Question about Garden
Yesterday i was using the 455 rancher its a huqvarna. it was working fine then, i went to use it again a little while later and when i went to cut with it it started bogging down and had little power.so i shut it off and went to get the manual and read how to fine tune it .the i restarted the saw and it was runnining fine again with lots of power on acceration.and seemed like it needed no carberator adjustment . what can cause this itermittent running condition
    Brigadier General:
  • 4,088 Answers
When it won't run correctly, try removing the fuel tank cap temporarily. If it immediately picks up, suspect tank venting problems. Good luck!
Posted on Nov 12, 2010
What is the gas / oil ratio mixture for husqvarna 455 rancher model ?
50:1 that's 2.6 ounces of 2-stroke oil (preferably with fuel stabilizer) to one gallon of gas. I recommend using 89 octane gasoline for all small engines. It has little or no ethanol in it, as opposed to the 10% typical in 87 or 86 octane fuel. This will prevent a lot of fuel issues, especially if you are not using the tool daily or at least weekly.
Aug 02, 2014 | Husqvarna "965030298 - 455 Rancher, 20""""...
How to change the fuel line on a Husqvarna 455 Rancher
feed a wire threw the tank cut the new hose down to 1/3 about 1/2'' long slide it over the wire and pull it back till it pops threw then pull it threw
Aug 09, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
455 rancher wont rev
remove the muffler and try running it if ok open the muffler and clean off the screen
Apr 15, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
Cutting with 455 rancher chain locked up took cover off ,replaced chain and put cover on still locked up
Husqvarna - IPL, 455 Rancher/ 460, 2006-02, Chain Saw (example - may not be your saw):
http://weborder.husqvarna.com/order_static/doc/usa/2006/I06000/I0601076.pdf
See Detail A, pn 503 89 08-02. You can use a Crescent Wrench on one of the ears (left end) to reset it. With the cover positioned with pn 503 89 08-02 in the upper left rotate it CW until it nests, to reset it.
This works quite well:
Reset Chain Brake by Dolfoff
Please follow this link, http://www.fixya.com/support/t3102817-re_install_side_cover_after_chain
Cursor down to “Best Solution”, while there click the “Was this helpful? [Yes]” button
If you do not have a vise a large C clamp to a work surface might work, you may still need a block or two of wood.
You can download the IPL for you saw here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
I will wager you will NEVER again remove the cover with the brake set. Me either! Good Luck. HTH
Lou
Feb 25, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
What size file to sharpen chain for 55 rancher
It depends on the chain you have installed on the chainsaw. You can look at the numbers stamped on the drive link side of the cutting chain and it should have a 2 digit number that correlates to the size.
The factory chain supplied with the #455 rancher was a .325" pitch 3/8" chain.
Here's a link to the specs for your saw with some useful info
http://www.husqvarna.com/us/homeowner/products/sawing/chainsaws/455-rancher/#specifications
Hope you found this very helpful and best regards!
Aug 06, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Adjusting automatic oiler. Chain is over-heating not getting enough oil. 455 Rancher
check for blockage in feeder pipe, try draining oil tank and clean with fine grade oil or wash out using engine clean by wynns. hope this helps
Jun 30, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
455 rancher will not produce oil for the chain. Oil pump replacement? Need repair manual or parts breakdown. Thanks Warren
Also make sure that where the oil is pumped against the side of the bar that the oil port (little hole) that feeds oil into the bar's slot is clear. Mine would go through a tank of oil with each tank of gas, but the chain wasn't getting oiled until I cleaned out this little hole.
Jun 29, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a 455 Rancher got it slightly used. It had oiler issues when I got it took it to the shop they installed a new one 3 months later the oiler isn't working,any fix for this?
the rancher uses a plastic oiler gear to a metal gear.the plastic gear always looses in the battle.pull the clutch off and clutch drum.under the drum you will find the plastic gear.replace it and all should be well again
Feb 21, 2009 | Husqvarna Chain Saw 20" Bar
Bad Clutch??
Hi
Before other checking change the spring of the clutch(2).
best regards savumihai71
Feb 14, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
76 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
