Question about DeLonghi DEFSGG36 Gas Kitchen Range
The fan is working bt the oven isnt getting hot
  • 1,583 Answers
I assume you have already checked the gas supply by turning on a burner on top.
Do you smell gas when the oven first tries to light? If the flame sensor isn't picking up a fire on the oven burner within a few seconds after the igniter is supposed to start firing, it will shut off the gas valve. The first thing to check is the oven igniter. Can you hear it sparking (repeated snapping sound until main flame starts)? The sound may be drowned out by the fan, so hearing it would only verify that it's making sparks; not hearing it doesn't tell you anything unless you were able to hear it before the problem started. If you had a major spill in the oven recently, it's possible some residue made its way to the igniter or pilot flame tube and is gumming up the works.
The next items to check would be the oven gas valve and thermostat.
Posted on Nov 12, 2010
Smeg oven UK80MFX1 troubleshooting
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Nov 30, 2011 | Smeg Ovens
Fan oven not heating up
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  • If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Apr 24, 2011 | Zanussi ZDQ495 Electric Double Oven
Fan not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
Mar 12, 2010 | Zanussi ZBQ665 Electric Single Oven
Help!!!!!!!!
Sounds like the oven element is faulty.
This is usually located at the rear of the oven compartment behind a remov eable cover.
Please rate my solution.
Thankyou
Jan 25, 2010 | Ovens
Z28 95 running hot
Is the fan running or do you have an electric fan? If fan isnt running or never comes on no matter what you do it will never run much cooler. If fan is good then you could flush the radiator a couple of times and that will help but if fan isnt working it wont last long
Aug 25, 2009 | 1995 Chevrolet Camaro
Fan works but oven doesnt get hot
One of the switches looks to be a 5 position switch. 0=off, 1=Light, 2=fan
Feb 24, 2009 | Ovens
Oven not getting hot
If the fan is working, then the oven element has failed, you need to fit a new element., it is behind a removable cover at rear of oven compartment.
Jan 25, 2009 | Stoves Premier 600EMa Electric Single Oven
Simpson 2001 series upright electric stove oven does not get hot only gets warm
It could be the oven element (behind the cover plate in the back of the oven), or the fan not blowing the heat into the oven.
Aug 19, 2008 | Ovens
DeLonghi DEFSGG36 Gas Kitchen Range Logo
174 people viewed this question
Top DeLonghi Kitchen Ranges Experts
JP Services
JP Services
Vitaliy Gins
Vitaliy Gins
Paul Bade
Are you a DeLonghi Kitchen Range Expert? Answer questions, earn points and help others
