Question about Neff H5642 Convection / Microwave Oven
NEFF H5642SOGB/04 was completely dead. It's fairly new although ex demo so no warrenty. I opened it up and found the lamp blown and the internal 10 amp fuse gone. I have since replaced the fuse (I am awaiting replacement lamp) and now when I power it up the fan just runs constant, but no display working or able to operate in any other way. Any thoughts?
4 Suggested Answers
Falling Down
  • 67 Answers
SOURCE: Neff combi blown diode.
If the diode failed by opening, there may be no other damage. If the dioded failed by shorting, the alternating current may have damaged other components. Ohm it out. You can get diodes from digikey.com, mouser.com, or radio shack or any electronics or appliance supply. If the diode is charred and you can't get the part number, the oven rating can be used to select a replacement. Since the fuse was 10 amps, the diode should also handle at least 10 amps. If you can power the unit and read the voltage at the diode input this will give you the power (volts times amps). It's always worth trying as it's cheaper than replacing the unit.
Posted on Nov 30, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: neff h7871
If it went dead almost immediately after pressing the Start pad, that\'s usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that\'s usually a failing high-voltage transformer.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.microtechfactoryservice.com/cap_test.html
http://www.microtechfactoryservice.com/diode.html
http://www.microtechfactoryservice.com/mag_test.html
http://www.microtechfactoryservice.com/xformer.html
We\'re happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 06, 2008
heatman101
  • 43501 Answers
SOURCE: neff H 7871 microwave, 8 years old. Just gone
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Apr 22, 2011
Mirowave wont start
I assume from your description that you can set power and time but nothing kicks in when you press start?? This could be a control panel fault but may be a problem with the door lock/switches. Check that the spring on the door hooks is ok, just lift it up and check it returns to down position by itself. If the microswitches do not make properly when the door is closed the m/w will not start because it assumes the door is open. A microwave (even when switched off) can be storing a high voltage so unless you are trained I would suggest you get an expert to take a look. BSH is Neff service division 0844 872 8999, they offer a one off repair plan, which covers your first repair and then any further repairs for a year. You can pay monthly by DD to spread the cost. (This may be age related so as yours m/w is nearly 10years old, it may not be eligible).
Hope this helps.
Mar 21, 2013 | Neff Microwave Ovens
MY H5642SOGB microwave keeps blowing the trip for the sockets.
I have a neff microwave with no manual where can I get one, H5642SOGB, thanks
Feb 18, 2012 | Neff H5642 Convection / Microwave Oven
Light does not work
Replacement of the lamp should be carried out by a qualified appliance repair service.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
But here is a basic method if you are mechanically minded and have electrical safety knowledge.
The lamp is sat in a housing and its position is adjacent to the vent holes that it shines through.
If you feel confident, disconnect it from the mains power, remove anything in the cavity.
Remove the microwave cover. Purchasing a new replacement lamp will be useful as it will give you an idea of what it looks like. Locate the dead lamp remove the lamp and fit the new one. Replace the covers. Plug it back in and try the lamp by opening the door.
Hope this helps.
Feb 21, 2011 | Neff H7871N2GB Convection / Microwave Oven
Neff h5642 doesn't start at all. No lights, no display. What should I check first?
safety fuse (internal) will have blown usually caused by faulty inverter short circuit if fuse changed and blows again this is what it will be costly repair if out of guarantee.
Apr 19, 2010 | Neff H5642 Convection / Microwave Oven
Microwave wont run, displays E 10 on the screen and also microwave fault, press stop to acknowledge, just changed the door.
e 10 is the internal safety fuse has blown this often happens if door is altered for any reason moving the door can effect the setting of the monitor switches these are set to a high tolerance to avoid operation of microwave with door open changing the door has shifted these settings and blown the fuse, replacing the fuse may be enough to get it going but it should be checked for leakage.
Jun 11, 2009 | Neff H5470 Microwave Oven
Neff combination microwave oven
We have had NEFF repair man out again and he replaced the door switchs and this time it is OK.He did say if it was a problem again it will be classed as unrepairable because he thinks it is shorting out on an internal rivet on the bodywork which is inaccesable. fingers crossed it was the door switchs and it dosent blow the main fuse again .thanks for your responce. Simon.
Jul 23, 2008 | Microwave Ovens
Neff h7871
Jul 06, 2008 | Neff H7871 Convection/Microwave Oven
H5470 built in microwave
sound like the door monitor switched has blown or shifted out of position if the switches dont operate in tandem when door is opened or closed it will blow the 10 amp fuse and kill the display they will need to be checked by engineer if it is monitor switch they are not expensive to replace.
Apr 01, 2008 | Neff H5470 Microwave Oven
Complete Shut-Down
I woulds first suspect a blown internal fuse or a thermal cutout on the magnetron in your case, but a microwave can be dead for many reasons.
If it goes dead for just a while during or after cooking then comes back on, the magnetron is probably overheating and causing the thermostat to open. When it cools, it closes the circuit and allows power on again.
If it's intermittent or random, it may be a bad connection, usually on the control board or fuse holder.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Please write back with more details if you need further help.
We appreciate your thoughtful rating of our answer.
Nov 23, 2007 | GE Monogram ZE2160SF Convection /...
Oct 14, 2007 | Neff H7871N2GB Convection / Microwave Oven
Neff H5642 Convection / Microwave Oven Logo
119 people viewed this question
Top Neff Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Neff Microwave Oven Expert? Answer questions, earn points and help others
