Question about Cobra 29 WX NW ST 40-Channels Base CB Radio
Im having a problem with people hearing me on my CB. I can hear people fine and it comes in real clear, but they can't hear me at all, i mean they can but its just that its so low they can hear me. It was working fine until my dad took my whip off and put it back on now its not working right.
    Guru:
  • 773 Answers
Tune your antenna. If he took the metal whip out of the base, then he messed the tuning all up.
It is important to tune your CB radio antenna to the proper length. The length must exactly match the wavelength of the frequency you transmit on. Or be really really close.
All Cb antenna's have a way to adjust the length of the antenna. If it's a mag mount, the metal whip can be slid in and out of a metal collar. Usually a set screw. If its a fiberglass whip, the way to tune it is on top. It either has a small metal rod with a set screw to adjust the length, or it threads in and out to adjust length.
Either type you have it will need to be adjusted for proper length. Here is how to tune the antenna to lowest SWR.
Some radios have a built in SWR meter. Some do not. If yours doesn't have an SWR meter, then you have to use an external SWR meter. Radio shack carries one, and you can find them cheap on ebay.
If you have a built in SWR meter or external, the procedure is the same:
1. Turn the radio to CH 20.(This is the center of the band.)
2. Switch the meter switch to CAL. (CAL stand for calibrate.
3. Key the radio. (Important. Do not talk while keying the radio.)
4. turn the CAL knob up until the meter hits the CAL mark.
5. Now while still keying the radio flip the meter switch to SWR.
Where the meter falls after that point is you SWR reading. If its above 3, that is real bad. 2 is not gonna kill your radio but its not the greatest. 1.5 and under is a good place to be, but the lower the better.
If your SWR is high, Here is how to find out if your antenna is too long or too short.
1. Turn to CH 1
2. Repeat SWR procedure. You must calibrate every time you do it.
3. Remember the SWR reading.
4. Turn to CH 40.
5. Again repeat SWR procedure.
6. Compare the reading between CH 1 and CH 40.
Now if the SWR is higher on channel 1 then channel 40 your antenna is too short. You must make it longer.
If the SWR is longer on channel 40 then on channel 1, then the antenna is too long, you need to make it shorter.
Make height adjustments about an eight inch at a time, and take reading each time.
once the SWR is significantly lower and the reading on channel 1 and 40 are about the same, you a about matched. At this point turn the radio to the center of the band, channel 20 and take an SWR reading.
You should now have a low SWR reading, 1.5 or under. If you are 1.5 or under, you are good to go.
If you cannot get the SWR to an appropriate level, there may be an antenna problem.
Posted on Nov 17, 2010
Hi chris here im using a gx300 with a 100w linear amp on the 27mhz band i can hear people but still cant seem to get out im using a staion master antenna please help tried everything
Yikes, using a linear on CB is illegal! You could get into real trouble doing that. The radio \'barefoot\' with that antenna should work very well, and will be legal. If you hear stations, but cannot contact them, there is a good possibility that the linear is not working. Or, the radio may not be putting out power. Do you have access to a watt meter or SWR meter? Find someone who has these instruments, and they can help you out. Best of luck to you!
Dec 07, 2014 | Midland Radio Midland 18-258 27MHz Window...
I can,t get any modulation on my uniden pc68xl cb
you shouldn't be able to hear your modulation anyway,unless you have talkback. If you can't hear to well get a mono set of head phones or turn your radio volume up.
Mar 20, 2013 | Uniden Radio Communications
Im having problems with my midland 77-095 im reciving lound and clear but my output is terrible people cant hear me but i can hear them>???? thanks
it is possible you are hearing peoplein skipland. skip is an atmospheric phenomenon that causes radio waves to travel hundreds even thousands of miles. there a lot of cb operators that run high power amplifiers which would make their signal go even further. this would mean you would hear them well, but your radio doesn't have enough power to reach that person. right now we are in a solar cycle which has been causing skip daily. if you know that the peson you are trying to talk to is local and within. a few.miles then there may be an issue wit either your radio or antenna. the antenna must be tunedto the radio or you signal will not radiate off the antenna completely. over time it can destroy the radios transmit circuit. so if you have never.tuned the antenna you may be causing the radio not to work well and you may have hurt the transmit transistor.
Jun 27, 2011 | Radio Communications
Lost the FM signal this morning, AM still works fine. all I get is static on FM with some intermittent what sounds like CB radio.
hello please check the rear of the radio as antenna could have come away from it hearing sounds like cb radio do you mean transmissions can you hear someone talking ,its probably someone near you that you are picking up
Mar 17, 2011 | Sony CDX-CA750X CD Player
My connex 3300 hp stopped reciving it transmits people can hear me loud and clear but I cant hear them radio was working fine then one day I turned it on and couldn't hear any thing.
Hi, my name is John. Try a external speaker, plug it in the back of radio, turn the RF GAIN to MAX. Turn the SQUELCH all the way to left, make sure the select knob is on CB, and on AM...try all this and if that's does not do it, let me know, I will post other steps here,.... hope this was very helpful....
Sep 02, 2010 | Connex 3300 240-Channels Base CB Radio
I can't hear.
I am not completely sure i understand whats going on. it seems like it could be a few things because of different parts of the question.
With my CB everyone else can hear me and the signal transmits fine
Good!
I have tested to see that my CB is picking up the signal
how? A meter on your radio should either light up or a needle should swing if you are receiving.
their voices don't play through my mic of my PA
A Mic is a microphone, i think you mean speaker.
Ok this may be the cause of the problem....
Try a couple of these.
First, unplug the PA Speaker, this simple act should make you to be able to hear the incoming signal.
Make sure the CB is on AM or CB not PA
If you can not hear the speaker may be busted or an internal part may be blown. (needing the expertise of a required technician)
If you can here when you do this make sure the speaker is working by plugging it into a computer. (mp3 players will barely put out enough power to make a sound audible) if this works, make sure you plug it into EXT not PA on the back of the radio.
one more thing to check. i dont know what radio you have but try turning it untill you hear static. if its all the way the other way you may not hear anything, also turn up any RX or rec. knobs.
i have limited knowledge about whats going on, but i hope this will help fixya
Jan 05, 2009 | Midland 1001Z 40-Channels Base CB Radio
Noise on cb when truck is running
You might try running an insulated wire and ground directly from the battery.
Apr 07, 2008 | Cobra 19 DX IV CB Radio
Rockford Fosgate 800.2 no power
This one is a real twister. Some questions of you might help to correct this problem.
1) Did you in some way hook the CB Radio up to the amplifier?
2) Did you use the same power lead from the amp to install the CB Radio?
3) In some way, did you unhook the ground from the amp?
These questions will help in solving your problem
I'll be waiting to hear from you
Ed
NC Electronic
Mills, Wyoming
Jan 29, 2008 | Rockford Fosgate 800.2 Car Audio Amplifier
Cobra 29 WX NW ST 40-Channels Base CB Radio Logo
117 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
