Question about Kenmore 24032\24036 Top Load Washer
Kenmore direct drive washer - not spinning
I have a kenmore washer, and over the past few weeks it's been shutting off and leaving a 'burning' type smell. Not electrical, but more like rubbing. After awhile of sitting it would run fine. Finally, the tub quit spinning and no agitator action but there is a hum. I checked the motor coupling and that appears ok... could it be the transmission?
  • SouthBurgh Jun 19, 2008
    Thanks! It's a kenmore elite 23012100, Well, I've replaced the Timer, however it produced the same results... there's a hum and the motor gets warm, but nothing else...
    Well, when all else fails... wiggle the wires. I pulled the wires on the motor and made sure all were in the sockets tight and plugged them back in... Plugged the washer back in and wal-la the magical swish swish!! Thanks again for taking the time to review my issue!!
  • 246 Answers
While it could be the tranmission, that is a fairly rugged part (although not impossible). More often, you have bad contacts in your timer. These will short together and cause the machine to try and do multiple things at once, thus causing the burning smell. You didn't list a model number, but for most of the Kenmore washers, you can open the console (two phiilips screws on the front or back towards the bottom) to access the timer. Most timers are able to be opened to verify visably black or silver marks on the normally brass colored contacts.
Posted on Jun 18, 2008
Front load washer no longer spins
Big problem with front load washers the tub bearing more than likely seized replace the machine the parts and labor close to 1000 I fix these all day long under warranty.
Apr 02, 2014 | LG Washing Machines
Kenmore top load washer won't agitate, but will drain and spin
your dogs may be bad in the agitater.. if u open the lid and turn the agitater back and forth does it rachet or does it turn freely both ways?
Dec 13, 2012 | Kenmore Washing Machines
Kenmore washer model # 110 20702 990 will not run past washer cycle or drain water
That is going to be your lid switch.
On this washer the pump is mounted on the motor. The motor goes in one direction for wash and the other for spin. The water gets expelled from the washer in the spin mode.
Here is 4 videos a service manual and a brief description of how it all goes down:
How it works: Direct drive washer
Jun 22, 2011 | Kenmore Washing Machines
My Kenmore Elite HE 3 model #110 4822 201 will not spin. It runs through an entire cycle and fills and drains. The drum will turn a few turns clockwise when spun by hand but then will not move further...
Hello there:
The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. The transmission may not be shifting properly. Older washers produced by Whirlpool and Kenmore have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it. The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
Jan 15, 2011 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Front load Kenmore washer is not spinning and draining. Is motor burned out? It had been making a funny noise while pumping water out the last few weeks
if its still washing, then,,,, no!
but i do think the pump has become blocked up
have a look at the filter first clean it if blocked up
Oct 23, 2009 | Kenmore 44102 Front Load Washer
The washer driving belt breaks.
Sounds like a spin bearing might be bad:
Check this link:
http://www.fixya.com/support/t197849-burning_smell_screeching_sound_but
Apr 21, 2009 | Kenmore Washing Machines
Washer makes noises
You said, when the washer is going into spin cycle it makes a loud clunking noise. You are wondering if this could be the brakes or possibly the pump?
Sounds like this!
Faulty direct drive Coupling (Whirlpool / Kenmore / Roper / Estate)
The direct drive (motor) Coupling may be broken. Many Whirlpool/Kenmore brands washing machines utilize a small, relatively inexpensive direct drive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other.
It can wear out over time or fail under overloading conditions. This protects your transmission from excessive loading.
it can also be a broken spring or strut dependping on your washes make and type
Please remember to leave a rating
Nov 16, 2008 | Whirlpool LTE6234D Top Load Stacked...
Maytag top loader not spinning
thats correct , need to replace the MAIN MOTOR, all that you mentioned (drive coupling , spin solenoid) there inside the MOTOR , since they manufacture the MOTOR sealed, it makes it impossible to repair , so if your handy with tools I suggest to get a new motor or a refurbished one , price range from $35.00 up to $90.00 , hope this info helps , AJ
May 07, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Series 90
rack, on these direct drive Kenmores, any time you have the washer spinning and agitating at the same time, it is a gearcase problem. The gearcase is covered under warranty for 5 years. Probably around 133.00 labor. Catriver..post back.
Oct 02, 2006 | Kenmore 15864/15862 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
117 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
