Question about RCA H100 MP3 Player
PLaylists? Is there a way to create a playlist within this player and how cuz i cant figure it out. I tried syncing a whole playlist at once it didnt help....
  • 8,596 Answers
This was designed for playlist transfer via Yahoo Music engine (see user's manual) or Windows Media Player 9. Any other method is not guaranteed to work. Did you get an error message when you tried to sync the playlist?
Posted on Jun 18, 2008
How do i copy music to my mp3
You can sync your music and pictures to your player using Windows Media Player.
By default, Windows Media Player automatically loads all the music and picture files
stored in your My Music and My Pictures folders into the library. If you add new files to
these folders, they will also be automatically added to the library.
If Windows Media Player has selected to sync your device automatically, you can choose not to sync your entire media library. You can choose what you wish to sync from existing
playlists or create new playlists. These playlists you have selected will then sync to your player every time you connect it to your computer.
1 Click the down arrow beneath the Sync tab and select Philips GoGear SA60xx > Set Up Sync.
> The Device Setup dialog box appears.
2 In the Available playlists pane, select the existing playlists you want to sync and then
click Add.
28
4.3.4 Select files and playlists for Manual Sync
If you sync manually, you must create a list of files and playlists you want to sync. You can also shuffle which files from your playlists to sync to your player.
1 Start Windows Media Player.
2 Switch on your player and then connect it to your computer using the supplied USB cable.
3 Click the Sync tab.
4 Drag the files and playlists that you want to sync from the Contents pane to the Sync List pane. You can also right-click on the file or playlist and select Add to "Sync List".
3 To create a playlist, click New Auto Playlist and follow the steps on the screen to specify criteria for files in the auto playlist (for details on how to create an auto playlist,
4 To remove a playlist, click the playlist in the list of Playlists to sync, and then click Remove.
5 In the Playlists to sync pane, select a playlist and click the Priority arrows to arrange
them in the order that you want them to sync.
Feb 12, 2011 | Philips GOGEAR SA6045 MP3 Player
I can't get a playlist onto my Sansa m240. I tried the method described on this site, and the name of the playlist came up, but said it had no files.
Creating Playlist
To create a playlist for Windows Media Player, follow these steps:
1. Launch Windows Media Player.
2. Clear the List pane by clicking the Clear List pane button.
3. Click the arrow below the Library Tab then select Create Playlist.
4. Type in the name of your Playlist.
Loading Content 14
5. Click Songs from Library then drag them from the Details pane to the List
Pane.
6. To rearrange the songs, drag them up or down in the List pane.
7. Click Save Playlist.
Transferring Playlists
To transfer playlists to your Sansa player, follow these steps:
1. Connect your Sansa player to the computer.
2. Select Sync digital media files to this devices using Windows Media
Player on initial connection.
3. Right-click on Your Sansa Player, then select Set Up Sync.
Loading Content 15
4. Select Personal Playlists from the drop down menu on the left pane.
5. Highlight the playlists you want to transfer to your Sansa player, click Add,
then Finish.
6. Synchronization will start as soon as you click Finish. To see the Sync
progress, click on Sync Results.
Dec 05, 2008 | SanDisk Sansa m240 MP3 Player
Philips GoGear SA3245 - Playlists Not Showing Up on Player
Have solved this problem on GoGear syncing with WMP 11 by going to options on the device itself, then go to the "settings" option, scroll down to "PC Connection Preferences", from here you will select the check box saying "MTP" then back out of options and connect your device and go back to your WMP 11 and drag your playlists to the syncing area and resync your device. You should then be able to see your playlists under the playlist option in music along with the "playlist on the go" playlist.
Hope this will help!
- Jared
Determan Technology LLC
Aug 31, 2008 | Philips GoGear SA3245/37 Digital Media...
Sansa m250 playlists
First you need to set your Sansa m250 mp3 player to MTP mode:
) Tap your menu button and select "Settings" > "USB".
2) On this screen, make sure that there is a check next to "Auto Detect" and NOT "MSC".
Note: Music that was transferred to the player in "MSC" (Mass Storage Class) mode will not be accessible once the player is put into MTP mode.
However, the music can still be accessed by switching the player back to MSC mode.
To transfer a playlist using Windows Media Player version 10:
- Make sure device is showing as an "audio device" and in MTP mode
- Create a playlist by right clicking a song in the library, add to>additional playlists>new or by saving a now playing list
- Select the Sync tab and click "Sync settings"
- Check "Synchronize device automatically"
- Set "View" to "All Playlists"
- Place a check next to the playlists they want to transfer to device
- Media Player should then sync those lists once you hit OK.
Once you Sync for the first time a new folder "Playlists" will appear in your m250 using Windows Explorer. Once that folder is created you can even use Windows Explorer alone to create playlists, all you have to do is right click on a song and choose create a playlist. Double click on playlist > Reference Tab, on the window you simply drag and drop your songs.
Hope this helps
Aug 28, 2008 | SanDisk Sansa m250 MP3 Player
Cannot load playlists
Try sync your player with winamp. It synced the whole winamp media library (including playlists). Hope this can help.
