Question about Intel PRO/Wireless 3945ABG Network Connection (WM3945AGMW1WB)
My intel wireless adapter displays error code 10 and this device cannot start.
    Scholar:
  • 74 Answers
Suggest you reinstall the driver from your drivers cd that you got with your laptop. Alternatively get driver from the manufacturer's website.
If you still get this issue, then usually points to a hardware failure
Make sure that you have already tried switching the PC off and back on again.
As a last resort, you may want to recover your pc back to its factory setting with your recovery disks and if still not detected, almost certainly a hardware problem
Hope this helps
Posted on Nov 12, 2010
F5d7010 network card error code 10 how to fix manually
Make sure you have the correct drivers installed for the correct hardware version.
NOTE: Older hardware version may not be compatible with current Windows.
Ref: http://www.belkin.com/us/support-article?rnId=302
Also follow: http://windows.microsoft.com/en-US/windows7/What-to-do-when-a-device-isnt-installed-properly
Dec 18, 2012 | Belkin (F5D7010) 802.11a, 802.11g/b...
CODE ERROR 10
Code 10
If the device has a FailReasonString value in its hardware key, that string is displayed as the error message. The driver or enumerator puts this registry string value there. If there is no FailReasonString in the hardware key, you receive the following error message: This device cannot start. (Code 10)Recommended resolutions
Here are some things that you can try to resolve this problem.
Update the driver
In the device Properties dialog box, click the Driver tab, and then click Update Driver to start the Hardware Update Wizard. Follow the instructions to update the driver.
You may be prompted to provide the path of the driver. Windows may have the driver built-in, or may still have the driver files installed from the last time that you set up the device. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor’s Web site.
Feb 26, 2010 | Broadcom BCM5721 NetXtreme Ethernet...
I get a "device cannot start (Code 10)" error and a "registry damaged Code 19" error. What should I do?
Make sure the drivers are correctly installed.
If they are, then wireless adapter may be the problem.
Replace with another wireless adapter, and test again
Don't forget to rate this answer if it helps
Dec 27, 2009 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
Intel PRO/Wireless 3945ABG Network Connection code 10
Code 10 usually means the device driver is not compatible, outdated or corrupt.
Try uninstalling the wireless device again and then reinstall using the latest driver available from:
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2259&OSFullName=Windows+Vista*+Home+Premium%2C+32-bit+version&lang=eng&strOSs=153&submit=Go!
NB If you're running XP, use the second one.
Hope this helps
Chris (ziraffa)
Dec 08, 2008 | Intel PRO/Wireless 3945ABG Network...
Router " won't start"
Code 10 loadTOCNode(2, 'moreinformation'); If the device has a "FailReasonString" value in its hardware key, that string is displayed as the error message. The driver or enumerator places this registry string value there. If there is no "FailReasonString" in the hardware key, the following generic error message is displayed:
This device is either not present, not working properly, or does not have all the drivers installed. (Code 10)
Try upgrading the device drivers for this device.
Solution button: Update Driver
To resolve this error code, make sure the device is connected to the computer correctly. For example, make sure all cables are plugged in fully and that all adapter cards are properly seated. Follow the suggested solution button and update the device driver. It may be possible to remove the device and redetect it using the Add New Hardware wizard.
I am sorry that we got disconnected in the chat. Please don't hesitate as I will assist you at anytime. I believe their chat session software is not working with the new firefox.
Thanks,
Lee
Jun 18, 2008 | Linksys Wireless-G WRT54G Router
If its saying code 10 you just need to update the driver for the device and that error code will be gone....
May 07, 2008 | Intel PRO/Wireless 3945ABG Network...
Code 10, intel pro/wireless
You can try updating the drivers for that wireless adapter. If the same happens, you can try to uninstall it completely then reinstall it with the updated drivers.
You can also try to install it on a different slot or a different laptop to test the connection.
If you have other problems, go ahead and press the ask button and i'll answer it for you.
Computers & Internet Logo
232 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
