Question about Clarity D613HS Phone
All my Clarity D613 cordless handsets give the "in use" tone when I try to use them. I've unregistered and reregistered all handsets successfully and erased all messages etc. The in use light on the base is not on and the handsets do not say "in use." My telephone service is fine - I called the service people to check the line signal. Still, if I turn on the phone to dial, instead of the dial tone I get the pulsing busy tone.
2 Suggested Answers
Charley C
SOURCE: How do you set the speed dial phone numbers on the
Clarity D613 Cordless Telephone
SPEED DIAL INSTRUCTIONS
To set, replace, or delete one of the nine Speed Dial numbers:
1. If you want to set or replace one of the Speed Dial numbers, and the new number is not already an entry in the phonebook, add the new phonebook entry before continuing here.
2. Press the PHONEBOOK button. The first entry in the phonebook displays.
3. Press the MENU button. The first two items (VIEW and ADD) of the seven-item PHONEBOOK menu display.
4. Press the UP/DOWN buttons (right side of the handset) to scroll to SPEED DIAL.
5. Press the MENU button. The first two items (KEY 1 and KEY 2) of the nine-item SPEED DIAL menu display.
6. The SPEED DIAL menu is displayed. If you do not want to make any (more) Speed Dial changes, press the BACK button until the HANDSET number displays, and stop following these instructions.
7. Press the UP/DOWN buttons to scroll to the KEY number that you want to set, replace, or delete; for example, KEY 4.
8. Press the MENU button. A phonebook entry appears. It is either the entry, if any, that is currently associated with the selected key or it is the first entry in the phonebook.
9. Press the UP/DOWN buttons to try to scroll to a different entry in the phonebook.
10. If you are able to scroll through the phonebook, the selected key is not currently associated with any phonebook entry and you have two options:
a. To leave the selected key without an association, press the BACK button and return to step 6.
b. To associate the selected key with a phonebook entry, go to step 16.
11. The displayed phonebook entry is currently associated with the selected key. If you want to leave it that way, press the BACK button and return to step 6.
12. Press the MENU button. A menu displays with two items (ADD and DELETE). By default, the ADD item is initially selected.
13. If you want to associate a different phonebook entry with the selected key, press the MENU button (to choose ADD). The first entry in the phonebook displays. Go to step 16.
14. Press the UP/DOWN buttons to scroll to DELETE.
15. Press the MENU button. DELETED displays. The selected key is now not associated with any phonebook entry. Return to step 6.
16. Press the UP/DOWN buttons to scroll to the phonebook entry that you want to associate with the selected key.
17. Press the MENU button. SAVED displays. The selected key is now associated with the selected phonebook entry. Return to step 6.
To call one of the nine Speed Dial numbers:
1. Press and hold the desired Speed Dial key (1 through 9 on the dial pad). The selected key number displays. If the key is associated with a phonebook entry, the call begins within a few seconds. Otherwise the phone beeps twice.
2. Release the key. If the key was not associated with a phonebook entry, you can either press the BACK key to return the phone to standby, or you can press the CLEAR key and then press a different Speed Dial key..
To review the phonebook entries that are associated with the Speed Dial keys:
1. Press the PHONEBOOK button. The first entry in the phonebook displays.
2. Press the MENU button. The first two items (VIEW and ADD) of the seven-item PHONEBOOK menu display.
3. Press the UP/DOWN buttons to scroll to SPEED DIAL.
4. Press the MENU button. The first two items (KEY 1 and KEY 2) of the nine-item SPEED DIAL menu display.
5. Press the UP/DOWN buttons to scroll to the KEY number that you want to review; for example, KEY 4.
6. Press the MENU button. The associated phonebook entry appears.
7. Press the BACK button.
8. If you want to review more Speed Dial associations, return to step 5.
9. Press the BACK button until the HANDSET number displays.
Posted on Feb 13, 2010
Clarity phone xlc 3.5 has static on it
Rather an unfortunate choice of brand name then :>) Take a look at the tips here
How to Remove Static Noise From a Cordless Phone ' It Still Works ...
https://itstillworks.com/12419015/how-to-remove-static-noise-from-a-cordless-phone
Sep 28, 2017 - Cordless phones transmit and receive radio signals to and from a base unit via antennae. They are convenient and can give you more freedom of movement when calling, but they are sometimes plagued by static noise problems. Find the small gray plastic box called the network interface device (NID) ... Missing: xlc ‎3.5
[PDF]3.5HS XLC3.5HSB - Clarity Products
shop.clarityproducts.com/media/.../XLC35HS_UserGuide_RevA.pd... Translate this page
F. R. A. N. ?. A. I. S. E. N. G. L. I. S. H. XLC. User Guide. 3.5HS. Additional Handset for select. Clarity products with ClarityLogic. XLC3.5HSB. XLC3.5HSB. XLC3.5HS .... telephone has been exposed to rain or water; if the telephone has .... Noise, interference or other calls heard while using the handset: • Make sure you are ...
