Case switch connected to motherboard is messed up. i need a new switch for the case or the configuration for the pins on the motherboard to be able to use a new case/new switch
  • Computers & ... Master
  • 5,660 Answers
The Power On switch is located inside the plastic Power On button assembly.
It is a Momentary Contact Switch, and is named an ATX power on switch.
This ATX Power On switch I have found fits many computers,
http://www.directron.com/atxswitch.html
The plastic front panel of a desktop computer is the Front Panel.
The pin area on the motherboard, that the cables (Wires) from the Front Panel connect to, is the Front Panel header.
Tell me the manufacturer name, and Model Number of the computer, or tell me the manufacturer name, and Model Number of the motherboard, and let me see if I can find a Pinout for it's Front Panel header.
(What pins the cables connect to)
Post in a Comment.
Posted on Nov 12, 2010
New case and new motherboard, when trying to turn on computer, power button doesnt work
Carefully double check the connection header pins and the leads that come from the front panel for LEDS indicators and push button switches. The motherboard manual will indicate what the numbering scheme is for the header pins (which pin is #1, etc.) and where they are physically located on the board itself. You may have simply connected one or more switches and indicators to the wrong pin. Getting them straight should solve the problem.
Mar 19, 2010 | ASUS M2N68-AM SE2 Motherboard
Need front panel connection diagram power switch lrf connectipns on 9 pin connector on motherboard
Hi u can easily solve this problem.
open your computer cover and and see the motherboard front panel connectors. a use of screw driver touch any two front panel connectors if any led or switch working this condition you can note this and connect successfully. one by one touch all penal connections and u will be solve ur problem thanks mukesh kumar
mukesh_ibm@yahoo.com
May 12, 2009 | ASUS Computers & Internet
Instructions on atx case wiring to motherboard
Assuming that the computer is laying down on it's right side, and you are viewing the F panel (the front panel header) from the right side of the motherboard (the bottom of the computer), pin 1 is on the bottom left of the F panel, pin 2 is on the top left, pin 9 is on the lower right, and pin 10 is on the top right (no actual pin)...
1 HD_LED_P Hard disk LED (+) 2 FP PWR/SLP *MSG LED (+)
3 HD_LED_N Hard disk LED (-)
5 RST_SW_N Reset Switch (-)
7 RST_SW_P Reset Switch (+)
9 RSVD Reserved
4 FP PWR/SLP *MSG LED (-)
6 PWR_SW_P Power Switch (+)
8 PWR_SW_N Power Switch (-)
10 Key No pin
Usually the wires and the pins are color coded, (the colored ones being positive.) Sometimes the connections are written in very small abbreviations on the motherboard.
Jan 28, 2009 | EliteGroup ECS A780GM-A Motherboard - AMD...
I need to know how to set my pin configure for off/on switch motherboard is a asus p4sgx-mx thanks sm1
on most of the motherboards it is stated about the pins. in case you connot find it on motherboard it will be in the manual.
Dec 04, 2008 | Computers & Internet
Connecting the case to my motherboard
Pin arrangment is Industry Standard Architecture.....
pwr led pwr sw N/C
X X X X O
X X X X O
hdd rst N/C
translated this is top row left to right ...... power led, power switch no connection
Bottom row is left to right........ hard drive, reset, no connection
Note: not all computer cases have a reset button, also the connectors for power led and hard drive produce a light, if the light does not show, power off the pc swithc the cable rooun 180deg on the connector pins and reconnect.
Pin connections on the motherboard of Acer Aspire AX3200-U3600A
You'll need to know the model of your motherboard, and search for the motherboard manual in the internet if you don't have one.. in the manual search about the power pin connections and you will see where to connect those wires into the pin..TY
HOPE I CAN HELP
How to connect front pannel
How about a picture? Pg. 46 in your manual.
Need manual, download from Intel. (Click on link).
http://www.intel.com/support/motherboards/desktop/RC440BX/sb/CS-013608.htm
Intel RC440BX Specification
Pg. 46
Basic rules case wiring. The color black is considered ground -. Power wires + can be any other color including stripped wires. (This is standard but case Mfg change to their own specification).
Pin 1 is + power for LED Hard drive green LED, Pin 2 is -/ground for Hard drive LED.
(Pin 3 is + power for LED Hard drive yellow LED, Pin 4 is -/ground for Hard drive LED).(See more options on pg. 47).
Pin 5 is + power for case On/off button, Pin 6 is -/ground On/off button.
Pin 7 is + power for Reset Switch, Pin 8 is -/ground for Reset Switch.
Once positive & negative pins has been located each connector follows in suit.
The Intel RC440BX front case connector is in an odd location.
The user will find it hard to connect front case LED connectors while the board in installed into the case.
Good Luck!
Mike
Apr 25, 2008 | Intel Desktop Board RC440BX...
EMachines Imperial GL VE-20021218 Motherboard Pin Out
Normally on the board there is silk printing to state what connection goes where. Also on the black connector i.e. power LED there is a small arrow that goes to pin 1 of the POWER LED pins.
Hope that was any help thanks J
Jan 20, 2008 | Computers & Internet
Led pins
I think you will have the an instruction manual of Packard Bell imedia 5106.In the manual an outline of the motherboard will be given.Figure out power and reset pins in the diagram given.
Usually the pins are at the corners only.
There will be labels near the pins like pwr rst etc.
Try connecting in the same configuration.
Please Rate me ;-) >Karatela
Dec 07, 2007 | Intel Motherboard
Motherboard pin config
All motherboards have a print beside the pins, Speaker= "speak", "pwr s" =powerswitch, "HDDled" red light on front, rst = reset switch [not allways used] "pwr led" Green led, the case wires are usualy marked on the plug ends with the same , "hdd" "reset" and so on. The power switch will work both way's around however the led lights wont. You will not hurt anything if they are the wrong way around, they just wont work so if you dont get lights just reverse the polarity. If by chance the case wires do not have labels the just trace them to the case front panel and plug them into the corresponding board pins. Regards mistyman
Aug 28, 2007 | Systemax Ascent PC Desktop
Computers & Internet Logo
488 people viewed this question
David Payne
David Payne
