Question about Watches
How to set the time on an oceanus 4330 - Watches
How to set the time on a casio 4364
Hi jmalone1961,
I see that you need assistance on getting to set the time on your Casio 4364 watch.
I have put a link to where you can acquire the User Manual for this watch, I would like to type in the details but there will be so much that it may get more confusing if I translate the manual.
Pleasee the link below.
http://www.oceanus-us.com/support/downloads/manuals/module_4364.pdf
Thanks,
mvincentc
Apr 30, 2011 | Casio Watches
I nedd to set the time and dont have my book
Pull the crown in 1st position. turn it cw and ccw. see what happens. now press the buttons one at a time. see what happens again. now pull the crown in 2nd position and again turn it. observe. push the buttons again. see what happens with your watch. you should figure out what everything does on yourself without needing a book. good luck!
Mar 01, 2011 | Casio OC-500 Oceanus Watch
I am trying to set the correct time on the Casio Oceanus 4364 but can't get it to timesetting mode correctly.
For all those who lost their Casio watch manual. Follow this link, fill in the requested details and download manual. http://world.casio.com/wat/download/en/manual/
Nov 14, 2010 | Casio OC500 Oceanus watch
Hallo, i bought casio oceanus ocw 650 T and i cann not set up the time manually. All hands are on starting position 12 o clock. Can you help me, can you send me email on dusan.gulic@post.sk? THX. GUlic...
You can get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals", watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Click on "search" and the download your instructions.
Feb 23, 2010 | Casio OC500 Oceanus watch
How can I change the battery in my Casio Oceanus Oc-501? What battery does it take please and do I need to reseal the back?
I dont recommend anyone change their own battery unless they have the proper tools to open and close it! If the case back unscrews then you need a case wrench...if it pops off with a knife then you will need a case press to close it or else risk breaking the crystal! Most require equal pressure around the entire edge of the case back! Save yourself time and frustration and possible damage and take it to a reputable watch repair shop!
Jan 19, 2010 | Casio Oceanus Watch OC503
My Oceanus watch model no. 4749 stays 1/2 hr slow. I manually reset it to the correct time and it resets itself to 1/2 hr slow. I have it set at central time
You can get manual information from the Oceanus web site (NOT casio strangely enough!).
Insert "www.oceanus-us.com/" into your search engine
Select "support", then "Manual information"
Enter your model number and download the information. There are instructions on choice of home city and further adjustments if it still is not correct after initial setting up.
Jan 16, 2010 | Casio OC500 Oceanus watch
Minut indicator is out of sync. Reset sets cursor
1. Look in the back of your watch, it will show the model number (in a square on top of "CASIO")
2. Look at this web page for the right manual:http://www.oceanus-us.com/index.php?fuseaction=support.content&CNT_ID=14884814-F2AB-46E6-93DC-5E678BD11926
3. Look at the section "Adjusting the Home Positions" - that is where the answer is.
Nov 03, 2009 | Casio OC500 Oceanus watch
Changing the band on my casio oceanus 500 wristwatch
If its an OC500, I just figured it out. There are two sides of the pin visible. One has a dimple and one is completely smooth. Use a small phillips or a punch that is the same diameter as the pin and push on the side with the dimple. The pin pushs in only about 1/4 inch and the smooth side protrudes from the other end. Pull or pry on the smooth end to extract it. The pin is actually 2 parts so be careful not to lose the dimple side piece.
Nov 14, 2008 | Casio OC500 Oceanus watch
I NEED A WRIST BAN A CASIO OCEANUS 0 C 500
i just found some on ebay... i need one too! $24.95 plus shipping though.. not cheap. just search "oc-500 band"
Feb 02, 2008 | Watches
Watches Logo
195 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
