Question about Toshiba 36AF42 36" TV
Picture goes black
The picture on my Toshiba 36AF42 constantly goes black as if the TV is powered down but the power "on" light flashes. Neither the power switch on the TV nor the remote will turn the TV on or off. I unplug the TV from the wall, plug it back in and the TV works for awhile.
  • Frederick Zarro
    Frederick Zarro Jan 24, 2016
    I'm sure it's too late for this person (2008), but for others having this problem, the symptoms he describes may very well be due to the main capacitor on the power supply going bad (200V, 470uF). It's the largest capacitor on the power supply, and if you remove the cover from the back of the TV and look on the left side (being careful not to touch the picture tube or other dangerous areas), it's easy to find. Look at the top of the capacitor (or any other capacitors) to see if the vent on top is raised up, which indicates that too much pressure built up inside the capacitor, and it "blew". Sometimes they're not gone completely, and can power up the TV occasionally, but eventually they will die completely and you won't have any picture. The good news is that for the price of a new, GOOD brand capacitor ($5), I was able to remove the bad capacitor and solder in the new one with my soldering gun, and the set works PERFECTLY now!!! If you're not comfortable with soldering, any friend with basic soldering skills can do this job, and all they need to do is remove a few screws holding down the circuit board so they can get access to the bottom side, to unsolder the old capacitor and solder in the new one (using solder flux, of course). Hope that helps someone!
    Scholar:
  • 89 Answers
GO TO MENU, THEN SETUP, SCROLL DOWN TO TIMER AND MAKE SURE IT IS ON 0 (ZERO) MIN. SOUNDS LIKE ITS PROGRAMMED TO GO SLEEPAFTER A CERTAIN TIME. THIS TV ALSO CUTS OFF AUTOMATICALLY IN 15 MIN. IF ITS TUNED TO A VACANT CHANNEL( NO PICTURE).
Posted on Dec 27, 2008
  • Frederick Zarro
    Frederick Zarro Dec 13, 2015
    How can you "Go to Menu", if the TV won't turn on at all? I guess you can't...
Toshiba TV model 36af42 has no picture but sound work
Engage in High-exposure Branding - Remember, a typical ad lasts about a thirty day period but an emblem item can final a number of years. How To Physical Exercise Whereas Sitting Down At Your Laptop Computer...
Jan 04, 2017 | Toshiba 36AF42 36" TV
Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
tv seems to turn on but no picture? - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
The timer, lamp, and standby/temp. light are flashing?!
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
Samsung plasma tv repair blinking light no picture ...
Jan 09, 2016 | Samsung Televison & Video
My Magnavox TV give sound but no picture. When I turn it on the light in the bottom right hand screen goes green, then flashes to yellow and goes back to green. The screen does not change it is constantly...
You need to replace your backlight inverter.
Check that all voltages are coming from the power supply as they should. The power supply will be stamped with the correct amounts, and you just read with the multimeter to confirm.
After those check out ok, you will need to replace the inverter to "light" your screen again.
You can hear sound because the tv is ON, but the inverter isn't lighting the screen!
Hope this helps, please rate!
May 11, 2011 | Televison & Video
Picture loss after picture begins to flash. blue and yellow light
Most likely the lamp is dying. Try replacing the lamp before calling a repair tech. What does the Owners manual say about the blink lights?
Oct 01, 2009 | Toshiba 62HMX84 62" Rear Projection HDTV
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
TOSHIBA TV NO SOUND NO PICTURE, POWER LIGHT IS ON
the lamp in the projector might have went. try replaceing it. to do so try
ADTECH SYSTEMS they may help
there in mass.
call David Crepeau at 978 261 1087 tell him Ryan Bolduk sent you
depending where you live. They maybe able to send someone out from there sub company
Sep 18, 2008 | Toshiba 42H81 42" Rear Projection...
Help! Toshiba 51H84..Power light flashing, tv picture won't come on!
You need a new HV transformer. Usually you can just buy the transformer itself. It's a little black tower on the backside of the tv. If it's not that, it's the convergence ic's. There's two of them, given it's a toshiba, the part number is more than likely stk392-110.
Sep 07, 2008 | Toshiba 57H81 57" Rear Projection...
Toshiba TheaterView
Called Tv tech. He said it was the power supply connectivity. common problem in rear projection Tv's. Cost to replace was anywhere between $300.00 and $400.00 dollars. Time for a new tv :-(
Feb 21, 2008 | Toshiba 50A60 50" Rear Projection...
Does anyone know why my tv screen goes black while the power light flashes on and off?
it seems that there is a problem in power supply. if it is ok check horizontal section it is a simple problem &can be fixed by skilled tech.
Sep 28, 2007 | Toshiba 32A50 32" TV
Toshiba 36AF42 36" TV Logo
200 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
