Question about JVC LT-32P300 32 in. LCD TV
Willnot powerup - JVC LT-32P300 32 in. LCD TV
  • 7 more comments
  • motorcycleis Nov 12, 2010
    Thank you .I will follow your instructions and let you know if sucessful. Mickey L. Harrison I.A.T.S.E.local480 n.m. stage mechanics
  • motorcycleis Nov 13, 2010
    can you decribe what the componets might look like I am testing what I think they are circut boards are not unfamilier but hobby would decribe meplease MR>Wizard help me(Tennesse Tuxedo)
    thank you can you decribe what idems might look like I can see power section of board they have nothing visible so with the meter I go Any more decriptions would be big help PLease MR.Wizard(Tennesse Tuxedo) Thank you M.L. Harrison
  • motorcycleis Nov 14, 2010
    yes I get the standby light then when I try to power up the green light comes on briefly and goes out .I checked the board no visible failuers with a magnifer .Every componet I tested with my meter showed a reading. thank you and any more suggestions before I have to spend for professional local talent?
    thank you for your help
  • motorcycleis Nov 17, 2010
    It has standby power
    yes the detail was quite decriptive and helpful .thank you gentleman Mickey Harrison
  • motorcycleis Dec 22, 2010
    Sorry your advice was no help. Since asking for your help I have replaced both of the large power boards and the button control board.I still get the standby light ,but same problem when powering up momentry green light and nothing .please is there something else other than the screen.
    I replaced both power boards with new and the button control board still same .Since I payed do I still get help?Please other than the screen whats left?
  • 8,197 Answers
Sorry we are not able to help you please send in for service.
Posted on Dec 24, 2010
  • 4,102 Answers
Hi, could i just ask, when you switch it on at the mains do you get the standby light coming on or is the whole tv totally dead as if no power is getting to the telly, let me know then i can assist you further ok
Posted on Nov 13, 2010
  • JVC Master
  • 6,993 Answers
your TV is having a power problem. The power supply board is defective that's why the TV won't power up. Its receiving power but it cannot transfer the current to the necessary part of the TV because a capacitor, diode, etc may have been faulty. Until these bad components are replaced, the TV might not come on.
If you know about TV repairers, I would suggest that you open the TV and read the power board/panel with a meter, detect the bad component and replace it. Take note that TV stores a lot of current that can shock, so leave the TV for a while before you open it.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you.
Good luck.
Posted on Nov 12, 2010
  • 10,515 Answers
The issue you describe is consistent with a power supply board issue.
This is the board where the AC goes to.
I do not think it needs replacement,rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different,most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Please note:
There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 14, 2010
Philips LX700 fuse blowing on powerup
Philips LX3000D - Fuses blowing on powerup. Help.
Jan 23, 2014 | Philips LX700 System
Black screen
Please post in Phones section.
Dec 25, 2013 | Computers & Internet
Powerup problems
you should not leave PC on for more than a couple days.
It may have gone into Hibernate and if there is a bad sector, (i.e. read errors,) when that is loaded into RAM, then that can cause many symptoms. Try to boot into Safe Mode, then if that works, Restart and use Normal mode.
Aug 31, 2012 | E-Machines T6532 PC Desktop
How to powerup the motherbaord without power switch
Hello, you can visit the dell homepage
and enter the sevicetag it should be at the back of your machine:
http://support.dell.com/support/topics/global.aspx/support/my_systems_info/manuals?~ck=ln&c=us&l=en&lnki=0&s=gen
The pinout should look like this:
You must use the pwrbtn or power pin to power up the mainboard.
Beware of static Electricity
Hope this will help you.
Aug 14, 2012 | Dell Computers & Internet
After starting Zebra S400 the printer makes an automatic calibration each time, spending 2 blanc labels on it. How do you turn off auto-calibration? Already tried the Zebra.com official site, without luck.
SET/UP EXIT
Hit the "+" quite a few times until you get to "MEDIA POWERUP"
Hit SELECT
Use the +/- keys to enter the password (1234)
Hit SELECT - you should see a small - and + button on the screen on either side of MEDIA POWERUP (if not, repeat previous steps)
Hit the + sign until you get to NO MOTION
Hit SELECT to exit MEDIA POWERUP
Hit the + button to go to the next item HEAD CLOSE
Hit SET/UP EXIT to save changes (permanently)
Open and close the printhead to check to see if it worked!!!
Sep 20, 2010 | Zebra Stripe S400 Label Printer
Unit will not powerup at all. I plug it in an turn
check to make sure it is full as it is auto shut off and check wire that it was not mulled out when someone tried to move it, also if it has a gfi make sure button is pushed in
Oct 28, 2009 | Maximatic Deluxe Popcorn Trolley Popcorn...
Need to powerup PowerEdge with out hitting the power Button!
ahhh ok, well in the bios of some machines their is an option to schedule a wakeup time for the PC, and you could also enable Wake On Lan and then wake up the PC remotely from a computer outside of the server room?
Feb 20, 2009 | Dell PowerEdge 1600SC Server
AC/Battery powerup
Well I think if you a tester test the battery if it is fine. It is not absolute sure that the battery is fine because it shows it is fine from the laptop.
If the battery is fine then there is something wrong at the connection of the battery with the motherboard.
Jan 28, 2008 | Compaq Presario 2170US Notebook
A310 shows USB icon on powerup
Nothing for you two and at this age the cost a repair will be well on the way to the price of a replacement. Get the new camera
Aug 21, 2006 | Fuji FinePix A310 Digital Camera
JVC LT-32P300 32 in. LCD TV Logo
112 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
