replaced may run but not pump blade stripped in pump
Apr 28, 2017 | Whirlpool Duet 3.8 cu. ft. Front Load...
Maytag model MEDE500VPO what does the f 01 code mean?
Controller board malfunctioning.
Try looking at the video at
Duet Sport Dryer 2008 Error code 01
If repairs like this are not something you want to attempt, try calling a repairman, particularly if the dryer is under warranty.
Jan 04, 2012 | Dryers
Whirlpool Duet Sport Model WFW8300SW0 basket won't
The following list of codes indicates an electronics communication problem with the washer: - Duet HT washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
I would first replace the door latch/lock assembly, a number of users have and it fixed the F-11 error code completely. Its the cheapest part for this problem.
Hope helps.
Jun 27, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
Duet code f-01 is showing.
Hi
Thanks for using FixYa. Error F01 in your whirlpool duet sport indicates EEPROM error which means that a communication error between the Central Control Unit (CCU)
and the EEPROM onboard the CCU occurred. This error also occurs when the pump driver fails to activate and/or one of the main relays is not working. To resolve this issue leave the unit unplugged for 5-10 minutes so that if this was caused due to power surge it is cleared. Also check the CCU (central control unit), if bad you’ll have to replace it.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer codes F01/F33, have cleaned the pump and
The F33 error code indicates a pump drive system error. If the pump ohms out correctly & the harness is secure I recommend replacing the CCU (central control unit).
Please see the following image provided for instructions.
http://media.fotki.com/1_p,stwwfrggtqfbrbbxgtqsskgwtqkq,vi/wgtbwqwssxsbwkbdtfwxrbfbddwwf/1/1303472/5961857/image9159087223444281043img-or.jpg
Remember to disconnect power to the washer before attempting access.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Jun 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport f-01 even after replacing CCU
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
Jan 01, 2010 | Whirlpool WFW8300SW
Washing Machines Logo
647 people viewed this question
Top Washing Machines Experts