Clarity Products - XLC3.6+HS
shop.clarityproducts.com > ... > By Product > Amplified Cordless Phones > XLC3.6+HS Illuminated talking dial pad with large buttons that speak the number that is pushed • Extra loud, flashing ringer with adjustable tones and voicemail indicator • Hearing aid compatible and TIA-1083 compliant • Direct connection to assistive listening devices or headset (2.5mm or 3.5mm) • Works only with XLC3.4+ or C4220+ ... Missing: static
Handset Registration; Troubleshooting - Clarity XLC 3.4 User Manual ...
https://www.manualslib.com > ... > Telephone > XLC 3.4 > User manual Clarity XLC 3.4 Manual Online: Handset Registration, Troubleshooting. XLC3.4 ... and the telephone. •. Make sure the handset battery is fully charged. •. Make sure the battery has been placed in the battery compartment. correctly. (The circular metal ... Noise, interference or other calls heard while using the. handset:.
Handset Registration; Troubleshooting - Clarity XLC3.4 User Manual ...
https://www.manualslib.com > ... > Telephone > XLC 3.4 > User manual Clarity XLC3.4 Manual Online: Handset Registration, Troubleshooting. XLC3.4 REGISTERING THE XLC3.4 Handset In Order To Use The XLC3.4 (or XLC3.1) Handset, You...
Clarity phone xlc 3 5 has static on it Google Search
Mar 07, 2018 | Clarity Lands Phones
Charging light on clarity d613 does not go off.
1) try to clean with alcohol isoprophil by 70% the contacts charger , unppluged the base, and wait by 30 minutes. and try again.
2) if the problem persist, go with the power supply inside, the IC can be damaged, replace go to the repair shop.
God bless you
Jul 21, 2012 | Clarity D613 Cordless Phone
Charging light does not go off
unppluget the base, and put contacts cleaner in the contacts charger buy it from radio shack or computer, and wait by 30 minutes.
2) try again, if work is o.k
3) if doesnot resolve the problem, the IC charger in power supply is defective repair go to the repair shop for fix it.
God bless you
The second handset says "not registered" and won't work. I lost manual. How do I "register" it so the mainbase recognizes it, please? Thanks.
1. Place the unregistered handset on the charger.
2. Press and hold the FIND button for 4 seconds on the base.
3. Release the FIND button once the IN USE light starts to flash.
4. A confirmation tone will sound when registration is successful. Handset X is displayed where X denotes the number of handsets. The phone will then go back to idle.
just in case you need it:
User Manual Clarity D613C Combo Pack (D613 with D613HS)
Don't forget to rate if this was helpful :-)
Sep 22, 2010 | Clarity D613HS Phone
Phone keeps saying move closer to base
The handset may have unregistered from the phone. The instructions to reregister it are in the manual, but I'll list them here for you.
1. On the handset, press MENU 001
2. On the base unit
For models KX-TG6021/KX-TG6022/KX-TG6023
Press and hold LOCATOR until the IN USE indicator flashes.
For models KX-TG6051/KX-TG6052/KX-TG6053/KX-TG6054
Press and hold LOCATOR/INTERCOM until the IN USE indicator
flashes.
After the IN USE indicator starts flashing, the rest of the procedure
must be completed within 1minute.
3. Press OK on the handset, then wait until a beep sounds.
4. Press OFF on the handset.
Aug 29, 2009 | Panasonic KX-TG6021 Cordless Phone
Electricity went off for few minutes, now phones have no dail tone
unplug five minutes ,from outlet jack also;plug in power only unregister all handsets and reregister them plug in wall jack ;that should work
Aug 16, 2009 | Uniden TRU9585-4 Quad Cordless Phone
No dial tone in Clarity C4230 setup
if you can get dial tone with another phone, look into manual for any instructions, usually a toll free number for help. ( BEST ) otherwise take phone back for exchange. may be problem in the board.
Apr 16, 2009 | Clarity C4230 Cordless Phone
EnGenius DuaFon 1X
Registration:
a. Press MENU-6 to enter the registration mode
b. Press and hold the base’s Registration (REG)
button for 2 seconds until 4 LEDs light up. (Located on the base where you plug in the phone jack)
c. Press handset key “1”, this completes the
registration process. When you register the
handset to BASE 10, the base will assign a
handset ID between 11 and 19. The assigned ID
will be displayed on the handset LCD, indicating
successful registration.
d. Repeat above steps for all additional handsets.
e. The first two handsets registered will be given ID
11 and 12, which gives them administrator
privileges.
Jan 04, 2008 | EnGenius DURAFON1X DuraFon 1X System Phone
How to REregister handsets
You can unregister your phone without being in the cradle, but to re-register them, just put them back in the cradle.  After being unregistered, they will automatically re-register once they are put back in the cradle of the main base.  Try setting them back in the base cradle to re-register, and hopefully that will work for you.
Dec 01, 2007 | Uniden TRU9480 Cordless Telephone
Clarity D613HS   Phone Logo
50 people viewed this question
Top Clarity Lands Phones Experts
Andrew Taylor
Andrew Taylor
Are you a Clarity Lands Phone Expert? Answer questions, earn points and help others
