Question about Dell 1815dn All-In-One Laser Printer
My printer is sayng the fuser door is open and I have been opening and reclosing everything on this printer what could this be??
    Director Badge:
    Uploaded 100 video answers.
  • 160 Answers
Hey, make sure the rear door is shut, if it is, you most likely need to replace the High Voltage Power Supply (Part# WH773). Iteminc.com has this part and can ship same day. The sensor which reads if the door is open can go bad and it is a part of the HVPS. Here is a video that explains this error and shows you how to replace it. Hope it helps. Good luck!
Posted on Jun 16, 2011
  • Steven C
    Steven C Jun 16, 2011
    Whoops, forgot to post the video
How do I clear a "door open" message when no doors are open and I have checked the door sensors?
re install the printer drivers or
reset the printer by eject the power and data cable for a one minite
Nov 26, 2014 | Samsung CLX-3175FW Multifunction Laser...
Reinstall software. You do not have to
uninstall the original software, re instalation will roll over it.
Brad
The fuser door is stating it is open when it is closed I have turned off and taken out fuser turned on and then replaced. still showing fuser door is open will not print or copy
That is a problem with the fuser door switch which is a part of the High voltage power supply. Replacing the HVPS should fix this right up.
Apr 28, 2011 | Dell 1815dn All-In-One Laser Printer
Ricoh aficio sp 3200sf fuser door open error getting "fuser door open" message. opened and reclosed fuser door to make sure fuser door was closed. restarted printer. still get same message. what can i do...
There is a black sensor that detects when the fuser door is closed, and an actuator that the sensor either sees or doesn't see. If this sensor is dirty, it might not be seeing the actuator. It could also be broken or knocked out of place.
Locate the actuator on the side door (a small metal or plastic tab that sticks out from the door) and find the corresponding sensor. Make sure the sensor is in place and not broken or moved, and make sure it's connector is well-seated. If you have a can of compressed air, blow it into the sensor to clear away any dust or dirt.
Jun 16, 2010 | Ricoh Multifunctional SP 3200SF...
We keep getting a message -paper jam check open rear door. checked, no paper jam, opening and closing rear door will allow the print job to go through. It will work for a few print jobs, then the same...
It's probably a sensor on the fuser. There are 2 and sometimes they get stuck and just closing the rear door hard will release it. Replace the fuser.
Dec 08, 2009 | Dell W5300N Laser Printer
Fuser door open on dell 1815n
If you have tried closing the fuser door (rear door) several times and the error continues. You most likely need to replace the High Voltage Power Supply (Part# WH773). Iteminc.com has this part and can ship same day. The sensor which reads if the door is open can go bad and it is part of the HVPS. Good luck!
Oct 02, 2009 | Dell 1815dn All-In-One Laser Printer
Jam in top cover area
Replace your paper pickups and set your paper tray setting correct, both in the tray and the settings menu. That should help you out. The part# for paper-pickups is RF5-3739.
Mar 17, 2009 | HP LaserJet 4600dn Color Printer
Panasonic printer dp4520 error code j40
This indicates there is a paper in the fuser area(very Hot section be cautious).1. open the front door.2, open the left side door. look inside for a green plastic handle & lift up he metal guide plate sometimes the paper gets wrapped around the upper heat roller or curled up and around the separator claws. if so be very careful not to scratch the rollers or break the sep claws. there is a green handle/knob located in the machine that can be turned, this turns the fuser rollers and makes it a little easier to remove a fuser paper jam. After you remove the paper jam close all the doors/panels you first opened. the copier should reset itself. I have seen the pj errors change to a new one indicating another pj still exists. if so look again and remove as indicate by the Lcd screen. Please leave positive feedback if this helps
Jun 07, 2008 | Office Equipment & Supplies
Error message "cover door is open or printer cartridge is missing"
Try to find the latch in the cover that presses a switch to indicate it is closed it is usually a small stick projection at the sides of the cover. Replace the cartridge it should fit snuggly then try it again.
May 28, 2008 | HP LaserJet 1018 Printer
Dell 1815dn All-In-One Laser Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
