Question about Kenmore Washing Machines
How do you pull out the timer to a model # 110.26852501
    President:
  • 1,937 Answers
First, see the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11026852501/0582/0153200?pathTaken=
Then see the following Whirlpool / Kenmore Service Manual for top load, direct drive washers:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Also see the following for how to release the console.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=bd565b63d8f8c39014f7aa79d1722163
Depending on the type of timer that you have (See the Whirl[pool manual) you may need to hold the shaft that goes through the timer to the knob with a thin needle nosed pliers in order to un-screw the knob before unbolting the timer.
Posted on Nov 12, 2010
Removing timer knob on maytag washer mav2755aww
It unscrews or if it is a newer model, remove the console so you can tip it forward. You will see a (usually black or white) pin in the center of the timer, pull it out about and inch and then remove the knob from the front by pulling it off the timer shaft. Check you new timer and make sure it comes with one. So did some did not. Good luck.
Mar 28, 2016 | Maytag Washing Machines
Model 59204EV Outdoor Mechanical timer - How do I set it - The pins do not move on my timer - where are the pins located?
Different Woods timers have same model number, depending on who packaged and sold product.
Manuals are sometimes generic. They say pins when they mean segments or tabs.
Segments are small plastic divisions located around outer edge of dial.
They divide 24-hour day into 15 minute or 30 minute periods.
Link below shows sample pins and tabs.
http://waterheatertimer.org/Woods-timers-and-manuals.html#Pins-tabs
With the 15204, I believe these segments pull out or push inward; but they could also pull upward or downward.
Move a couple segments, plug in the timer and lamp, and then manually rotate dial to watch how lamp turns on-off.
Lamp must be turned ON and bulb working.
Some 15204s have a switch on face of timer, or somewhere on timer. Some do not have a switch, and some have a dial. Move switch to TIMER, or to AUTO. Or rotate dial to ON.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer, any do-it-yourself project.
Jan 13, 2011 | Woods INDUSTRIES 59204 OUTDOOR MECHANICAL...
I have woods lighting timer model 59200 and can not program it. every I set the time according to the instruction light stays on. What I am doing wrong?
See Woods timers:
Are you sure about that model number?
59200 is a plug-in dial-type timer.
Timer does not have a light.
The dial is rotated to set current time.
And segments located around dial are pulled up and pushed down to set timer function.
http://waterheatertimer.org/pdf/Woods-59200.pdf
Add a comment with description of your so I can locate manual and help.
Nov 21, 2010 | Woods 2C 24 Hour Indoor Mechanical Timer...
I have a Kenmore gas dryer model 97591220. wont
Disconnect power to the dryer and remove the screws attaching the console rear panel to the console and pull the panel off.
Inspect the wires connected to the timer and ensure a snug fit connection. Clean the connectors and terminals then reseat it several times to ward off dirt within the connectors.
Reconnect power to the dryer and start it; replace the timer (part number 3398195 ) if the dryer still won't stay running. Unplug the dryer and pull the timer knob off the console. Remove the screws securing the timer to the bracket and remove it. Secure the new timer in place then disconnect the wires from the old timer one at a time and connect it to the corresponding terminal on the new timer.
Push the timer back into position on the console and secure the console rear panel in place.
Apr 14, 2010 | Dryers
Timer not working
Hello there:
The timer push/pull switch : The timer push/pull switch is the main switch in the timer. If this switch fails, the complete timer has to be replace.
To check the this timer switch, you will need to set your multimeter to read ohms. Set the timer on the biginning of a cycle and pull the knob to turn the switch to the on position.
Open the controls panel, take a reading between the Black wire on the cord connecting block and the violet wire on the water level switch connecting block. The reading should be about 0 ohms, If the reading is infinity, the timer is bad and you will need to replace the timer.
If any of the above mention parts is not working properly, the washer will not work at all.
If this is found to be bad the timer will cost about 60 to 80 dollars ok
Hope this informatin has been very helpful for you
Best regards Michael
Dec 31, 2009 | Kenmore Washing Machines
Setting GE Plug in mechanical timer 24 Hr Model 15119 instructions
pull the pins up for off, down for all, so pull all the pins up then push down the pins for the time you wan the time on
Dec 13, 2009 | General Electric GE 24-Hour Timer, 2-Pin...
How do I set the ge timer model #15119. husband
I tried to pull the whole dial and doing that I discovered that the border of the dial is composed by pins that you can pull it up each independently, with your nail or with any pointing device. The rest is easy: get sure the switch is set at "timer on", turn the dial to the current time using the black triangle mark and pull the pin up in the time you want your device to disconnect.
Dec 08, 2009 | General Electric GE 24-Hour Timer, 2-Pin...
Timer won't turn off or on by itself
Pull the pin up wait and see if it comes on you will know then. Most do pull up but there are a few that have the pin that has to be shoved in. 90% however do have to be pulled up to set the timer for off and on.
Oct 02, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
TIMER NOT WORKING
The knob does not pull out on dryers. Turn the timer to the desired setting and push the start button. Eric
Sep 10, 2009 | Dryers
Timer knob
some models you remove center cap on knob and pull pin out others you need to remove screws in console and lean in forward to acess rear of timer push knob in pull small pin in back of timer and then pull knob off
May 21, 2008 | Maytag Performa PAV3200
Washing Machines Logo
88 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
