Cannot print any document on MP620. I have troubleshot cleaned heads and everything else. Now all I get when I try to print a document that "printer is working on another issue" when it finally spits out another bunch of colored bars, printer stops and no document is printed. I unplugged and left it overnight. Problem persists. I have Dell with windows vista. bob
  • 4 more comments
  • huntoonbob Nov 15, 2010
    I reinstalled the MP620 drivers and the problem persists.
    I was trying to print a document and pushed the black start button one time and the color start button a second time.
    All that was printed in both runs was my email return address and that was printed in blue.
    I also got a statement that "the printer is performing another operation".
    I copied a color photo in black & white mode.
    huntoonbob@gmail.com
    I did what you said [cleared print spooler and restarted computer]
    BUT the printer will only print my email return address (blue type) and nothing else.
    I also got the comment before it started on my document that "The printer is performing another operation" this resulted in spewing out a totally blank page and then it printed my email return address and nothing more.
    what next?
  • huntoonbob Nov 17, 2010
    Did you give up?
    huntoon
  • huntoonbob Nov 18, 2010
    I tried that with another guru, it did not work; now working with ekse who recommended smart bullet [after having me print a photo]which I have ordered. Thank you.
    thank you. I will work with Ekse for a while.
    yes. I've ordered a spray to open up the printer holes. thanks.
    President:
  • 2,923 Answers
Bob,
Try to stop and restart the "Printer Spooler". Here's how:
Go to Control Panel > System and Maintenance > Administrative Tools > Services.
Locate and click the "Printer Spooler", then click on "Stop the service", and then "Restart the service".
If the same problem occur, try to uninstall the printer driver and download the latest driver that's compatible with your Vista computer, then install it.
Thank you and good luck!
Posted on Nov 20, 2010
  • 2,567 Answers
Did you try to uninstall & then re-install the printer's drivers?
Posted on Nov 18, 2010
  • 3,530 Answers
Welcome to Fixya
You may try to reinstall the printer driver first then refresh the print spooler service of your computer. Here's the procedure on how to refresh the print spool service. Click start menu then type in to the start search bar services.msc. Scroll down on the right side panel and look for print spooler. Double click the print spool service then click STOP. Wait for 5 secs then click START. Restart the printer then try to print again.
All the best!
  • Jose Cada
    Jose Cada Nov 18, 2010
    That's good to know. Thank you.
  • 4,737 Answers
Have you tried uninstalling and reinstalling the Printer's drivers/softwares? If not, give it a try. Uninstall the printer's drivers/softwares from the Control Panel's Programs and Features (Add/Remove Programs). The printer should be disconnected while doing this. Also, connect the printer only when you are asked to do so. Let me know if the problem persists.
Posted on Nov 12, 2010
  • Lebanon Raingam
    Lebanon Raingam Nov 15, 2010
    Ok.. then try this..
    First, unplug the printer's usb cable from the computer usb port.
    Click Start > Run
    Type services.msc and hit enter
    Locate "Print Spooler"
    Right-click on the Print Spooler and then select "stop".
    Now, open "My Computer" and Go to this path: C:\WINDOWS\system32\spool\PRINTERS and delete everything inside the "PRINTERS" folder.
    Restart your computer and again do the following :
    Click Start > Run
    Right-click on it, i.e. Print Spooler and then select "Start".
    [Note: Start > Run may be different in vista, Run should be the box with faded words "Start Search", the instructions are given as a whole for windows]
    Reconnect the printer and try printing again.
    Also, make sure the paper guide or the paper are properly installed, you can try moving the paper try to make sure it isn't stuck.
    Let me know if this doesn't help to resolve the issue.
    All the best.
MP620 print-outs are skewed.
Try a clean and maintenance run on the printer and then do a test page. See if it still does it. strange fault....
Sep 15, 2015 | Canon PIXMA MP620 All-In-One InkJet...
No cyan on photo
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
May 16, 2012 | Canon PIXMA MP620 All-In-One InkJet...
I keep getting an error message (B200) on my MP620. Any ideas about how to fix this?
Print head failure. All you can do is to remove the cartridges, flip up the securing lever and extract the print head assembly from the carrier then clean its contact and the pins on the carrier. If that doesn't fixes it then either the data ribbon cable that connects the carrier to the board or the processor are damaged. In both cases the repair will cost more than a new printer so it's time for a new one.
Sep 29, 2011 | Canon PIXMA MP620 All-In-One InkJet...
