Question about KLH ASW10-125C Subwoofer
My woofer won't work. The power comes up and I feed it live input. It has worked previously before on numerous ocassions.
  • bereanresear Nov 12, 2010
    This problem is now fixed. Just giggled the "off, auto, on" switch.
Amp power light is on, but sub not making sound ?
If you have power, and the amp has previously worked.
Check your audio input and make sure you do not have any filters on like a sub woofer crossover, that you do not want.
If that still doesn't work try hooking up a different speaker for testing purposes.
I hope this helps
Nov 15, 2016 | Car Audio & Video
Speakers on cinema surround sound working on test only
More than likely the optical connection is defaulting to another source. The optical may have been intentionally assigned to another source and either needs to be reassigned or try switching the inputs on the unit until you hear sound...
Feb 04, 2014 | Logitech Z-5500 Audio Subwoofer Thx...
No I cant get my sub woffer to work woofer.There is power to the unit .I am trying to connest it to a sound bar which has a sub out.
If there is power to the woofer then a signal input must power the woofer to work. So feed a test signal or a audio siignal from a DVD and if there is no output then the AMPLIFIER section had faults.
Unless the sealed unit is opened it cannot be tested to confirm if the output , the input to the AMP or the power supply has failed.
Check if there is power to the output section to confirm.
Jul 29, 2011 | Proficient S12 Subwoofer
Controler and sub woofer no power
This previous diagnostic, isn't good, if you test and no continuity between the positive and negative terminals generally means a blown sub.
You won't always get scratching or distortion from a blown sub. Sometimes the voice coil just overheats and burns out like a fuse. In this case there will be no sound at all from the sub, because no power can flow through the voice coil. A continuity test between the positive and negative terminals will show no connection.
Hope this helps.
Jul 05, 2011 | Audio Players & Recorders
QUESTION ABOUT SPEAKERS. SPRCIFICALY WOOLFER. WHAT KIND OF WOOLFER SHOULD WORK BEST WITH THIS AMP?
hi,
Do you mean sub woofer. Then you can select any brands Active sub woofer ( active means built in amplifier) to connect with your system. They comes in different power (watts). you can use an active sub woofer with 100W output.
connect the sub woofer pre out of you amp to the pre input of sub woofer.
ok
Feb 05, 2011 | Technics SA-EX500 Receiver
LG TV RT29FC85VW 29" woofer not working
Check the Woofer for continuity and also with an external amplifier.
if there is no issues then the sub-woofer power amp IC can be faulty.
Check the main voltage to the IC, if not present the power section must be traced for a line break, fusible link.
If there is power , then test for input signal to the IC. If so the IC can be the supect.
Oct 28, 2010 | LG Televison & Video
Cannot get the sub woofer to work.
Now tell the NAD you have a subwoofer. Page 15, Figure 13, etc. and Page 18 - 19.
Mar 05, 2010 | NAD T770 Receiver
Non powered sub woofer
if you have a in and out on the sub woofer feed one of your speakers in and out of it. I can't believe your rca rec. only has one input and no outs.... if it has built in speakers your out of luck.. unless you want to hardwire it to the sys. by going inside the unit. leave that up to a pro. please
Dec 09, 2009 | Audio Players & Recorders
One speaker wont work
if u have experience with the soldering of the terminals then you can open the speaker casing of the sub woofer and then solder the right speaker input wire.
dont do this if you have no previous experience and DISCONNECT THE POWER SUPPLY before doing any work inside.
Apr 19, 2009 | Logitech Z-2300 2.1 Computer Speaker...
KLH ASW10-125C Subwoofer Logo
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Edwards
Michael Edwards
Level 1 Expert
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
