Question about HP Office Equipment & Supplies
Printer reporting cartridge jam-I have opened door and moved them but no luck.
    Genius:
  • HP Expert
  • 1,325 Answers
Hi
perhaps its a roller jam or carriage jam.. look in your manual and review the various paper jams possible.
if i can get your printer model, i can look into it
hope this helped you, if not let me know
Posted on Nov 12, 2010
My printer carriage has jammed.
To resolve the issue, you can try each solution in this document in the order presented.MPORTANT : Each time you try a solution, try to print a self-test report to determine if the hardware functions correctly. To print a self-test report, use the steps in the following table:Load plain white paper into the input tray.Press Setup on the product control panel.Press the right arrow ( ) to select Print Report , and then press OK .Press the right arrow ( ) to select Self-Test Report , and then press OK . The self-test report prints.Solution one: Turn the product off and on again Follow these steps to turn the product off and then on again to reset the printing mechanism Press the Power button to turn off the product. If the product does not turn off, continue to the next solution.Wait 60 seconds.Press the Power button to turn on the product NOTE:The product might go through a warm-up period. The product lights might flash and the carriage might move. Wait until the warm-up period finishes before you proceed. Try to print a self-test report. See the steps on how to print a self-test report at the beginning of this document.If these steps resolved the issue , and the self-test report prints , there is no need to continue troubleshooting. If the issue persists , continue with the next solution. If the self-test report does not print , continue with the next solution.Solution two: Clear any paper jam Follow these steps to clear any paper jam.Step two: Clear the jam from the rear of the product Use one of the following methods to clear the paper jam from the rear of the product. If your product has a two-sided printing accessory (duplexer), skip to Method two.Method one: Clear the jam from the rear access door Press the Power button ( ) to turn off the product, if it is not already off.Disconnect the USB cable from the rear of the product.Disconnect the power cord from the rear of the product.Remove the rear access door: Press the tab on the left side of the door inward, and then pull the door out.Figure 1: Remove the rear access door ently remove any jammed paper from the rollers.CAUTION:If the paper tears while you remove it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the product. If any torn pieces of paper remain inside the product, more paper jams are likely to occur.Figure 2: Remove torn pieces of paper from the rollers Reattach the rear access door. Gently push the door forward until it snaps into place.Method two: Clear the jam from the two-sided printing accessory (duplexer) Press the Power button ( ) to turn off the product Disconnect the USB cable from the rear of the product.Disconnect the power cord from the rear of the product.Remove the two-sided printing accessory (duplexer) from the rear of the product: Press the buttons on each side of the duplexer, and then pull it toward you. Figure 3: Remove the two-sided printing accessory Gently pull the jammed paper out of the rollers.CAUTION:If the paper tears while you remove it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the product. If any torn pieces of paper remain inside the product, more paper jams are likely to occur.Figure 4: Remove torn pieces of paper from the rollersIf you do not see jammed paper in the rear access area, push the latch on the top of the duplexer, and then lower its cover.Figure 5: Open the duplexer - Latch on top of the duplexer Duplexer cover Remove any jammed paper from inside the duplexer.Close the duplexer cover, and then reinsert the duplexer into the rear access area of the product. Figure 6: Reinsert the duplexer Push the duplexer inward until it clicks into place.Step three: Clear the jam from the front of the product If you cannot remove the paper jam from the rear of the product, follow these steps to remove the paper jam from the front.Open the cartridge access door.Figure 7: Open the cartridge access door NOTE:The carriage should be on the right side of the product, out of view. If it is on the left side, close the cartridge access door, and then turn on the product. Unplug the power cord from the wall outlet, and then open the cartridge access door again.Look for any pieces of paper or other debris inside the cartridge access area.Gently pull the paper out of the rollers.CAUTION:Remove paper from the front of the product as carefully as possible. If any torn pieces of paper remain inside the product, more paper jams are likely to occur, and this could damage the print mechanism.Close the cartridge access door.Figure 8: Close the cartridge access door Reconnect the USB cable to the rear of the product.Reconnect the power cord to the rear of the product.plug the power cord back into the electrical outlet. Press the Power button ( ) to turn on the product. Reload paper in the input tray.try to print a self-test report. See the steps on how to print a self-test report at the beginning of this document.If these steps resolved the issue , and the self-test report prints , there is no need to continue troubleshooting.If the issue persists , continue with the next solution.If the self-test report does not print , continue with the next solution.Solution three: Make sure the carriage moves freely Use the following steps to make sure the carriage moves freely.Press the Power button ( ) to turn on the product, if it is not already on.Open the artridge access door.Figure 9: Open the cartridge access door Without turning off the product, disconnect the power cord from the rear of the product.WARNING:You must disconnect the power cord to move parts by hand without the risk of an electrical shock.unplug the power cord from the wall outlet.Look inside the product to see where the carriage is stuck, and then check for any torn paper or other objects that might restrict the movement of the carriage.NOTE:You might need a flashlight to illuminate areas inside the product Figure 10: Use a flashlight to see inside the product Remove any loose paper or obstructions you find.Figure 11: Example of obstruction in carriage access area Reach inside the product through the cartridge access door, and then manually move the carriage. You might have to reach through the paper output tray to access the carriage.If the carriage is stuck on the right side of the product , move the carriage to the left side of the product.If the carriage is stuck on the left side of the product , move the carriage to the right side of the product.Make sure the carriage moves freely across the width of the product by gently pushing the carriage to the left, and then to the right.Close the cartridge access door.Figure 12: Close the cartridge access door. Reconnect the power cord to the rear of the product.Plug the power cord into the wall outlet. Press the Power button ( ) to turn on the product. Try to print a self-test report. See the steps on how to print a self-test report at the beginning of this document.If these steps resolved the issue , and the self-test report prints , there is no need to continue troubleshooting. If the issue persists , continue with the next solution. If the self-test report does not print , continue with the next solution. four: Remove and reinstall the cartridges Improper placement or installation of the cartridges can cause the product to indicate a carriage jam error.