Jun 10, 2008 | Samsung YP-K3 MP3 Player
Seperate Playlists
Use Windows Media Player to create the playlist, and then transfer them to the player by dragging the entire folder to the sync window, instead of dragging all of the files within the playlist to the window.
May 31, 2008 | Philips SA1100 MP3 Player
Big problem with play lists
According to the manual for most GoGear's, you have to have automatic synchronization enabled in Windows Media Player for the playlists to transfer correctly.I still have not been able to verify if this is true, since I have been able to transfer playlists fine with and without auto-sync engaged.
I haven't tried a 3115 specifically, but with an SA4111 and an SA5125, I just created the playlist in Windows Media Player 11, right clicked on the playlist name after it was created, selected "Add to Sync List," and then "Start Sync" with GoGear connected. I used this method, because it seemed more likely to add the songs AS A PLAYLIST rather than just dragging and dropping the tracks WITHIN the playlist.
As I look more closely at the documentation for the SA3115, however, it does not have the same playlists options as other GoGear's - it seems to limit you to Playlist-on-the-Go. I know that the GoGear will not recognize folders that you create in Windows Explorer, so that option is out. You can connect the GoGear, and see if a Playlists folder appears in the left-hand pane underneath the icon of the GoGear in the Sync tab. My gut feeling, however, is that this player is just not as equipped as other GoGear models for playlist transfer. I'll go back to the lab on tuesday and see if I can find anything new.
-Tha Mp3 Doctor
May 25, 2008 | Philips GoGear SA178 MP3 Player
Cant transfer a playlist to my sony mp3 player
Windows Media Player (WMP) 11 in XP does not create Playlist on my MP3 MTP device. I have a Sony Walkman NWZ-S544 but I think my problem and its solution could also apply to other MP3 players that don't receive Playlists from WMP. And perhaps to Vista and Windows 7?
When I connected my WALKMAN to my PC and used WMP to Sync (transfer) Playlists to it, the songs were correctly Synched but no Playlists were created on my WALKMAN. My problem was that Windows had installed the wrong driver for my WALKMAN. Here is how I diagnosed and fixed the problem.
DIAGNOSIS: When I used WMP to Sync, the picture in WMP's right hand window was a generic MP3 device. It should have looked like my WALKMAN NWZ-S544. When I looked at the device drivers, I couldn't find a driver for my WALKMAN NWZ-S544 under Portable Devices, but instead found a non-MTP Walkman listed as a USB Mass Storage Device. (See Fix explanation for how to look at device drivers.)
Fix: To fix the problem I first uninstalled the incorrect driver and then installed the correct driver. Here's how…
  1. I disconnected all MP3 players and USB devices (Key/thumb/External Hard drives, etc) from my PC.
  2. I opened the Device Manager. Right-click My Computer-Click Properties.-Click Hardware Tab-Click Device Manager. No Portable Devices were showing. Click the + to the left of the Universal Serial Bus Controllers heading and there was one USB Mass Storage Device but it was for an irrelevant memory card reader on my PC that I can't disconnect.
  3. I connected my Walkman. Looking at the Device Manager, I see that one new USB Mass Storage Device is now showing, I right click-Properties and it describes it as a Compatible USB storage device (Walkman). This is my problem. Windows is using an older Walkman driver. My Walkman driver should be for a MTP device.
  4. I again right click the Walkman USB storage device and click Uninstall. I click OK to Confirm Device Removal. The Device Manage no longer shows my Walkman which has now turned itself off.
  5. I disconnect my Walkman and then reconnect it. Windows gives me the message that I have installed new hardware. The Found New Hardware Wizard starts. I click "No, not this time" and then Next. I click "Install from a list or specific location (Advanced)" and then Next. I click "Don't search. I will chose the driver to install." and then Next. I click "Show compatible hardware" and I select "MTP Device" under Model and then Next. Windows then finds the appropriate driver for my Walkman and I'm done.
VERIFICATION: To verify that it is properly installed, look in the Device Manager under Portable Devices (while your Walkman is connected). Click + and you should see:"Walkman NWZ-S544". Or simply look under Name in My Computer and you should see an entry for Walkman NWZ-S544, and an icon that looks like your Walkman. Everything should now work properly.
Mar 25, 2008 | Sony Walkman NWZ-S616F MP3 Player
Putting music in different folders
Within WMP 10 create a few playlists and drag/drop music files to the appropriate playlist (drag whole albums or individual songs). When you have constructed and filled your playlist(s) connect your player, open the sync tab, and drag the playlist(s) to the sync box. Click sync and smile. ;)
Jan 12, 2008 | Creative Labs Muvo V100 MP3 Player
Cant Install Or Replay Playlists NS-DA2G
I called insignia. An extremely rude cust. service rep. told me that the player doesn't work with itunes playlists and is ONLY mac compat. as a storage device.
What a crap answer! I actually can get songs on the thing and they play, but playlists are a lost cause.
Sometimes technology sucks.......
Nov 07, 2007 | Insignia NS-DV2G MP3 Player
RCA H100 MP3 Player Logo
74 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