My canon Pixma MP620 wont print in black. All the other colors are fine. I've tried deep cleaning with no results..
Try this;
- Open the document you want to print - Go to file > Print - click properties in the print window - in the menu select 'Maintenance' - in the 'Maintenance' click 'Ink Cartridge Settings' - select Black Only - click OK - click OK - now you can print only using the black ink in the printer.
Hope this helps.
Please rate if this solution was helpful. thanks!
Jul 14, 2011 | Office Equipment & Supplies
My Canon MP620 is printing in pink (and a bit of orange) only. All cartridges are at least half full. The big black one is full as are the pink and cyan ones. How can I get the black to function again...
Use the CANON software on your computer to run some "printer maintenance", namely a few "print-head-cleaning" cycles, to try to unclog any blocked ink-jets that are _not_ shooting ink onto the paper.
Jun 04, 2011 | Canon PIXMA MP620 All-In-One InkJet...
Wont print magenta despite deep cleaning and nozzle head cleaning. Its a new cartridge. It wont print sotred docs or photocopy in magenta it comes out yellow/green colour
Hi the bad news is you need a new print head and they cost about £47.00
go to amazon or google Canon PIXMA MP620 print head and you will get a list of suppliers
Very simple to fit
Ian
Mar 11, 2011 | Canon PIXMA MP620 All-In-One InkJet...
My MP620 printer is all of a sudden not printing black, I have no idea why, there is still ink in the cartridge. Please help.
You could clean the black ink cartridge. For this you need to remove the black ink cartridge which is present in the printer. In order to clean the laser or scanner block you could use a cotton swab as it would fully clean the dirt. You need to clean the grime and the dried ink present in the printer. This would remove all the hindrances which prevent the ink from flowing. Cleaning the printer heads would also help to solve the problem.
Nov 29, 2010 | Canon PIXMA MP620 All-In-One InkJet...
Can't find ink storage
look at this
Details Issue: How do I replace or insert an ink tank?
Solution: Install the Print Head and Ink Tanks - MP620 / MP620B
  1. Open the Paper Output Tray (A), then lift the Scanning Unit (Cover) (B) until it locks into place.
    The Scanning Unit (Cover) (B) is fixed automatically.
    The Print Head Holder (C) comes out. (This is where you install the Print Head.)
    Note : Close the Document Cover (D) and lift it with the Scanning Unit (Cover).
  2. Raise the Print Head Lock Lever (E).
    i_expl.gifCaution : Firmly raise the Print Head Lock Lever until it stops. (The Print Head Lock Lever may feel heavy.)
    i_note_e.gif Note : If the Print Head Holder does not move, make sure that the machine is turned on.
  3. Remove the Print Head from the silver package.
    i_expl.gifCaution : There may be some transparent or light blue ink on the inside of the bag the Print Head comes in, or the inside of the protective cap - this has no effect on print quality. Be careful not to get ink on yourself when handling these items. Be careful not to stain your hands.
  4. Remove and discard the orange protective cap.
  5. Tilt the Print Head and set it in place. Lower the Print Head Lock Lever (E) completely.
    i_expl.gifCaution : Do not knock the Print Head against the sides of the Holder.
    Be sure to install it in a well-lit environment.
    Pinch the Print Head Lock Lever firmly and lower it gently.
    Once you have installed the Print Head, do not remove it unnecessarily.
Install the Ink Tanks
  1. Pull the orange tape (1) in the direction of the arrow to peel off the protective film and remove the film (2) completely.
  2. While pressing down with your left thumb, twist off the orange protective cap (A) located on the bottom of the ink tank.
    i_expl.gifCaution : Do not hold the sides of the ink tank; ink may splash.
  3. Install the Ink Tank
    Press the PUSH mark on the ink tank until it clicks into place.
    Make sure the Ink lamp lights red.
    i_expl.gifCaution :Be sure to install it in a well-lit environment
    i_important.gif Important : Match the labels when installing.
  4. Install all the other ink tanks in the same way.
    Install all the ink tanks.
    i_expl.gifCaution :Once you have installed the ink tanks, do not remove them unnecessarily.
    i_important_e.gif Important : Make sure all the Ink lamp lights red.
  5. Close the Scanning Unit (Cover) (B).
Mark
Apr 16, 2009 | Canon PIXMA MP620 All-In-One InkJet...
44 people viewed this question
k24674
jasbo
jasbo