Oct 12, 2011 | HP Officejet 6500 Wireless All-in-One...
I have a jam on my printer that says there is a print carriage access jam how do i solve it
I have the same problem.... trying to use lubricants and done some cleaning, but no luck... till i found out that using an extension cord with several devices plugged in will lessen the amount of current that flows to the devices.. that's why the printer's motor can't able to do his job because of no enough power.... Connect the printer's plug directly to the wall...
it works for me....
---ritchie---
Jan 13, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Paper jam
Check the following steps for fixing Hp Carriage Jam Error :
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed paper out.
Dec 07, 2010 | Office Equipment & Supplies
Printer carriage jam and then locks
Dec 07, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Paper jam light on permanently, printer is jammed
http://h30434.www3.hp.com/t5/Other-printing-questions/Paper-Jam-Error/m-p/305772#M20513
Nov 25, 2010 | HP DeskJet 970cxi InkJet Printer
Paper Jam {Printer does not detect paper
Nov 18, 2010 | Office Equipment & Supplies
My printer comes up with a clear paper jam and press checked key. I have cleared all paper from machine and yet the light flashes and will not allow me to print and the same error code comes up. What...
Solution one: Turn the All-in-One off and on again Follow these steps to turn the product on, and then off again, to reset the print mechanism.
  1. Press the Power button (c01602202.gif ) to turn off the product.
  2. Wait 15 seconds.
  3. Press the Power button (c01602202.gif ) to turn the product on again.
    NOTE: The product might go through a warm-up period of up to two minutes. The product lights might flash and the carriage might move. Wait until the warm-up period is complete before proceeding.
  4. Try to print a self-test report. See the steps on how to print a self-test report at the top of this document.
  • If these steps resolved the issue , and the self-test report prints , there is no need to continue troubleshooting. Reconnect the USB cable, and then try to print again.
  • If the issue persists , continue with the next solution.
  • If the self-test report does not print , continue with the next solution.
Solution two: Clear any paper jam Jammed paper can cause the carriage to stall. Follow these steps to clear any jammed paper. Step one: Remove any loose paper Remove any loose paper from the input tray and output tray. CAUTION: Do not remove jammed paper at this stage. Trying to clear a paper jam from the front of the product can damage the print mechanism. Step two: Clear the paper jam from the back of the All-in-One Use the following steps to check for and remove jammed paper from the back of the product.
  2. Disconnect the USB or Ethernet cable from the back of the product.
  3. Disconnect the power cord from the back of the product.
  4. Remove the rear door. Push the door latches toward each other, and then pull the door away from the product. Figure 1: Remove the rear door c00244379.gif Illustration of removing the rear door
  5. Gently pull the paper out of the rollers. CAUTION: If the paper tears when removing it from the rollers, check the rollers for torn pieces of paper that might remain inside the product. If any torn pieces of paper remain inside the product, more paper jams are likely to occur.
  6. If you are printing labels, see if any are missing from the label sheet. If any labels are missing, find them inside the product, and then remove them carefully.
  7. Reattach the rear door. Gently push the door forward until it snaps into place.
Step three: Clear the paper jam from the front of the product Follow these steps to remove the paper jam from the front of the product.
  1. Open the cartridge access door. Figure 2: Open the cartridge access door c01913998.gif Illustration of opening the cartridge access door
  2. If you find paper jammed in the product that cannot be removed through the rear door, gently remove the paper through the front of the product.
    NOTE: Remove paper from the front of the product as carefully as possible. If any torn pieces of paper remain inside the product, more paper jams are likely to occur, and this could damage the print mechanism.
  3. Close the cartridge access door. Figure 3: Close the cartridge access door c01913999.gif Illustration of closing the cartridge access door
  4. Reconnect the power cord to the back of the product.
  5. Press the Power button (c01602202.gif ) to turn on the product.
  6. Try to print a self-test report. See the steps on how to print a self-test report at the top of this document.
Keep in this LINK.
Oct 26, 2010 | Dell 948 All-In-One InkJet Printer
False paper jam message
Check the following Steps to Fix Hp printer carriage jam :
  • Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
  • Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
  • Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
  • Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed papaer out.
Sep 29, 2010 | Office Equipment & Supplies
Clear carriage jam
The carriage assembly is what the ink cartridges moves on. The silver bar that runs through the cartridge holder must be oiled. Put two or three drops of thin oil oun iether sides of the cartridge holder. This should clear the "carriage error"
Good Luck
Apr 15, 2010 | HP PSC 2210 All-In-One InkJet Printer
Cartridge jams
remove the cartridge and directly off the printer let the carriage remain in center.then with your hand manually move the carriage from left to right.3 to 4 times.then on the printer and insert the cartridge after cleaning it with dry tissue.then check out.also in the back side of the printer there is access door to remove the paper if jammed so check out there also if any paper jammed.
thanks.
Apr 01, 2009 | HP PSC 2210 All-In-One InkJet Printer
16 people viewed this question
Seeker5211
Seeker5211
