Question about Acer Ferrari 4000 Laptop Notebook
How do you change the CMOS Battery? Acer Ferrari 4000. We can not find any info on how to locate the battery
    Genius:
  • Acer Expert
  • 1,325 Answers
Hello
first remove the power cord, then the battery.
go to this link and download the manual for the Acer notebook.. basically you have to remove the back cover , the one with most of the screws around it. Once you get the plastic cover off, you will see the one side of the mainboard, look for a coin shaped silver battery, remove the CMOS battery and replace with new one
in case yopu dont have the manual, link below can be downloaded -- but it will not show you how to remove the battery.
http://www.acer.ca/acer/service.do?LanguageISOCtxParam=en&miu10einu24.current.attN2B2F2EEF=3751&sp=page15e&ctx2.c2att1=27&miu10ekcond13.attN2B2F2EEF=3751&CountryISOCtxParam=CA&ctx1.att21k=1&CRC=719687231
Posted on Nov 12, 2010
Ferrari 3000 locked bios password
Hi Steve,
you just need to remove the CMOS battery, when replaced it resets the BIOS password. but please make sure no battery power or charger pluged in at the time you open up the machine.
Jan 29, 2014 | Computers & Internet
How do i power up my acer ferrari 4000
Remove main battery and try again, if nothing! check power adapter for correct voltage, If okay! sub out the ram memory one at a time and test, still no change! the DC jack is often the source of trouble and the laptop will need to be dismantled down to the motherboard level, the DC jack will probably need resoldering.
Apr 14, 2012 | Acer Ferrari 4000 Laptop Notebook
How to locate the Cmos battery
The CMOS battery is the RTC battery. Real Time Clock.
It's smaller version of the CR2032 batteries you're used to seeing in a desktop computer.
It's in a plastic holder that resembles a bag. The plastic 'bag' wraps around the battery.
There are two wires attached to the battery, and come out of the 'bag'.
One wire connects to the Positive pole of the battery, and the other wire connects to the Negative pole.
The wires are soldered to the Battery.
At the end of the wires opposite of the Battery is a small white connector. It's a Male connector.
The Male connector plugs into a Female connector on the motherboard.
Once you have the RTC battery pack removed, and the battery itself removed out of the 'bag', you can match up a new battery to it. Carefully make a **** in the side of the bag, and remove the battery/wire combo.
Have a competent repair person remove the wires, and connector to the old battery, and solder the wires/connector to the new battery.
Install the battery/wires/connector combo back in the 'bag', use glue to seal the 'bag' once more.
(Or you can use silicone)
The RTC Battery is on the BOTTOM of the motherboard. This means the laptop has to be completely disassembled in order to access the RTC Battery.
In the above heading it states Acer TravelMate 4000 PC Notebook. This is the TravelMate 4000 series.
There are many models in that 4000 series.
The Model Number is on the bottom of the laptop.
Models in the 4000 series are; 4000, 4010, 4020, 4050, 4060, 4070, 4080, 4100, 4150, 4200, 4210, 4220, 4230, 4260, 4280, 4320, 4330, 4330G, 4400, 4500, 4520, 4530, 4600, 4650, 4670, 4720, 4730, and 4730G.
The above Model list may not be complete.
The disassembly guide for the Acer TravelMate 4000 series will cover all of the above models.
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-acer
Scroll down with your eyes to the Travelmate heading.
Go down to the third line that starts with 2700, read across to 4000.
Click on 4000.
This is a PDF file. The computer you are on now has Adobe Reader on it, which uses PDF files.
However if you do not have the latest Adobe Reader, I would suggest downloading it.
(Adobe Reader 9.3.4)
After you click on 4000 nothing will happen for up to 30 seconds. (Maybe more)
The screen will be blank. The file is downloading in the background, and after it has fully downloaded, the first page will pop up.
For additional questions please post in a Comment.
Would appreciate it if you would rate my solution.
Regards,
joecoolvette
Oct 21, 2010 | Acer TravelMate 4000 Notebook
How to change cmos battery Acer notebook model 4002LCi.
Cmos battery usually but not always is held to the mother board with spung steel clip Its like a large watch battery often,that is needed when power down for the clock,time of your pc(and other functions).
Youll have to open you pc up to get to it,youll see it when you do !--Good luck!
Davey Snake!
I changed bios password on 4005
i'll try make it simple..disconnect all input mains power sources.."just remove or pick open the cmos battery (+3v) from the main/mother board and resit/fit it again carefully"..
configure bios again..save n exit n restart..hope it'll work..
always better to hv professional supervision, contact ur system admin/vendor....
Nov 01, 2009 | Acer Ferrari 4005WLMi Notebook
Lost password
NO.....laptops are built his way for a security reason and there is no bypass gimmick, no hacker tricks. The cmos battery has to be pulled, the two pins in the battery socket on the motherboard have to be "shorted", the laptop powered on and then off and the battery replaced. That is the only safe way to do this procedure. I have included a service guide below for the job.
http://tim.id.au/laptops/acer/ferrari%204000.pdf
Sep 22, 2009 | Acer Ferrari 4002WLMi Notebook
Need to find a power/battery charger board for Acer Ferrari 4000.
Hi there.
You will be able to get the laptop powerboard from ebay or Sony themselves, although if you get from Sony it will be considerably more expensive.
Good luck and thanks for choosing FixYa!!
May 28, 2009 | Acer Computers & Internet
Acer 8100 Travelmate - blank screen
Acer Ferrari 4000 "power on" blank screen, fan is running but no beeps, no activity in/from the HD. No reaction on a F8 start up (no Bios set up). It charges the battery OK.
KR Steen Larsen
Dec 08, 2008 | Acer Ferrari 4000 Notebook
Acer Ferrari 4000. The computer won't charge the battery. We have a new charger and a new battery both of which have been checked. It was purchased 2 years ago.
based on your information, with new ac adapter and new battery the notebook will still not charge your battery this is a motherboard problem. replace motherboard
Jun 19, 2008 | Acer Computers & Internet
Acer Ferrari 4000 Laptop Notebook Logo
669 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
